  3. Relay actuator sketch - auto off function
relay
17 Posts 4 Posters 10.9k Views 4 Watching
    try like this... I can compile but not test.
    Note: relay Pins in array will need to be edited, of course...
    //#define RELAY_ON 1  // GPIO value to write to turn on attached relay
    //#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
    #define PULSE_TIME 500UL
    byte relayPin[] = {4,5};
    unsigned long relayStartTime[2];
    boolean pulseRelay[] = {false, false};
      gw.begin(incomingMessage, AUTO, true); // Initialize library and add callback for incoming messages
      gw.sendSketchInfo("MyRelay", "1.0"); // Send the sketch version information to the gateway and Controller
      for (byte sensor = 0; sensor < 2; sensor++) // Fetch relay status
        gw.present(sensor, S_LIGHT); // Register all sensors to gw (they will be created as child devices)
        pinMode(relayPin[sensor], OUTPUT); // Then set relay pins in output mode
        //digitalWrite(relayPin[sensor], gw.loadState(sensor) ? RELAY_ON : RELAY_OFF); // You probably dont want to use EEPROM store here since you are only pulsing
      updateRelays();
    void incomingMessage(const MyMessage &message)
      if (message.type==V_LIGHT)
         //digitalWrite(message.sensor, message.getBool() ? RELAY_ON : RELAY_OFF); // Change relay state
         pulseRelay[message.sensor] = true;
         relayStartTime[message.sensor] = millis();
         //gw.saveState(message.sensor, message.getBool()); // Store state in eeprom // Again, not needed here, I believe
         Serial.print("Incoming change for sensor:"); // Write some debug info
    void updateRelays()
        if (pulseRelay[sensor] == true)
          if (millis() - relayStartTime[sensor] <= PULSE_TIME)
            digitalWrite(relayPin[sensor], HIGH);
            digitalWrite(relayPin[sensor], LOW);
            pulseRelay[sensor] = false;
    N
    N
    niccodemi
    @BulldogLowell thanks again.
    • N niccodemi
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @niccodemi
      great, let me know if it works for you
      N 1 Reply Last reply
        @niccodemi
        N
        N
        niccodemi
        @BulldogLowell I tested it today and it works as expected.
        On the hardware side do you think it would make more sense to use transistor instead of relay (since I am dealing only with 12 volts)?
        • N niccodemi
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @niccodemi
          I would consider what I'm switching (the load) as much as the voltage and the way they are being powered.
          " ...simple 12v 433 mhz remote control..."
          what kind of remote is this?
            @niccodemi
            N
            N
            niccodemi
            @BulldogLowell it is remote control fob similar to this one. It uses 12 volt battery (27A).
            DwaltD 1 Reply Last reply
            • N niccodemi
              DwaltD
              DwaltD
              Dwalt
              @niccodemi
              I am curious why you chose arduino -> relay -> 433 transmitter for your project and not simpler arduino -> 433 transmitter. I ask because I have one of these key fob RF cloners lying around and have not put it to use yet. I was considering using it to trigger scenes via a 433 receiver on a yet-to-be-built node.
              • DwaltD Dwalt
                @niccodemi
                N
                N
                niccodemi
                @Dwalt initially I tried with Vera and Rfxtrx433 but only later I learned there are many different coding systems on 433 Mhz and many (including Lightning4) are not supported in Rfxtrx plugin. I wanted to try with arduino + 433 transmitter but about same time I found out about mysensors and abandoned 433+arduino altogether. That said I've still got couple 433 mhz controlled switches and I want to integrate them to Vera-Mysensors environment. Until now I thought that the only option is to use relay. I would be interested to try other solutions.
                • N niccodemi
                  DwaltD
                  DwaltD
                  Dwalt
                  @niccodemi I have several of these 433 switches and use a nano (w/mains power) with the 433 transmitter from the store to control them thru MySensors/Vera. The drawback is that these cheap outlets do not give feedback (with MySensors or RFXtrx) but Vera tracks their state by last command.
                  The four I have on my setup work very reliably and have not failed a trigger command during the past two months of operation. The 433Mhz transmitter seems to have better distance within my house than the NRF24 and is very reliable, at least thru my limited experience. My 433 transmitter node is within line of sight of my gateway and only 3m distant. The 433 outlets are scattered throughout my house, on different floors and through multiple walls. I use them to control floor lamps and a fan.
                  I sniffed the RF code from the included remote using the 433 receiver and then put the codes within the sketch on the nano controlling the 433transmitter. I used this blog for details on the sniffing process. I got the set of four outlets for about $18 shipped during a sale so it worked out to $4.50 each.
                  • DwaltD Dwalt
                    mvader
                    @Dwalt can you post your sketch for these 433 mhz units?
                    • M mvader
                      DwaltD
                      DwaltD
                      Dwalt
                      @mvader
                      The original sketch was posted here. It is crude (my first arduino sketch) but it worked and continued to work for the past 9 months. I sniffed the codes and then hard coded them into the sketch rather than use one of the RF libraries which I couldn't figure out.
                      I recently updated it for it to work under MyS 1.5 but did not refine it. It is still ugly:
                      #include <EEPROM.h>
                      #include <NewRemoteReceiver.h>
                      #include <NewRemoteTransmitter.h>
                      #include <MyTransportNRF24.h>
                      #include <MyHwATMega328.h>
                      #define TRANSMITTER_PIN 3
                      #define RECEIVER_INTERRUPT 1
                      #define RF433_CHILD_ID 0
                      #define NUMBER_OF_OUTLETS 4
                      #define DELAYSHORT 160
                      #define DELAYLONG  500
                      #define SEND_DATA 3
                      static void ookPulse(int on, int off) {
                        digitalWrite(SEND_DATA, HIGH);
                        delayMicroseconds(on);
                        digitalWrite(SEND_DATA, LOW);
                        delayMicroseconds(off);
                      static void pt2262Send(uint16_t signature, uint8_t command) {
                        byte i, k;
                        // send 16 times
                        for(k=0;k<16;k++) {
                          // send signature first
                          for(i=0;i<16;i++) {
                            if((signature>>(15-i)) & 0x1) {
                              ookPulse(DELAYLONG, DELAYSHORT);
                              ookPulse(DELAYSHORT, DELAYLONG);
                          for(i=0;i<8;i++) {
                            if((command>>(7-i)) & 0x1) {
                          // end with a '0'
                          // short delay
                          gw.wait(5);
                       gw.sendSketchInfo("RF433", "1.1");
                       for (int sensor=1; sensor<=NUMBER_OF_OUTLETS; sensor++){
                        if (message.type==V_LIGHT) {
                        int incomingLightState =  message.getBool();
                        int incomingOutlet = message.sensor;
                       /* Serial.print("Outlet #: ");
                        Serial.print("Command: ");
                       if (incomingOutlet==1) {
                       if (incomingLightState==1) {
                          // Turn on  socket 1
                       //   Serial.println("\nTurn on Socket 1");
                       pt2262Send(0b0101000101010101, 0b00110011);
                       gw.wait(100);
                       if (incomingLightState==0)  {
                          // Turn off socket 1
                       // Serial.println("\nTurn off Socket 1");
                      pt2262Send(0b0101000101010101, 0b00111100);
                      gw.wait(100);
                       if (incomingOutlet==2) {
                          // Turn on  socket 2
                       //   Serial.println("\nTurn on Socket 2");
                       pt2262Send(0b0101000101010101, 0b11000011);
                       gw.wait(100);
                          // Turn off socket 2
                      //   Serial.println("\nTurn off Socket 2");
                      pt2262Send(0b0101000101010101, 0b11001100);
                      gw.wait(100);
                       if (incomingOutlet==3) {
                          // Turn on  socket 3
                       //   Serial.println("\nTurn on Socket 3");
                       pt2262Send(0b0101000101010111, 0b00000011);
                       gw.wait(100);
                          // Turn off socket 3
                      //   Serial.println("\nTurn off Socket 3");
                      pt2262Send(0b0101000101010111, 0b00001100);
                      gw.wait(100);
                       if (incomingOutlet==4) {
                          // Turn on  socket 4
                       //   Serial.println("\nTurn on Socket 4");
                       pt2262Send(0b0101000101011101, 0b00000011);
                       gw.wait(100);
                          // Turn off socket 4
                      // Serial.println("\nTurn off Socket 4");
                      pt2262Send(0b0101000101011101, 0b00001100);
                      gw.wait(100);
                       gw.wait(100);
                      • DwaltD Dwalt
                        @mvader
                        #include <EEPROM.h>
                        #define SEND_DATA 3
                          byte i, k;
                          // send 16 times
                          for(k=0;k<16;k++) {
                            for(i=0;i<16;i++) {
                            for(i=0;i<8;i++) {
                            // end with a '0'
                            // short delay
                            gw.wait(5);
                            // Turn on  socket 1
                         gw.wait(100);
                        gw.wait(100);
                            // Turn on  socket 2
                         gw.wait(100);
                        gw.wait(100);
                            // Turn on  socket 3
                         gw.wait(100);
                        gw.wait(100);
                            // Turn on  socket 4
                         gw.wait(100);
                        gw.wait(100);
                         gw.wait(100);
                        mvader
                        @Dwalt oh wow.. thanks so much.. i was waiting for you to get back to me but never saw this post.. and i just happened to stumble on it when i was looking to see if you had been back on the forum or not.
                        I'm good with the hardware side of things and can shell script and do windows scripting. but still have not learned this coding yet.
                        i have all the hardware for the 433 stuff.
                        i even got the RF stuff to work (on my RPI2) and sniffed all my codes
                        i could just never get it to work with my arduino stuff.
                        likely the code, so i'm excited to give your code a go.
