  3. Roller Shutter
Roller Shutter
87 Posts 23 Posters 71.3k Views 32 Watching
  • DwaltD
    DwaltD
    Dwalt
    wrote on last edited by Dwalt
    #24
    I have the ftdi header on the sensebender board mounted on the atmel chip side (opposite the radio) and have not had any problems with radio range or packet loss. My deployed sensebenders are all between 3 and 7 meters from gateway or repeater.
    • F
      F
      Fabien
      You can have no problem but sure metallic part modify the diagram antenna. Perhaps with real Nordic there's less problem but for new design it is better to avoid ground plane or tracks on all layers under the antenna.
        @tbowmo: ok. so in my case it is not a good idea to put 2 radio footprints as it will increase size. As I have already done the job, I will make 2 versions. easier.
        In the other hand, the mini pro version (a little bigger) I have already traced could handle both radio with some minor change.
        So, I have now all recommandation I need. So I am able to finish it and send to fabhouse for test. I will inform you when board and sketch all done.
        Thanks again to all.
        • Daniel OliveiraD
          Daniel OliveiraD
          Daniel Oliveira
          Hi @scalz
          A question, there is a reason to do not use an encoder instead of the acs712 and the stop buttons to know the position of the shutter?
          MySensors rules my home :)
            Hi.
            I am not sure what do you mean with "stop button" (end stops?) and encoder. I have made this board for multi purpose, not rollershutter only. And in dualrelay, I can know power consumption too.
            I need to update 3d view. But my schematics and pcb are my latest rev. I am waiting for my pcb (end of the month).
            Maybe there are other good ideas as I am not electronician. But I have learnt a lot at my job and thx to internet:smile:
              Hi.
              just to share :smile: as I have received some boards today. so here a screenshot for rollershutternode.
              It is not soldered yet, I just wanted to see if my hilink, relays and nrf footprints was ok. it's ok! but too bad I forgot to order varistor and fuses (fuse will be between the screw terminals, and varistor on right bottom corner...
              these boards was ordered at Seeed.
              • J
                J
                jemish
                can you please tell me that what type of roller shutter are use....
                where I can buy this roller shutter.
                  @jemish: I will test it on somfy rollershutter (220v motor). but the board can be used with 12-24-110v motors/load. and I need to finish the rollershutter sketch too and check everything.All will be ok in maybe... two weeks I hope.
                  • F
                    F
                    Fabien
                    It's exactly what I want. Dimension are fine (fit in wall european round european box). I can't wait 2 weeks :joy:
                    • F
                      F
                      Fabien
                      @scalz : what the news ? Did you test your board ? I will start a design without Hi-link (LNK306 Or SR086 instead) and triac and I would like to know if you can use current information from hal-effect sensor.
                        @Fabien: yes I have done some tests and worked on the sketch too.
                        So for rev 1.0, I have made a mistake on opamp of acs712. not big but a little embarrassing to fix onboard.
                        Good news is I have no stability problem (regarding relays, button interrupt, or smd nrf near buttons pinheader). I was afraid about that. so it's cool.
                        Rev 1.1 is finished (but not ordered) and I am working on documentation before release. it won't take long time I hope :wink:
                        In rev 1.1 :
                        • opamp for acs712 updated
                        • 0805 onboard led added (was missing but it can be useful!)
                        • 0805 CTN for temperature of the board (under hilink)
                        • better silkscreen
                        for your question about triac and acs712, I can't tell you. I am not sure, but don't see why it could not work. but if it is for rollershutter node control, I am not sure if triac is best option..
                        • F
                          F
                          Fabien
                          I don't think relay is a good option for 230VAC motors. On start current is very high and relay's life will be short. And second problem with SR086 for example I have only 60mA under 3.3V, It could be a problem for NRF+ATMEGA328+Relay command (transistor).
                          I prefer to chose triac like ACST8-8G (DPAK) wich is fine for controlling motor and very small.
                            #36
                            @Fabien:
                            cool. it could be interesting. I thought about triacs and making my own power supply too and for lots of reasons I choosed relays and hilink.
                            • I wanted something the most secure and galvanic isolated.. and for triac you would need an opto. then multiply by 2 for Up and Down. So for one rail, counting all components involved, footprint is near relay, maybe bigger.
                            • omron relays are small and not power eager. I don't enable two at same time for rollershutter motor.
                            • triac makes more emi. Add to this an homemade powersupply...I wanted to be sure for radio..
                            • I think fibaro rollershutter uses relays (two). If triacs was a good option I think they would have used it as they uses triac in others products. but I am note sure, I have none of these. I just looked at their docs.
                            Anyway, your way is interesting too! try and test I will follow your work for sure :wink:
                            • F
                              F
                              Fabien
                              @scalz : at this time, I 'm only explore different ways. I've got some HI-LINK but in your design i'm not sure it fit with an enclosure into a 67mm wall box.
                                yes I understand. I thought exactly about same problematic. my design is 47x48. I was hoping to make smaller too.
                                another cool idea could be to make custom wallbox...with touch sensor plate or gesture recognition.
                                DrJeffD 1 Reply Last reply
                                • scalzS scalz
                                  DrJeffD
                                  DrJeffD
                                  DrJeff
                                  @scalz
                                  I'm following this post closely I like the idea, I have some motors controlled via RF but I don't like the controllers or the reliability. I will see how to retrofit them with your controller after you have tested and did all the hard work! ;) I believe I can just Hijack the motor wires and use the relays and the boards for all the logic. I like what you have setup but I will have to see your sketch first.
                                  I have some old Hunter Douglass motorized shutters that use IR remote I hacked them with an reed relay on a node that acts as a push button. Just like pushing the button on the motor. Unfortunately the new shutters I got don't have a manual push button or I would do the same.
                                  • F
                                    F
                                    Fabien
                                    @scalz any news ? I just find this library (from @Marvin-Roger) : https://github.com/marvinroger/arduino-shutters
                                    After few days, I think you are using the right way with HI-LINK and Relay. It coud be better to user interlocking between relay becaus shutters doesn't like to have AC on 2 inputs simultaneously (and will be dead). This can be a problem. But you have to find relay with 2 poles.
                                    • DidiD
                                      DidiD
                                      Didi
                                      @scalz any news ?
                                        #42
                                        @Didi: sorry, I am very late on my projects. Busy at my daily job. some projects not presented yet; and those which I started here too..and actually I have some projects in teamworking with Charles from hallard.me...gloups! I don't sleep too much, tired, but it's ok :wink:
                                        So for this project, some changes that I have done recently (thx to @Fabien for his ideas too :wink: ):
                                        • bigger relays and interlocking between them : 1x10A NO and 1x10A NO-NC
                                        • tvs diode, transistors...replaced by MDC3105dual relay driver: smaller footprint
                                        • some reorganization : now I have enough place to make another board and replace nrf with rfm.
                                        These changes mean that it is not a pure dual relay anymore. Too bad for me as I wanted something dual relay+shutter. But I have still my previous dual relay design. So now I have two boards to update! First, rollershutter (I will try to upload my files tonight, I hope, not sure...) and dual relay board (same thing...).Did I say that I have not enough work :laughing: ??
                                        something important to know is this new rev is not tested, and boards not ordered yet. Of course, I have debbuged things, and it should work. I know someone who wants to order it but I have not given to him my files yet. Thanks to him, it is to participate to money and debug, as it costs money to dev...
                                        • Ivan ZI
                                          Ivan ZI
                                          Ivan Z
                                          http://www.sharp-world.com/products/device/lineup/data/pdf/datasheet/s102s02_e.pdf
