  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.1k Views 14 Watching
  • D
    diggs
    @jkandasa thanks for the reply. Will add in the issues section
    • J
      J
      jkandasa
      Anyone tried MyController.org to setup locally? If yes kindly share your experiences ;)
      • J
        J
        jkandasa
        Wiki Link: http://www.mycontroller.org/
        • D
          d-smes
          @jkandasa very nice work! As for my experience, I had a bit of trouble getting it started. Somehow, I was under the impression that double-clicking start.bat would automatically start the Java app. It was later that I realized I then need to point my browser to localhost:8443 and log in. Your WIKI is well written, but I somehow missed that step. BTW, I'm using the Ethernet gateway and editing settings was a breeze.
          Possible bug to report- Sensors with an ID of 0 (zero) are not auto-detected. I have four nodes with sensor ID's of 0 that I know are sending data but they do not show up on Sensors page or on Action Board.
          • J
            J
            jkandasa
            @d-smes thank you to gave a try with MyController.org. Could you please see your log file is there any error? logs/mycontroller.log
            • J
              J
              jkandasa
              @d-smes can you see other sensors in MyController page? other than sensor id 0
              • D
                d-smes
                @jkandasa Yep, error log full of the same sets of errors. Example of one error pair:
                2015-09-16 11:41:55,150 WARN [Thread-3] [org.mycontroller.standalone.db.dao.SensorDaoImpl:52] Sensor:[org.mycontroller.standalone.db.tables.Sensor@e7f65f[id=<null>,sensorId=0,type=<null>,messageType=38,name=<null>,updateTime=<null>,status=<null>,lastValue=<null>,unit=<null>,node=org.mycontroller.standalone.db.tables.Node@18dbb32[id=4,name=<null>,version=<null>,updateTime=<null>,type=<null>,mySensorsVersion=<null>,batteryLevel=<null>,eraseEEPROM=<null>,firmware=<null>]]], Sensser Id should be in the range of 1~254
                2015-09-16 11:41:55,150 ERROR [Thread-3] [org.mycontroller.standalone.mysensors.MessageMonitorThread:68] RawMessage[NodeId:4,ChildSensorId:0,MessageType:1,Ack:0,SubType:38,PayLoad:4.825] throws exception while processing!,
                java.lang.NullPointerException: null
                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.recordData(ProcessRawMessage.java:480) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.setSubMessageTypeSelector(ProcessRawMessage.java:449) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.messageTypeSelector(ProcessRawMessage.java:91) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                	at org.mycontroller.standalone.mysensors.MessageMonitorThread.processRawMessage(MessageMonitorThread.java:60) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                	at org.mycontroller.standalone.mysensors.MessageMonitorThread.run(MessageMonitorThread.java:82) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                	at java.lang.Thread.run(Unknown Source) [na:1.8.0_60]
                The clue appears to be "Sensser Id should be in the range of 1~254"
                Nodes with multiple sensors show e.g. sensors 1- 11 but not sensor 0.
                • J
                  J
                  jkandasa
                  wrote on last edited by jkandasa
                  #36
                  @d-smes My bad it was a mistake, I understand wrongly like, we will not have sensor id 0, should have only from 1~254, now corrected and will allowed 0~254 id,
                  you have to stop your mycontroller server and replace lib/mycontroller-standalone-0.0.2-alpha2-single.jar with the fix http://www.filedropper.com/mycontroller-standalone-002-alpha2-single
                  • J
                    J
                    jkandasa
                    MyController.org Released 0.0.2-alpha3 :thumbsup:
                    For user documents visit MyController.org
                    • D
                      diggs
                      Just wondering if it is possible to run two controllers side by side both looking at the same serial port?
                      i.e. can I run Domoticz and MyController at the same time in serial mode with the one gateway or would it cause issues?
                      • J
                        J
                        jkandasa
                        @diggs for my knowledge we could not share same port directly for two applications. We may need to use some adapters for this operation. I do not know how much it is possible.
                        • E
                          E
                          etrombly
                          @diggs I was looking into doing the same thing. There are ways to duplicate a serial port using utilities like socat that should work. I was having issues with one side of the redirect disconnecting when there was no data to read. I was thinking of just writing up a quick python utility that would have the features I wanted. ser2net would work well, but it only redirects the port to the network, it doesn't do local redirection.
                          • E
                            E
                            ericvdb
                            @jkandasa Would it be possible to add a graph for the battery percentage?
                            • J
                              J
                              jkandasa
                              @ericvdb Thank you for your interest with MyController.org. I have created a request for battery percentage. Kindly update your thoughts on this https://github.com/mycontroller-org/mycontroller/issues/14
                              How often node sends battery percentage?
                              • F
                                F
                                fleinze
                                That depends on your sketch. I update battery every hour, but only if there are changes.
                                  shattered
                                  wrote on last edited by shattered
                                  #44
                                  Thank you - This is what I have been looking for. I was getting ready to write my own which I did not have time for. It is simple displays the data that is needed and easy to debug. The other controllers I tried I spent more time debugging because of the bloat. I can not focus on my sensor development.
                                  • D
                                    davidbd
                                    Nice ! Very clean GUI !
                                    I installed this controller on RPI with serial gateway and it works like a charm with two TEMP sensors.
                                    It will be good if you can use the RPI GPIO to connect directly to NRF24 RF module instead on adding the serial gateway ( see http://iot-playground.com ..)
                                    I wish you good luck with this project.
                                    J 1 Reply Last reply
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      Actually, you can add the NRF24 directly to the Raspberry and use it as a gateway at the same time:
                                      http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                                      • D davidbd
                                        J
                                        J
                                        jkandasa
                                        #47
                                        Yes, I have plan to implement NRF24l01 directly. I have to learn more about how mysensors gateway is working. Also planing to implement RPI GPIO port access from MyController.org directly
                                        Thank you! @davidbd
                                        • GertSandersG GertSanders
                                          J
                                          J
                                          jkandasa
                                          #48
                                          Thank you @GertSanders let me have a look. As MyController.org is designed with pure Java language I have to implement with some wrapper or with the help of pi4j module
