  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.6k Views 13 Watching
  • Z Zeph
    @petewill just to be clear - I appreciate your posting that adding the loose wire to the on-PCB antenna helped, and I'm not discouraging that. If it works, it works! Mostly I wanted people to understand that it's going to be trial and error, rather than something where they can count on calculating the best length (because it's added to another antenna at an unanticipated point, rather than being a standalone wire antenna). It would not surprise me if somebody found that a 6.5 cm wire worked better than 8.33cm, for their particular case (picking an example length at random). Wiggle those rabbit ears!
    I love the examples you post and your excellent videos. I have modestly good knowledge here and there, with gaps in other places, and your working examples give me confidence/inspiration to build something I haven't before - along with practical (not just theoretical) advice. You even turn your minor mistakes into lessons - how it should have been done, and how you managed to work around it anyway. Keep them coming!
    petewillP
    petewillP
    petewill
    I agree. The more knowledge provided to people the better hopefully it will result in better communicating nodes. Thanks for the posts!
    • petewillP petewill
      @Zeph I agree. This is complicated stuff that I don't even begin to grasp. That said it is a cheap and easy hack to try. In my case it has helped every time. Maybe I just got lucky but it helped enough of my nodes that I thought I'd at least tell people about it. If it doesn't work, then just remove the wire and no harm done. Thanks for all your contributions to the site. Your knowledge is helping a lot of people.
      @TheoL Thanks for the kind words! Although, credit really goes to @hek and the team. They are the geniuses that make this all work! Good luck with "mysensoring" the old power plug. But, be careful, it's addicting. :)
      TheoLT
      TheoLT
      TheoL
      @petewill Off course I'm very gratefull for what @hek and the team created. I've been playing with mySensors for a week now. And I'm still amazed by it. It's so easy to use. And I haven't had a failure yet. I'm currently promoting MySensors to everyone I know ;-).
      @hek Do you happen to have some small stickers with the MySensors logo? Ik would love to put them on the sensors I create. Something like "Powered by MySensors"?
        Good idea. But currently not something we have.
        • Z
          Z
          Zeph
          I like the idea of logo stickers. Better in some ways than typical swag like t-shirts and coffee cups, because if it goes on the devices we build that provides useful information, not just advertising. Maybe leave a blank section where a node number could optionally be written in with a sharpie, or a version.
          Maybe "Networked by MySensors.org" rather than powered? ("Telepathy by MySensors"?)
          TheoLT 1 Reply Last reply
          • Z Zeph
            TheoLT
            TheoLT
            TheoL
            @Zeph How about Wired by MySensors ;) Because my experience is that it seems like all sensors and the gateway are wired together because of MySensors.
              Dome Stickers would be nice ;)
              http://www.aliexpress.com/item/Custom-Made-with-Your-design-Clear-Dome-Resin-Sticker-Epoxy-Stickers-Label-1000pcs-free-shipping/1875126113.html?spm=2114.031010208.3.1.zlyb2B
              Just wonder how we should make them cost-effective to buy for the community...
                TheoLT
                TheoLT
                TheoL
                @hek they look good to me! Maybe you can start a poll on this forum. Ask the members who would like to buy the stickers. If the majority wants them, we can order them.
                • Z
                  Z
                  Zeph
                  The domes are kind of cool for some things, but I think for this purpose I'd actually prefer flat stickers that fit smoothly on any side of a project box, even curved, without protruding and looking like something that should be pressed, or that should light up.
                  (OTOH domes atop an illuminated button (assuming translucent backing) would be awesome in some cases)
                  And with flat, (re) distribution in small batches is easier - one could get a lot of them in a minimum-postage conventional letter.
                  • Kenney RK
                    Kenney RK
                    Kenney R
                    Hi Pete,
                    I'm thinking of using the AMS1117 3.3v regulator. Can I still use the 0.1uF and 10uF capacitors or do I need to use others. Because I run into sites saying I need to use 100uF and 1000uF and I think the difference is pretty big.
                    Regards,
                    Kenney
                    btw: Great video! It helped me a lot!!
                    petewillP 1 Reply Last reply
                    • Kenney RK Kenney R
                      Hi Pete,
                      Regards,
                      Kenney
                      petewillP
                      petewillP
                      petewill
                      Yes, that should be fine. The capacitors are there to help filter the power to the radio (which can be sensitive).
                      • Z
                        Z
                        Zeph
                        Regarding adding wires to the on-PCB antenna of a nRF24L01+ module, here's someone who used two wires (andcut some traces) to create a dipole. He knew that it was hard to really calculate the appropriate values, so he did empirical testing to find the best lengths, using a test program.
                        http://www.instructables.com/id/Enhanced-NRF24L01/
                        And is this from the same Pete or another one?
                        https://www.youtube.com/watch?v=NpMnauHeR7Y
                        • Z
                          Z
                          Zeph
                          Another interesting (albeit long) video testing range of various modules and antennae.
                          https://www.youtube.com/watch?v=gtM832Z0ujE
                          The interoperability of different types is somewhat surprising. Some had only a 2/3 packet success ratio even at close range, but retained that for a long distance, for example. He did try cap vs no cap, and with "whip" (really more of a stubby or rubber ducky style) antenna parallel or with one pointing at the other. The unit with PA+LNA and shield was overall pretty good for range.
                          • Z Zeph
                            petewillP
                            petewillP
                            petewill
                            @Zeph thanks for sharing. Always better to have more info and hopefully better range!
                            • sundberg84S sundberg84
                              @petewill
                              Now i got three working relays thanks to you, so again, great video!
                              Wanted to thank you and also show my sollution.
                              I hade some 433mhz cheap (not good working) relays with perfect case i could re-use:
                              The case had a status-led and a switch i use as well.
                              dayve218
                              @sundberg84 how are you powering the arduino?
                              • sundberg84S
                                sundberg84S
                                @dayve218
                                Im using a USB charger as pete does in the video but mine is a iphone charger instead of a samsung.
                                • D
                                  dakipro
                                  Nice project, both Petewill and sundberg84.
                                  I was just wandering if you @sundberg84 know more about what is the device type/model/manufacturer you were moding?
                                  I've used quite some time and effort to find localy some good case that I can modify, I did manage to hack some of them but they are just not quite reliable (something with power just kills caps too often).
                                  Thanks in advance, sorry for bringing up old topic (but it is a very good one :) )
                                  • sundberg84S
                                    sundberg84S
                                    @dakipro - Its a low brand 433mhz wall plugs i bought in Sweden called Everflourish emw100r. I dont think they are sold anymore. Its probably some china brand so maybe they are sold in another name.
                                    • dbemowskD
                                      dbemowskD
                                      So I have been thinking of building some relay controlled power strip nodes similar to these, but there have been some issues that I have been thinking about. The first is that if I am going to use a relay to turn on an outlet, the relay would need to be powered the entire time that I would want that device on. This would mean that not only am I powering the device that is plugged in, but the power to keep the relay on also. Wouldn't it be smarter to use latching relays? At least with those you don't need to keep power to the relay while your outlet is on. Has anyone ever done a MySensors node with latching relays? If so, how do you manage monitoring the state of the device?
                                      • D
                                        dakipro
                                        out of the curiosity, what is downside of powering the relay entire time?
                                        that is how (all) wall switches work out of the box, you press the button and they turn on/off by powering the relay (all the time).
                                        I think that they work quite reliably when it comes to keeping power to the reley
                                        dbemowskD 1 Reply Last reply
                                        • D dakipro
                                          dbemowskD
                                          dbemowskD
                                          @dakipro I wouldn't say that ALL wall switches work that way. And when you say (all) wall switches, what are you referring to? Standard (non automated) wall switches don't use relays. Also, most if not all of the X10 relay modules and wall switches that I have use latching relays.
