  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.1k Views 69 Watching
  • sundberg84S
    sundberg84S
    Another China iphone plug destroyed.
    This has been working for 2-3 weeks without problems... the plug runs a 5v arduino and a normal 240-5v relay with button and led, standard sketch.
    One day it just didnt started and i opened it up and saw a melted plastic cover and some burned component.
    I have felt the relays a couple of times and noone has been really hot.
    Im getting a bit shaky here... how far from disaster (big fire) is this?
    • rvendrameR
      rvendrameR
      rvendrame
      BTW, the review of HLK PSU should be published in 'few days' according to the guy from http://lygte-info.dk . Can't wait for that!
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • petewillP
        petewillP
        petewill
        @sundberg84 Yikes! That is exactly why I started this thread. I don't want to burn my house down...
        @rvendrame Awesome! Can't wait either!
        • rvendrameR
          rvendrameR
          rvendrame
          The review of the hlktech's HLK-PM01 is available here!
          Alexa / Google Home
          • F
            F
            Fabien
            Thank you for the test.
            • petewillP
              petewillP
              petewill
              This is fantastic news!!
              Would anyone be able to provide a parts list and wiring diagram based on the recommendations from the test site (pasted below)?
              "A few notes for using it:
              Electronic wears down faster when warm, especially capacitors, i.e. keep it as cool as possible for long lifetime.
              I would place a fuse or fusible resistor before the converter, the fuse is not supposed to be replaceable, when it blows it is time to replace the converter.
              A MOV accross the mains input would probably also be a good idea."
              Once we have a that info I will update the first post so everyone reading this in the future doesn't have to read through 200+ posts to get to the conclusion. Thanks to everyone who helped with this!!!
              • Z
                Z
                Zeph
                The wiring is easy to describe.
                Put a fuse in line between the "hot" mains AC input and the power supply module input (the "neutral" can go directly to the power supply). Put a MOV across the power supply input (on the PS side of the fuse).
                For small spikes, the MOV would protect the PS by absorbing most of it. For longer surges, the MOV would cause the fuse to blow, probably sacrificing itself in the process.
                Maybe others can help with component selection (for 120v and 240v mains). I see that in the case of Littelfuse, the fuse is rated by RMS AC voltage, so a 140v MOV would work for a nominal 120VAC mains). http://www.littelfuse.com/~/media/electronics_technical/application_notes/varistors/littelfuse_selecting_a_littelfuse_varistor_application_note.pdf
                I don't know if RMS rating is standard, or if some are rated by their DC voltage conduction threshold, but one would want to be sure of that for the brand they are getting.
                petewillP 1 Reply Last reply
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Some more thoughts from the guy who analyzed it:
                  "Hi Ricardo
                  It looks safe enough to me, except I want a fuse or fusible resistor before it. The purpose of the fuse is to blow when the module is worn down and maybe shorts. How fast it wears down will depend on temperature, at very high temperature it might be less than ½ year, at more moderate temperature it might be 10-20 years. The main culprit is the capacitors, their lifetime depends on temperature and quality of the capacitor.
                  Second risk for failure is large transients on the mains that may damage the module, again the fuse is there to prevent things getting out of hand if the module breaks down.
                  The module can get hot if you pack it into the wall, especially if it is inside a lot of insulation. Doing a few test with a DMM and a temperature probe taped to the module inside the wall might be a good idea when running the module near full load.
                  I do not know the stuff used to fill with, but usual it will not easily catch fire."
                  Alexa / Google Home
                  • TD22057T
                    TD22057T
                    TD22057
                    @rvendrame Thanks for getting this tested - that's a great result. The high temperatures he was testing at are for running at 1A of output but I thought that the 5V line is just for the Arduino and the radio which aren't going to use much current at all right?
                    rvendrameR 1 Reply Last reply
                    • TD22057T TD22057
                      rvendrameR
                      rvendrameR
                      rvendrame
                      @TD22057 , exactly, under regular load (< 600ma), the unit should not get that hot. Once I get some time I will try the suggestion, by gluing a temp sensor on the unit and put it behind the wall switch.
                      Perhaps I will add the temp sensor permanently as a extra mySensor on the wall-relay, so I can capture the temp during the upcoming summer days. ;-)
                      Alexa / Google Home
                      • B
                        B
                        Bertb
                        Well, I must say, I am very happy with the result. Thanks for the testing.
                        So, I am already planning to use it in a number of devices. To avoid too high temperatures in confined boxes, it might be a good idea to glue a temperature fuse to it and wire it in series with the live mains wire. When the temperature rises above, lets say 75 degrees celsius, the fuse breaks down.
                        • TD22057T
                          TD22057T
                          TD22057
                          It would also be good to link that temp sensor into the arduino. Then it could send out a "help my temp is to high" message before it shuts down. It should be possible to implement an overheated mode which would just blink a status LED on the front of the device and shuts everything else down until the temperature drops. Using the tricks of running a battery powered node should let the arduino power stay low enough for the PSU to cool down while still checking the temperature every few minutes and running the LED. The fuse would then be a fail-safe backup to the overheated mode.
                          • rvendrameR rvendrame
                            "Hi Ricardo
                            mvdarend
                            "Hi Ricardo
                            *It looks safe enough to me, except I want a fuse or fusible resistor before it. The purpose of the fuse is to blow when the module is worn down and maybe shorts.
                            Would something like this be OK?
                            http://www.aliexpress.com/store/product/100pcs-LOT-PTC-Resettable-Fuses-TRF250-080-250V-0-08A-80MA-PPTC-Polymeric-PTC-PolySwitch-DIP/1653204_32267664975.html
                            • M mvdarend
                              "Hi Ricardo
                              rvendrameR
                              rvendrameR
                              rvendrame
                              @mvdarend , I don't have experience to evaluate that. These ones are current-driven, I think it would be nice some fuse that is temperature-driven (despite I don't know even if that exist or what would be the parameters for that...)
                              Alexa / Google Home
                              • Z Zeph
                                petewillP
                                petewillP
                                petewill
                                @Zeph Thanks.
                                Do you all think a 150v MOV is ok for USA? I found some cheaper than the 140v on ebay but I' like to do it right :)
                                http://www.ebay.com/itm/LOT-of-10-MAIDA-METAL-OXIDE-VARISTOR-RADIAL-MOV-8mm-Disk-150V-D68ZOV151RA03-/390095815756?hash=item5ad385c44c
                                I found these fuses but they are 250v. Do you think that would be OK for 120v normal power or do I need to find 150v fuses?
                                http://www.ebay.com/itm/Through-Hole-T5A-5A-250V-Radial-Leads-Miniature-Micro-Fuse-20-Pcs-SP-/181623867749?hash=item2a49a04965
                                Something like this for the temperature fuse?
                                http://www.ebay.com/itm/3-pcs-New-KSD-9700-70-C-250V-5A-Thermostat-Temperature-BiMetal-Switch-NC-Close-/141752004726?hash=item210113f076
                                Is there anything else I'm missing that should be included in the circuit? Like others, I was also thinking that adding a temp sensor to the Arduino would be good so I could tell how hot it is in the box at any time.
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  wrote on last edited by rvendrame
                                  #220
                                  More from the 'guru'
                                  "There is no input fuse, that is the reason I recommend one and it has to be a real fuse that blows, not a fuse that will automatic recover. The only time it is supposed to blow is if the converter blows and then you want the mains permanently disconnected. Probably a 0.2A slow fuse will work."
                                  Alexa / Google Home
                                    mvdarend
                                    @rvendrame Thanks for the clarification.
                                    • Z
                                      Z
                                      Zeph
                                      And a 250VAC fuse is fine to use on 120VAC (and in fact quite common).
                                      • petewillP
                                        petewillP
                                        petewill
                                        Ok, how does this look for parts?
                                        70 degree (Celsius) fuses - http://www.ebay.com/itm/10pcs-Thermal-Cutoffs-SEFUSE-Microtemp-Thermal-TF-Cutoff-NEC-Fuses-73-C-240-C-/221560426284?var=&hash=item339607cf2c
                                        .75A fuse - They are fast blow not slow like specified above. Does that matter?? http://www.ebay.com/itm/40Pcs-ELECTRIC-FUSE-FAST-BLOW-0-75A-250VAC-35A-IR-THROUGH-HOLE-/271902224922?hash=item3f4ea2b21a
                                        Same MOVs http://www.ebay.com/itm/LOT-of-10-MAIDA-METAL-OXIDE-VARISTOR-RADIAL-MOV-8mm-Disk-150V-D68ZOV151RA03-/390095815756?hash=item5ad385c44c
                                        Is there anything else I'm missing? The goal with all this is to make another "how to" video so I want to make sure I'm not giving people bad advice.
                                        So, it would look something like this (ignore power to radio, didn't have time to wire it):
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          @petewill . the MOV goes in parallel with HLK input (and not in series like you did).
                                          It was suggested to use .2A fuses (instead the .75A). And the Thermal fuse should be glued on HLK top (my guess).
                                          Alexa / Google Home
