  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.5k Views 14 Watching
  • D
    d-smes
    @jkandasa Yep, error log full of the same sets of errors. Example of one error pair:
    2015-09-16 11:41:55,150 WARN [Thread-3] [org.mycontroller.standalone.db.dao.SensorDaoImpl:52] Sensor:[org.mycontroller.standalone.db.tables.Sensor@e7f65f[id=<null>,sensorId=0,type=<null>,messageType=38,name=<null>,updateTime=<null>,status=<null>,lastValue=<null>,unit=<null>,node=org.mycontroller.standalone.db.tables.Node@18dbb32[id=4,name=<null>,version=<null>,updateTime=<null>,type=<null>,mySensorsVersion=<null>,batteryLevel=<null>,eraseEEPROM=<null>,firmware=<null>]]], Sensser Id should be in the range of 1~254
    2015-09-16 11:41:55,150 ERROR [Thread-3] [org.mycontroller.standalone.mysensors.MessageMonitorThread:68] RawMessage[NodeId:4,ChildSensorId:0,MessageType:1,Ack:0,SubType:38,PayLoad:4.825] throws exception while processing!,
    java.lang.NullPointerException: null
    	at org.mycontroller.standalone.mysensors.ProcessRawMessage.recordData(ProcessRawMessage.java:480) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
    	at org.mycontroller.standalone.mysensors.ProcessRawMessage.setSubMessageTypeSelector(ProcessRawMessage.java:449) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
    	at org.mycontroller.standalone.mysensors.ProcessRawMessage.messageTypeSelector(ProcessRawMessage.java:91) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
    	at org.mycontroller.standalone.mysensors.MessageMonitorThread.processRawMessage(MessageMonitorThread.java:60) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
    	at org.mycontroller.standalone.mysensors.MessageMonitorThread.run(MessageMonitorThread.java:82) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
    	at java.lang.Thread.run(Unknown Source) [na:1.8.0_60]
    The clue appears to be "Sensser Id should be in the range of 1~254"
    Nodes with multiple sensors show e.g. sensors 1- 11 but not sensor 0.
    • J
      J
      jkandasa
      wrote on last edited by jkandasa
      #36
      @d-smes My bad it was a mistake, I understand wrongly like, we will not have sensor id 0, should have only from 1~254, now corrected and will allowed 0~254 id,
      you have to stop your mycontroller server and replace lib/mycontroller-standalone-0.0.2-alpha2-single.jar with the fix http://www.filedropper.com/mycontroller-standalone-002-alpha2-single
      • J
        J
        jkandasa
        MyController.org Released 0.0.2-alpha3 :thumbsup:
        For user documents visit MyController.org
        • D
          diggs
          Just wondering if it is possible to run two controllers side by side both looking at the same serial port?
          i.e. can I run Domoticz and MyController at the same time in serial mode with the one gateway or would it cause issues?
          • J
            J
            jkandasa
            @diggs for my knowledge we could not share same port directly for two applications. We may need to use some adapters for this operation. I do not know how much it is possible.
            • E
              E
              etrombly
              @diggs I was looking into doing the same thing. There are ways to duplicate a serial port using utilities like socat that should work. I was having issues with one side of the redirect disconnecting when there was no data to read. I was thinking of just writing up a quick python utility that would have the features I wanted. ser2net would work well, but it only redirects the port to the network, it doesn't do local redirection.
              • E
                E
                ericvdb
                @jkandasa Would it be possible to add a graph for the battery percentage?
                • J
                  J
                  jkandasa
                  @ericvdb Thank you for your interest with MyController.org. I have created a request for battery percentage. Kindly update your thoughts on this https://github.com/mycontroller-org/mycontroller/issues/14
                  How often node sends battery percentage?
                  • F
                    F
                    fleinze
                    That depends on your sketch. I update battery every hour, but only if there are changes.
                      shattered
                      wrote on last edited by shattered
                      #44
                      Thank you - This is what I have been looking for. I was getting ready to write my own which I did not have time for. It is simple displays the data that is needed and easy to debug. The other controllers I tried I spent more time debugging because of the bloat. I can not focus on my sensor development.
                      • D
                        davidbd
                        Nice ! Very clean GUI !
                        I installed this controller on RPI with serial gateway and it works like a charm with two TEMP sensors.
                        It will be good if you can use the RPI GPIO to connect directly to NRF24 RF module instead on adding the serial gateway ( see http://iot-playground.com ..)
                        I wish you good luck with this project.
                        J 1 Reply Last reply
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          Actually, you can add the NRF24 directly to the Raspberry and use it as a gateway at the same time:
                          http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                          • D davidbd
                            J
                            J
                            jkandasa
                            #47
                            Yes, I have plan to implement NRF24l01 directly. I have to learn more about how mysensors gateway is working. Also planing to implement RPI GPIO port access from MyController.org directly
                            Thank you! @davidbd
                            • GertSandersG GertSanders
                              J
                              J
                              jkandasa
                              #48
                              Thank you @GertSanders let me have a look. As MyController.org is designed with pure Java language I have to implement with some wrapper or with the help of pi4j module
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                @jkandasa
                                I used the Raspberry version of Mysensors gateway for software to set up a serial gateway. Then Inadded a symlink link with shorter name so domoticz could see it. If your software can detect the normal ttyMySensorGateway then no need for a symlink.
                                Hardware toconnect radio and raspberry is simple interconnect with GPIO. Same connections as with wire. I made a little board for it. Link to that is also somewhere on the forum.
                                  @jkandasa
                                  J
                                  J
                                  jkandasa
                                  @GertSanders said:
                                  @jkandasa
                                  @GertSanders This is nice, I guess no need to change anything in MyController software. Let me check this and update you. Thank you.
                                  • J
                                    J
                                    jkandasa
                                    @GertSanders @davidbd Just now I tested https://github.com/mysensors/Raspberry with MyController.org server it is working perfectly. Thank you very much! you guys saved hardware cost and added direct NRF24 support to MyController.org :smiley:
                                    I did all the steps as root user (running MyController.org server also as a root user). Kindly let me know if you face any issues.
                                    Install https://github.com/mysensors/Raspberry and connect NRF24L01+ as mentioned on the page.
                                    Now we have to point-out ttyMySensorsGateway port to MyController.org server via it is configuration file
                                    Stop your MyController server change a line,
                                    File Name: mycontroller/conf/mycontroller.properties
                                    mcc.serialport.name=/dev/ttyMySensorsGateway
                                    Start your MyController server. That is it :)
                                    D 2 Replies Last reply
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      link to my board:
                                      https://oshpark.com/shared_projects/aXLXBO3f
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                                        My setup described here
                                          J
                                          J
                                          jkandasa
