  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.1k Views 14 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    My CPU load hardly ever goes over 1%, and that is including a running Domoticz controller in parallel with the serial gateway.
    Gert
    • J jkandasa
      @davidbd said:
      @jkandasa
      I just install the PiGatewaySerial in RPI and run as a daemon but found CPU is almost 100% !
      2173 root 20 0 3740 1624 1416 R 98.8 0.4 2:17.91 PiGatewaySerial
      @davidbd I donot face any issue like you said.
      root@raspbx:~# ps -p 11415 -o %cpu,%mem,cmd
      %CPU %MEM CMD
       0.0  0.0 /usr/local/sbin/PiGatewaySerial -d
      I do not have much knowledge on PiGatewaySerial we have a discussion about this topic on http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection/39
      Some people already reported 100% cpu usage. Can you please check and post your query there?
      My RPI setup.
      root@raspbx:~# uname -a
      Linux raspbx 3.18.6-v7+ #753 SMP PREEMPT Sun Feb 8 14:53:56 GMT 2015 armv7l GNU/Linux
      root@raspbx:~# cat /etc/issue
      Raspbian GNU/Linux 8 \n \l
      root@raspbx:~# cat /etc/debian_version
      8.0
      RPI Model: Raspberry pi 2 Model B
      I ran everything as a root user.
      davidbd
      @jkandasa As reported by users ... the 100% cpu usage happens only if nothing connects to /dev/ttyMySensorsGateway
      I am OK now but maybe worth to check why as this is not good behaviour.
      • tbowmoT
        tbowmoT
        tbowmo
        #61
        Just finished setting up MyController, so it runs besides domoticz, and NodeRed. Looks fine so far, but haven't had that much time to delve into MyController specifics yet.
        Have set it up so that when ever I turn a light on / off in MyController, Domoticz also sees this (and of course the sensor network).
        Plan was to try and use MyController for OTA firmware updates, and keep track of firmware versions in my network.
        J 1 Reply Last reply
        • D
          diggs
          wrote on last edited by diggs
          #62
          For some reason cannot seem to get it running.
          Have installed the software and the server appears to start, but there is no web access and this is what I get when I check the log.
          Have I setup something incorrect
          Running on a PI
          Exception in thread "main" java.lang.UnsupportedClassVersionError: org/mycontroller/standalone/StartApp : Unsupported major.minor version 52.0
                  at java.lang.ClassLoader.defineClass1(Native Method)
                  at java.lang.ClassLoader.defineClass(ClassLoader.java:792)
                  at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
                  at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
                  at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
                  at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
                  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
                  at java.security.AccessController.doPrivileged(Native Method)
                  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
                  at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
                  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
                  at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
                  at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
          java version "1.7.0_40"
          Java(TM) SE Runtime Environment (build 1.7.0_40-b43)
          Java HotSpot(TM) Client VM (build 24.0-b56, mixed mode)
          • D diggs
            Running on a PI
            J
            J
            jkandasa
            wrote on last edited by jkandasa
            #63
            You should update your java version to 1.8 or later. For raspberry PI oracle java is recommended for MyController.
            http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html
            jdk-8u60-linux-arm32-vfp-hflt.tar.gz
            @diggs hope this link will help you to update your java: http://www.rpiblog.com/2014/03/installing-oracle-jdk-8-on-raspberry-pi.html
            D 1 Reply Last reply
            • tbowmoT tbowmo
              J
              J
              jkandasa
              @tbowmo Nice! you can give try for other features also which is available in MyController ;)
              Alarm, Timer, Forward Payload, UID, etc.,
              • J jkandasa
                diggs
                @jkandasa Thanks for that.
                The latest Java version has go me going as far as server access goes, but I am having issues opening the serial port it seems.
                I am trying to run in parallel with Domoticz, but I maybe having an issue trying to access the same port I am guess.
                Suggestions on how to get around that?
                2015-09-27 15:45:16,568 ERROR [main] [org.mycontroller.standalone.gateway.serialport.SerialPortPi4jImpl:68] Failed to load serial port,
                java.io.IOException: Unable to open the serial port/device. (Error #2)
                        at com.pi4j.jni.Serial.open(Native Method) ~[mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at com.pi4j.io.serial.impl.SerialImpl.open(SerialImpl.java:151) ~[mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at com.pi4j.io.serial.impl.SerialImpl.open(SerialImpl.java:242) ~[mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at org.mycontroller.standalone.gateway.serialport.SerialPortPi4jImpl.initialize(SerialPortPi4jImpl.java:61) [mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at org.mycontroller.standalone.gateway.serialport.SerialPortPi4jImpl.<init>(SerialPortPi4jImpl.java:40) [mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at org.mycontroller.standalone.StartApp.startServices(StartApp.java:217) [mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                        at org.mycontroller.standalone.StartApp.main(StartApp.java:78) [mycontroller-standalone-0.0.2-alpha4-single.jar:na]
                2015-09-27 15:45:16,646 INFO [main] [org.mycontroller.standalone.db.TimerUtils:144] Updated Time:[SunRise:Sun Sep 27 10:36:00 AEST 2015, SunSet:Sun Sep 27 22:41:00 AEST 2015], City:[latitude:11.2333, longit$
                [Sun Sep 27 15:45:21 AEST 2015] TJWS httpd 0.0.0.0 - [SSL: ServerSocket[addr=0.0.0.0/0.0.0.0,localport=8443]] is listening.
                • D diggs
                  J
                  J
                  jkandasa
                  I guess you cannot share same port for two different applications. We may go with some third party tools to share serial port across applications. But, I do not have any experience on it.
                  In this case to run MyController server, stop MyController server and Domoticz controller, then start MyController server, it will work.
                  • J jkandasa
                    diggs
                    @jkandasa Thanks
                    Have now done all that. Stopped the Domoticz server, started Mycontroller. I get the webpage up now, but still no nodes showing up and for some reason nothing is being written to my logs the past few hours at all.
                    What can I look at?
                    • D diggs
                      @jkandasa Thanks
                      What can I look at?
                      davidbd
                      @diggs
                      • stop the server
                      • connect to your serial port and see if you get any response from gateway ( minicom/miniterm etc ... )
                      • If above work , check your config for correct serial ports settings.
                      • If above doesnt work not check your serial gateway
                      • D davidbd
                        @diggs
                        • stop the server
                        diggs
                        @davidbd Thanks for the reply.
                        Yep, can connect to the port and see the node / gateway data in the line.
                        Still nothing though in the Mycontroller
                        All my settings seem pretty standard, so not sure what the issue would be or what to check next.
                        # MySensors Gateway settings
                        # Select Type of gateway will be used, Only one gateway will be used
                        # Types -> serial, ethernet, mqtt
                        mcc.ethernet.gateway.type=serial
                        # MySensors Serial port settings
                        # In this section select: Driver, port name and baud rate
                        # Available drivers -> [pi4j, jssc, jserialcomm, auto]
                        mcc.serialport.driver.type=auto
                        mcc.serialport.name=/dev/ttyACM0
                        mcc.serialport.baud.rate=115200
                        # MySensors Ethernet Gateway settings
                        # Update host name/ip and port number, Default: 192.168.178.6:5003
                        # Keep alive check frequency in seconds
                        mcc.ethernet.gateway.host=192.168.178.6
                        mcc.ethernet.gateway.port=5003
                        mcc.ethernet.gateway.keep.alive.frequency=60
                        # MySensors MQTT Gateway settings
                        # Update broker host name/ip and port number, Default: 192.168.178.6:1883
                        # Root topic name of broker
                        # Note: MQTT_TRANSLATE_TYPES will be not supported
                        # Disable MQTT_TRANSLATE_TYPES in your MQTT gateway
                        mcc.mqtt.gateway.broker.host=192.168.178.6
                        mcc.mqtt.gateway.broker.port=1883
                        mcc.mqtt.gateway.broker.root.topic=MyMQTT
                        # Database
                        # Where do you want to keep your database.
                        # It is highly recommended  to take a backup of this db on upgrade.
                        # Database: H2DB, location and name, example:/tmp/mycontroller
                        mcc.h2db.location=../conf/mycontroller
                        # Web files, will be located under ../www by default
                        # For web used angularjs
                        www.file.location=../www/
                        # Web Application server configuration
                        # bind.address - interface to bind. 0.0.0.0 - all available interfaces
                        # You can use either http or https, enable.https - https is enabled
                        # if https is enabled specify keystore file details
                        # It is highly recommended to use https also change default keystore file
                        bind.address=0.0.0.0
                        enable.https=true
                        http.port=8443
                        ssl.keystore.file=../conf/keystore.jks
                        ssl.keystore.password=password
                        ssl.keystore.type=JKS
                        #logger configuration - logback.xml
                        D J 2 Replies Last reply
                        • D diggs
                          # Database
                          enable.https=true
                          http.port=8443
                          davidbd
                          @diggs Have no idea but you can try to change your serial port driver
                          • D diggs
                            # Database
                            enable.https=true
                            http.port=8443
                            J
                            J
                            jkandasa
                            #71
                            @diggs just now I tested with RPI native port(/dev/ttyACM0 /dev/ttyAMA0) and gives some issue, let me find out the root cause,
                            • J jkandasa
                              diggs
                              @jkandasa OK thanks
                              At least I am not going crazy :)
                              • J jkandasa
                                J
                                J
                                jkandasa
                                @jkandasa said:
                                @diggs just now I tested with RPI native port(/dev/ttyACM0) and gives some issue, let me find out the root cause,
                                @diggs Just now I confirmed that issue is not with MyController server. I didn't disable default kernel console access of serial port. Hence I couldn't not access inbuilt RPI serial port from MyController server.
                                I followed this page to gain user access for RPI default serial port.
                                Now I can access default RPI serial port without any trouble. Hope you are also facing same issue.
                                • J jkandasa
                                  diggs
                                  @jkandasa Checked my settings and they were already set as per that article, so I don't believe that is the trouble I am facing. From the logs I sent you, anything else you think could be causing the issue. Was the port being opened OK in the system?
                                  • D diggs
                                    J
                                    J
                                    jkandasa
                                    @diggs Can you check on your RPI do you have /dev/ttyAMA0?
                                    pi@raspberrypi ~ $ ls -lh /dev/ttyA*
                                    crw-rw---T 1 root dialout 204, 64 Jan  1  1970 /dev/ttyAMA0
                                    If you have /dev/ttyAMA0 try MyController server with /dev/ttyAMA0. I hope it should work. Kindly post your RPI hardware and software details.
                                    • J jkandasa
                                      diggs
                                      @jkandasa I do have an AMA0, but it does not work on that one either. The gateway is definitely connected to ACM0. Which is the one it works on when I have Domoticz connected up.
                                      Something odd is happening with the PI USB side of things. Tried switching to another port but no luck there either.
                                      As a side, I installed on windows and it works fine, so I know the gateway is OK, but I really want it running on the PI at some point
                                      • D diggs
                                        J
                                        J
                                        jkandasa
                                        Are you using USB to ttl connector or native RPI tx/rx pin? can you post your RPI hardware and software details?
                                        • J jkandasa
                                          diggs
                                          @jkandasa as discussed on chat, but thought I would put the info her as well.
                                          Using one of the 4 USB ports on the PI.
                                          Versions
                                          Linux raspberrypi 4.1.6-v7+ #810 SMP PREEMPT Tue Aug 18 15:32:12 BST 2015 armv7l GNU/Linux
