No softspi support for RFM69
It seems that the softspi functions were not implemented as part of the Rfm69 implementation and this is not mentioned anywhere as far as I can tell. There is a big difference in the Rf24.h and Rf69.h files. This means that it is not possible to use ethernet gateway with Rfm69 and wiznet module
with an extra component it should be possible to use wiznet and rfm69.. you need to have something that can disable MISO line from the Wiznet chip.
Could be a 74lvc1g125. Needs a bit more soldering / messing arround, but it's doable..
It should also be possible to use normal SPI for the NRF together with W5100, when using the above "hack"
@mrmin24 Have you had a chance to upload this yet?
FYI - It looks like the RFM69 library from lowpowerlabs might not have have been updated. Here are some threads about using an RFM69 w/ an ethernet shield over there:
https://lowpowerlab.com/forum/index.php/topic,838.0
https://lowpowerlab.com/forum/index.php?topic=557.0
https://lowpowerlab.com/forum/index.php?topic=201.15I'm just starting to work my way through these now but if you've already got it working, that would be great. I'm very curious to see if MqttClientGateway + digital signing + RFM69 will compile down small enough to fit.
I was able to implement the module RFM69 on a soft spi (RFM69 only for now). It is not very complicated. If anyone is interested, I can post a description how to do this, or I can send the ready files. Unfortunately, I did not use GitHub yet and not posted files there - I'll try to do it as soon as I can.
I use modules RFM69W and RFM69HW as radio modules. As the gate I use MySensors MQTTgateway (Arduino Mega 2560 R3 + ethernet shield + RFM69HW). Everything works pretty well and I can build an entire network of sensors based on MySensors libraries. -
Thanks. Chat message sent w/ my email to get the files. I won't have time to mess with the radios until next week but then I can set up a git pull request with your changes if you like. I decided to spend the $7 and get a Mega for my gateway and duplicate your set up (except w/ the MqttClientGateway). Did you apply the ethernet shield reset fix to the mega+ethernet? More info here: http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors/156
I'm using Arduino Mega in my gate because I want to add LCD display in the future . Uno has too little ram to do it.
Now when I compile MQTTgateway sketch with my RFM69 soft spi library in the arduino ide it takes 18 838 bytes, variables 882 bytes, so this should be fit for Uno. -
Nice. I bought a Mega with an LCD touch screen too. I also thought it would be interesting to have a gateway that can show you messages it receives on a screen and other information.
OK, finally I put my library and files at GitHub repositories. You can find it at https://github.com/gieemek
I don't need to reset my gateway after power lost (Arduino Mega 2560 + ethernet shield + RFM69HW radio) - everythng working good.
Now when I compile MQTTgateway sketch with my RFM69 soft spi library in the arduino ide it takes 18 838 bytes, variables 882 bytes, so this should be fit for Uno.@gieemek said:
Now when I compile MQTTgateway sketch with my RFM69 soft spi library in the arduino ide it takes 18 838 bytes, variables 882 bytes, so this should be fit for Uno.Ooops, I have made a mistake. My MQTTGateway.ino sketch with RFM_softSPI library compiles to 28 474 bytes, variables 1 003 bytes. Sorry for my earlier notes.
Thanks! The connection diagrams are a nice touch. I'll take a look and try it out (probably w/ the MQTTClientGateway) as soon as I can.
How hard would it be to make a version of RFM69 that would support soft and hard spi? I haven't run diff's yet to see what your modifications were but it would be nice if this was a fork of the LowPowerLap library so Felix could fold back in to his version code. Having two versions of the same file that I have to switch between might get confusing in the future.
Modifications were easier than I expected, only that I am successfull (I'm not a programmer).
For now, the program did not switching between soft and hard SPI and I fail to realize it fast - really frequently change the file is uncomfortable.
I want to send my library to LowPowerLab to check it.
If you are interested in further modification of this library, I can send you by mail a list of changes I made. -
I modified MyConfig.h file and RFM69 driver to allow you build gateway (ethernet or MQTT) with W5100 ethernet and RFM69 radio modules using SoftSPI bus. You can find it at: https://github.com/gieemek/RFM69_softSPI-for-MySensors-2.1.1
