  3. Domoticz as controller **and** a gateway for MySensor nodes running on a Raspberry Pi 2
47 Posts 14 Posters 32.7k Views 16 Watching
    MikeF
    Hello @GertSanders, for the time being I've got the gateway working with CE connected to pin 15, having carried out some 'surgery' to the board!
    I've found this code in PiGatewaySerial.cpp (line 198 onwards):
    /* create MySensors Gateway object */
    #ifdef __PI_BPLUS
    gw = new MyGateway(RPI_BPLUS_GPIO_J8_15, RPI_BPLUS_GPIO_J8_24, BCM2835_SPI_SPEED_8MHZ, 1);
    gw = new MyGateway(RPI_V2_GPIO_P1_22, BCM2835_SPI_CS0, BCM2835_SPI_SPEED_8MHZ, 1);
    Is this the 'offending' code?
    • GertSandersG
      GertSandersG
      GertSanders
      Yes, as the rpi2 is not recognised properly the code compiles for rpib+.
      I changed the code so that both rpi b+ as rpi2 have the same: use pin 22
      • GertSandersG
        GertSandersG
        GertSanders
        You will need the code as here above, then no need for surgery
        • GertSandersG
          GertSandersG
          GertSanders
          Had some time to log into my Raspberry 2 today, and indeed I adapted the code I used for the PiGatewaySerial because a RPI2 is not recognised properly.
          So here is what I used as source-file:
          I'm not sure where the correction should be made so that the RPI2 is recognised properly (instead of being recognised a s a raspi B+)
            MikeF
            All now working OK - many thanks!
            • GertSandersG
              GertSandersG
              GertSanders
              I will need to document this. In the original post I followed to compile the gateway for rpi, this was also mentioned.
              I would prefer that the code is corrected in the right place, because I feel the RPI2 should be recognised properly.
              Anyway, happy to know there is a +1 user with a raspberry 2 and direct connected NRF24.
                MikeF
                That's the code change I made (makes the 'if' redundant).
                I've also changed the tty name (to /dev/ttyUSB40 - which is what I've declared to Domoticz) in this file and in Makefile.
                BTW: Very impressed with OSH Park - got the PCBs here in UK (from US) 13 days after ordering!
                • GertSandersG
                  GertSandersG
                  GertSanders
                  #24
                  This was the fourth board I ordered from OSHPark. For boards with ENIG finish, they are cheap. And the quality is indeed excellent. I have ordered a fifth design from them (should be ready end next week) and at the same time I sent my files to DirtyPCB. We will see what that gives quality wise. On this forum someone mentioned Shenzen2u and they are eaven cheaper then DirtyPCB. So my next design will also be ordered from those guys.
                  Now it's time to enjoy a local brew :-)
                  • TD22057T
                    TD22057T
                    TD22057
                    @GertSanders Check out http://pcbshopper.com/, there are places slightly cheaper than DirtyPCB and places that will do runs of 5 boards instead of 10 for the same price per board. http://www.elecrow.com/ looks really good (5 boards for $15 delivered) but I haven't ordered from them yet so I can't comment on quality (other reviews of them say it's fine though).
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      I would rather pay 8.90 USD for 10 boards, then 15 USD for 5 boards delivered. http://www.shenzhen2u.com does the thing for me.
                      • Sander StolkS
                        Sander StolkS
                        Sander Stolk
                        @GertSanders Did you have a shopping part list available? I've ordered your board at OSHPark and I've got the Caps in stock but not the blue thingy and the dupont blocks.
                        Could you put me in the right directorion where to shop those two parts?
                        • Sander StolkS
                          Sander StolkS
                          Sander Stolk
                          Nevermind the dupont blocks. I've found those!
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            @Sander-Stolk The blue thingy is a ceramic 100nF capacitor, the two others are electrolytic capacitors of 100uF and 10uF respectively.
                            • Sander StolkS
                              Sander StolkS
                              Sander Stolk
                              Thanks alot!
                              • rmtuckerR
                                rmtuckerR
                                rmtucker
                                wrote on last edited by rmtucker
                                #31
                                Anyone got a spare pcb i can purchase in the UK ?
                                Seems a waste ordering a batch.
                                An SD image would be good too??
                                C 1 Reply Last reply
                                • Fat FlyF
                                  Fat FlyF
                                  Fat Fly
                                  What i select from drop down menu? Mysensors gateway USB ?
                                  • Fat FlyF Fat Fly
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    yes, follow these instructions:
                                    http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway
                                    • Tore André RosanderT
                                      Tore André Rosander
                                      Is there any pros/cons for using the nrf directly on the RPi instead of a NodeMCU?
                                      Right now i use NodeMCU (esp) with nrf radio as gateway, but i want to reduce the nuber of units around my house so connecting directly to the RPi would be better as long as there is no negative sides to it.
                                      • Tore André RosanderT Tore André Rosander
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @Tore-André-Rosander
                                        For me there are no downsides. I use the raspberry as both gateway (with the NRF mounted) and as Domoticz controller. It is part of my home network and I can reach my Domoticz from the internet. So far I have 13 sensor nodes running and communicating with the raspberry.
                                        • rmtuckerR rmtucker
                                          C
                                          C
                                          chickey
                                          @rmtucker I was thinking the same, don't need a whole batch. Anyone got a spare board, happy to pop some cash your way via a paypal gift.
