  3. RGB-3D only showing 1 dimmer, not 3 in Vera
17 Posts 5 Posters 5.6k Views 3 Watching
  • V
    V
    vil1driver
    wrote on last edited by vil1driver
    if you have a great android phone, you can also using OTG cable with 'UsbTerminal' app.. nothing wirelessly..
    but of course try just after up a sketch on your arduino before disconnect from your pc
    • T
      timropp
      Thanks - I do have OTG cables. Can you connect that way via USB while the arduino is getting power via Vin (12V from the LEDs)? I thought you can't use Vin and USB at the same time.
      VeraEdge UI7 with Mysensors ethernet gateway
      • V
        V
        vil1driver
        You can use at the same time yes
        • T
          timropp
          Thanks - found out the same thing googling after I posted the question.
          Thanks all for your off-topic help! Can't wait to get home and get this thing working.
          • T
            timropp
            Solved!
            It was a hardware problem - I didn't put caps on the radio on the gateway or RGB node originally. I added them and the node added perfectly. I guess I got lucky originally that even the 2 devices appeared on the first try.
            DrJeffD 1 Reply Last reply
            • T timropp
              Solved!
              DrJeffD
              DrJeffD
              DrJeff
              @timropp Also remember if your gateway is using a long range antenna make sure it has enough power I have had that problem also. You may get some inclusion but not others.
              • T
                timropp
                Nope, just standard squiggle-antenna radios for me so far.
                • V
                  V
                  vil1driver
                  Great, have you get the 4 devices ?
                  I hope you will like this sketch, specialy the color cycle :-)
                  • T
                    timropp
                    I got 5 devices - the 3 R, G, B dimmers, a repeater, and the swirl on/off. However, for some reason my swirl doesn't work. Haven't spent any time messing with it, but clicking that button on Vera just turns on one channel of lights and clicking that button off does nothing. I had to use the matching dimmer to turn it off.
                    Not sure why, didn't spend any time tracking that down - for now I just needed the dimmers and they work great so I didn't dig :)
                    • V
                      V
                      vil1driver
                      strange..
                      the On/Off button is for start/stop color cycle (rainbow), but is very slow, and start with red color only..
                      maybe try to wait a bit more..
                      when you click it Off, it's stop the color cycle, save state and return actuals color to controler..
                      anyway, I'm glad you like it
                      • T
                        timropp
                        Yep, the cycle does work. I just wasn't patient enough :) I 'd assumed it was a faster swirl (didn't look at the code, just assumed).
                        Now just gotta actually run my LED strips in place and then it'll all be great! Thanks again for the help.
                        • Tore André RosanderT
                          Tore André Rosander
                          What is the actual solution to this problem? I have the same problem (mysensors v2 (dev)) and domoticz.
                          I have 2 RBG-3D nodes, the first one is showing all dimmers and works perfect, but when i added the second one i only get "Present Blue" and the "show" button.
                          Under the mysensors hardware in domoticz the second RGB node display "Name: unknown, Sketch name: Unknown".
