  3. What radio to use? NRF24L01+, RFM69, RFM73 ?
52 Posts 11 Posters 56.4k Views 9 Watching
    @fets said:
    H version stands for High power.
    C version is pin compatible with RFM12.
    RFM69 uses SPI so the connections are :
    Arduino RFM69
    10 <-------------------> NSS
    11 <-------------------> MOSI
    12 <-------------------> MISO
    13 <-------------------> SCK
    DI00 <-------------------> 2
    GND <-------------------> GND
    3.3V
    ANA : antenna
    NSS, MOSI and SCK are inputs so you need to adapt level if you use 5V arduino
    I have connected a RFM69HW to my arduino nano+rpi gateway and have connected a RFM69W+Mini Pro 3.3V to a soil sensor but nothing shows up in Domoticz. Do I have to do anything else? Do I need a external antenna? The two RFM's is only like 1m apart.
    fetsF
    fetsF
    fets
    I never tested without antenna. I used simple wire the length dependinf of your frequency?
    Did you look at your arduino serial outpout ?
    If there is nothing, it may that because RFM69 init failed
      Yes you should put an antenna on. It doesn't have a PCB trace antenna. A simple piece of wire, typically cut to 1/4 wavelength, will work fine.
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok, I have some thin insulated copper wire, will that work? And how long wire will I need for the 868mhz frequency?
        But just to be clear, do I need to alter the gateway or the sensor sketches in some way to have it use the rfm radio?
        • fetsF
          fetsF
          fets
          1/4 wavelength = (3 10^8 / (868 10^6)) / 4 =>about 8.64 cm
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Thanks, sorry for repeating the question but do I need to alter the code on gateway or sensors?
            • fetsF
              fetsF
              fets
              You only need to create a MyTransportRFM69 instead of MyTransportNRF24. This is the constructor : MyTransportRFM69 (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM);
              if you use a RFM99H, you have to set the 5th parameter (isRFMHW) to true.
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Sorry for being semi-retarded, but is this done in the gateway sketch? Sensor
                -sketch or both? Is there any documentation on this part as I am a complete beginner.
                • fetsF
                  fetsF
                  fets
                  both, here is the documentation
                  • FrancoisF
                    FrancoisF
                    Francois
                    wrote on last edited by Francois
                    #25
                    @Cliff-Karlsson You have to change the following setting in Myconfig.h for you radio
                    *  RFM69 Driver Defaults
                     #define RFM69_FREQUENCY   RF69_433MHZ
                    //#define RFM69_FREQUENCY   RF69_868MHZ
                    #define RFM69_ENCRYPTKEY  "sampleEncryptKey"
                    Then in MySensor.h you change the following:
                    ifndef MySensor_h
                    #define MySensor_h
                    #include "Version.h"   // Auto generated by bot
                    #include "MyConfig.h"
                    #include "MyHw.h"
                    #include "MyTransport.h"
                    //#include "MyTransportNRF24.h"
                    #include "MyTransportRFM69.h"
                    #include "MyParser.h"
                    #ifdef MY_SIGNING_FEATURE
                    #include "MySigning.h"
                    #include "MySigningNone.h"
                    #include "MyMessage.h"
                    #ifdef MY_OTA_FIRMWARE_FEATURE
                    #include "utility/SPIFlash.h"
                    #include <stddef.h>
                    #include <stdarg.h>```
                    // look for this lines and changes this
                    class MySensor
                      public:
                    	* Constructor
                    	* Creates a new instance of Sensor class.
                    	//MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
                    	MySensor(MyTransport &radio =*new MyTransportRFM69(), MyHw &hw=*new MyHwDriver()
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      Hmm. I can't get it to work. This is what I have done:
                      In Myconfig.H:
                      Everything was already set up like the example only 868Mhz was uncommented and that is the same as I got.
                      Mysensors.h:
                      Commented #include "MyTransportNRF24.h" as in the example.
                      Added "#include "MyTransportRFM69.h" as it was not present.
                      Under class Mysensor,
                      Commented "MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()"
                      Added "MySensor(MyTransport &radio =*new MyTransportRFM69(), MyHw &hw=*new MyHwDriver()"
                      In the Serial Gateway sketch:
                      Commented the line "#include <MyTransportNRF24.h>"
                      Commented the line "MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);"
                      Added the line "MyTransportRFM69 (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW=true, RF69_IRQ_NUM);
                      When trying to upload to my nano I get an error:
                      'transport' was not declared in this scope.
                      And this line is highlighted: MySensor gw(transport, hw /, signer/);
                      fetsF 1 Reply Last reply
                        In Myconfig.H:
                        Mysensors.h:
                        fetsF
                        fetsF
                        fets
                        @Cliff-Karlsson, sorry for my late answer.
                        you made a mistake on the line added in the serialgateway, it should be :
                        MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM) ;
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          Has anyone used the Raspberry Pi Gateway implementation with an Rf69? Does it work? On which pin does one connect the interrupt pin ?
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            wrote on last edited by Cliff Karlsson
                            #29
                            @fets said:
                            Personnaly I use 3 * 2 resistors (10k and 4.7k) for NS, MOSI and SCK rfm69hw inputs.
                            Ok, I am continuing with my neverending story :) I have gotten the sketches to complie and I have used a 8.6cm wire as antenna for both of them. But I still does not se any sensors in domoticz. I might have destroyed my radios as I might have accidently used 5 volts on them for a short while. I am trying to use some new radios this time.
                            First question: I have a RFM69HW on my gateway and a RFM69W on my sensor (both 868Mhz) They are compatible as I understand only that the H is more powerful?
                            Second question: If I am using a Nano I can just cut a cable in two and solder a 10k and a 4.7k in series in between them before connecting the NS, MOSI and SCK ? When checking online voltage divider calculators online and specify 5V in and 10k + 4,7k resistors it says that voltage out is 1.599v
                            NeverDieN fetsF 2 Replies Last reply
                              Assuming they are of the same frequency, then basically yes, though there is one small difference in the code to account for the RFM69HW having a PA, which MUST be turned on for it to transmit.
                                fetsF
                                fetsF
                                fets
                                @Cliff-Karlsson,
                                question 2 : I think you misplaced the connection to RFM69 :
                                Here is how to connect arduino and RFM69.
                                Is it what you did ? (I bet you switched 4.7k ans 10k )
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  I am still having some problems with getting any data from the RFM69.
                                  Do I need to define some pins to like in the NRF24L01 section in the Myconfig.h ?
                                  I have not defined any pins anywhere for the RFM69 or do I not need to do that?
                                  *  NRF24L01 Driver Defaults
                                  #define RF24_CE_PIN		   9
                                  #define RF24_CS_PIN		   10
                                  #define RF24_CHANNEL	   76
                                  //#define SOFTSPI
                                  #ifdef SOFTSPI
                                  #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!```
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    I even sent a mail to hek asking for help and he said that the only thing I needed to do was to add the line:
                                    MyTransportRFM69 transport;
                                    in the serial gateway sketch and "construct your mysensor class with" : MySensor gw(transport);
                                    I added those two lines in the serial gateway sketch and it complied and uploaded ok but as usual it does not work for me. Can someone give me the exact sketch for a serial gateway using the RFM69W radio and the dallas temperature sketch that is provided on the mysensors-build page modified for use with RFM69W? I would be forever grateful :)
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Still trying, can anyone tell me if this is correct: Nano-Levelshifter-RFM69W
                                        Shouldn't D2-> DI00 have level shifting as well?
                                        • TD22057T
                                          TD22057T
                                          TD22057
                                          That's IRQ so it should be an output from the radio to the arduino just like MISO right? I was under the impression that radio->arduino links didn't need to be shifted since they're digital connections and the arduino will read 3.3V as HIGH. I could be mistaken of course...
                                          @Cliff-Karlsson I'm going to start my RFM69 radio testing this weekend (finally) using ProMini 5V <-> level shifter <-> RFM69W so hopefully I can report back with something that works.
                                          Anytime you have trouble, you should start w/ the simplest case and build up to a real case. So:
                                          1. use a serial gateway. start it up w/ debug output and make sure that the radio initializes properly.
                                          2. use the MockMySensors sketch or take a simple sketch and modify it to send an increasing counter value (1,2,3...) every second. start that w/ debug print as well (run 2 arduino ide's so you can use 2 serial monitor windows). That will tell you if the radios are receiving each other properly. You can use this to test range as well my moving one of the radios to another location.
                                          3. create a simple arduino sketch that reads the sensor. it shouldn't have any mysensors code in it. just report the sensor values to the serial connection. make sure that works. This validates the sensor reading and wiring code.
                                          4. combine 2+3 so you're sending real data to the gateway == success!
                                          12.5k
