  3. [SOLVED] 2 X nrf24l01+pa+lna with RF24_PA_MAX
31 Posts 9 Posters 30.9k Views 4 Watching
  • TD22057T
    TD22057T
    TD22057
    I've been having reception problems myself (so I'm planning on switching to RMF69W modules) and have been reading more about antenna design since I want to create a custom PCB (and basically learning that I'll probably never know enough to be good at RF). You might be having ground plane issues - it can also help to try moving the radio module away from any other boards and metal surfaces near it and see if that helps too.
    • OitzuO
      OitzuO
      Oitzu
      Well... i never opened one of these standard 2,4ghz stubby antennas but i guess there is a little groundplane in there on the bottom of the antenna directly after the joint.
      It isn't that i got directly reception problems... 400-600m sounds good in my opinion. But working with the maximum i can get, would be nice...
      Little bit offtopic: Whats the maximum distance the RMF69W working on? Whats the datarate they deliver? I know that the RFM69W modules work on 868mhz so they naturally should work on a longer distance, but most 868mhz chips don't even reach the minimum datarate of 250kbps...
      • OitzuO
        OitzuO
        Oitzu
        Tested a little bit more. I have the strange feeling that setting the PA_LEVEL higher then LOW overdrives the nrf24l01+pa+lna. Has anyone ever used this modules with a PA_LEVEL higher then low?
        • SweebeeS
          SweebeeS
          Sweebee
          I use it at max and it works fine. How do you feed the 3.3V of the nrf? I use a AMS1117 (up to 800mA).
          • OitzuO
            OitzuO
            Oitzu
            External 2xAA batteries for my tests. In the final use case I will add a 3.3V voltage regulator. I got a tip yesterday that this could be a matter of inproper shielding to the module itself. Sounds like a plausible explanation to me. I will try today to shield the module from his own rf with tin foil.
            • OitzuO
              OitzuO
              Oitzu
              Just if anybody else is running into this problem:
              Shielding the module with tinfoil against RF worked great! With the tinfoil shield i got over 1km reach in a clear line of sight!
              • Z
                Z
                Zeph
                Wow. A little better!
                I assume that's at 250 Kbps? Did you do any range tests at different speeds?
                The nRF24L01+ with LNA & PA & antenna is not that much more expensive than the rfm69* so for some applications that need the higher speed they are still in the running even with longer distances.
                I saw an analsyis (maybe here?) which suggested that this setup would not do very much good for reception, which was more limited by the noise floor, such that the antenna gain and LNA would not improve things much - so most of the range gain would come from the increased transmit power (including antenna gain). This was a theoretic analysis, not an empircal test.
                If true, it would mean that using an enhanced power unit on one end of the link only would not give one much additional range in bidirectional protocols, where the back-link (conventional to enhanced) would be the limiting factor. I've been curious if this is indeed the case or not in practice.
                • F
                  F
                  Fabien
                  @Oitzu do you have some photo of your module with shielding ?
                  • OitzuO
                    OitzuO
                    Oitzu
                    @Zeph Only tried 250kbps at the moment, i tried to test the maximum range possible.
                    But i will also do some 1mbit and 2 mbit tests in the near future (depends on weather).
                    Hm.. i don't know what exactly do the performance gain. I also ordered some modules with external antenna but without external LNA+PA. Let's see what the LNA+PA really do. ;)
                    @Fabien: I will post a photo tomorrow. But basicly i just wraped cling film arround the module (to not get any shorts) and then wraped tin foil arround that.
                    • OitzuO
                      OitzuO
                      Oitzu
                      @Fabien:
                      Surely doesn't look "professional" but it works. In the final installation i will try to add aluminum tape to the inside of the project box.
                      • Z
                        Z
                        Zeph
                        wrote on last edited by Zeph
                        @Oitzu The range was greatly improved by using a far-aday cage.
                        Z 1 Reply Last reply
                        • OitzuO
                          OitzuO
                          Oitzu
                          @Zeph: Yeah i understand that. I meant if the pa all alone or if the lna also plays a role with this modules.
                          Because you mentioned that the lna probably doesn't play a role in this.
                          • F
                            F
                            Fabien
                            Thank you !
                            • Z Zeph
                              Z
                              Z
                              Zeph
                              Sorry, it was meant to be a throw-away pun, not an insight.
                              OitzuO 1 Reply Last reply
                              • Z Zeph
                                OitzuO
                                OitzuO
                                Oitzu
                                ... now i got it... haha... sorry. You know how many germans does it takes to change a lightbulb?
                                One. We are very efficient and don't have humour. ;)
                                • W
                                  W
                                  wico2002
                                  @Oitzu questions: on the picture, the foil cover up the base of the antenna. Can it touch the antenna connector itself (golden part the antenna is screw on) or this part also need to be covered with plastic film ?
                                  You also told you will try to cover up the inside of the case with foil to not wrap the radio itself... did you try it ?
                                  • OitzuO
                                    OitzuO
                                    Oitzu
                                    @wico2002: you should also cover the base of the antenna with plastic foil.
                                    As far as i know the base is grounded. I don't really know if this makes any difference but i let my tinfoil ungrounded. I'm no expert in RF mechanics. :D
                                    No not tried this yet.. but this should have the same effect as the tinfoil wrapping.
                                    As long as you let stick the antenna out of the housing.... ;)
                                    • W
                                      W
                                      wico2002
                                      @Oitzu A BIG THANK YOU, it work now with the foil trick. I'll will maybe close other forum topics including your topic's url. thank you again
                                      • DwaltD
                                        DwaltD
                                        Dwalt
                                        Using @Oitzu 's trick, I wrapped my iBoard Gateway in aluminum tape. I can't tell if there is any benefit in transmission range or reduced interference but at least it looks nice and shiny!
                                        • OitzuO
                                          OitzuO
                                          Oitzu
                                          @Dwalt will this box also sends packets to the path of valallah?
                                          DwaltD 1 Reply Last reply
