  3. Domoticz as controller **and** a gateway for MySensor nodes running on a Raspberry Pi 2
47 Posts 14 Posters 32.7k Views 16 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    #24
    This was the fourth board I ordered from OSHPark. For boards with ENIG finish, they are cheap. And the quality is indeed excellent. I have ordered a fifth design from them (should be ready end next week) and at the same time I sent my files to DirtyPCB. We will see what that gives quality wise. On this forum someone mentioned Shenzen2u and they are eaven cheaper then DirtyPCB. So my next design will also be ordered from those guys.
    Now it's time to enjoy a local brew :-)
    • TD22057T
      TD22057T
      TD22057
      @GertSanders Check out http://pcbshopper.com/, there are places slightly cheaper than DirtyPCB and places that will do runs of 5 boards instead of 10 for the same price per board. http://www.elecrow.com/ looks really good (5 boards for $15 delivered) but I haven't ordered from them yet so I can't comment on quality (other reviews of them say it's fine though).
      • GertSandersG
        GertSandersG
        GertSanders
        I would rather pay 8.90 USD for 10 boards, then 15 USD for 5 boards delivered. http://www.shenzhen2u.com does the thing for me.
        • Sander StolkS
          Sander StolkS
          Sander Stolk
          @GertSanders Did you have a shopping part list available? I've ordered your board at OSHPark and I've got the Caps in stock but not the blue thingy and the dupont blocks.
          Could you put me in the right directorion where to shop those two parts?
          • Sander StolkS
            Sander StolkS
            Sander Stolk
            Nevermind the dupont blocks. I've found those!
            • GertSandersG
              GertSandersG
              GertSanders
              @Sander-Stolk The blue thingy is a ceramic 100nF capacitor, the two others are electrolytic capacitors of 100uF and 10uF respectively.
              • Sander StolkS
                Sander StolkS
                Sander Stolk
                Thanks alot!
                • rmtuckerR
                  rmtuckerR
                  rmtucker
                  wrote on last edited by rmtucker
                  #31
                  Anyone got a spare pcb i can purchase in the UK ?
                  Seems a waste ordering a batch.
                  An SD image would be good too??
                  C 1 Reply Last reply
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    What i select from drop down menu? Mysensors gateway USB ?
                    • Fat FlyF Fat Fly
                      GertSandersG
                      GertSandersG
                      GertSanders
                      yes, follow these instructions:
                      http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway
                      • Tore André RosanderT
                        Tore André Rosander
                        Is there any pros/cons for using the nrf directly on the RPi instead of a NodeMCU?
                        Right now i use NodeMCU (esp) with nrf radio as gateway, but i want to reduce the nuber of units around my house so connecting directly to the RPi would be better as long as there is no negative sides to it.
                        • Tore André RosanderT Tore André Rosander
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @Tore-André-Rosander
                          For me there are no downsides. I use the raspberry as both gateway (with the NRF mounted) and as Domoticz controller. It is part of my home network and I can reach my Domoticz from the internet. So far I have 13 sensor nodes running and communicating with the raspberry.
                          • rmtuckerR rmtucker
                            C
                            C
                            chickey
                            @rmtucker I was thinking the same, don't need a whole batch. Anyone got a spare board, happy to pop some cash your way via a paypal gift.
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              I distributed my two other boards to friends locally. If you make the boards at OSH Park you get three boards (for a cost of 2.20 USD - shipping included).
                              https://oshpark.com/shared_projects/aXLXBO3f
                              • DwaltD
                                DwaltD
                                Dwalt
                                wrote on last edited by Dwalt
                                #38
                                I have the two spares from my order. If anyone wants one, send me a private chat message with your postal address. I am in the US, so it could take a few extra days to arrive if you are unfortunate enough to live on the wrong side of the pond.
                                • GertSandersG GertSanders
                                  C
                                  C
                                  chickey
                                  @GertSanders Thanks for the heads up. I'd incorrectly assumed that it was going to be something like $10 plus shipping. At $2.20 it's nothing so ordered a few just for testing. Got carried away though and ordered a few 8266 breakout boards too :-)
                                  Col
                                  • SeanMarshS
                                    SeanMarshS
                                    SeanMarsh
                                    I"m troubled. I know this will make me sound like a total newbie, but that's ok. From someone that is new to the form, it seems like you magically made the NRF work while it is physically attached to the RPi. I'm not finding any directions on how you made it work. I did find an old link that said that the directions on there will only work with 1.5X or below. Please show me the light.
                                    • Fat FlyF
                                      Fat FlyF
                                      Fat Fly
                                      Yes. I read too. NRF working directly with mysenosrs 1.5x. 2.0 not supported today.
                                      • Iraklis KourtisI
                                        Iraklis KourtisI
                                        Iraklis Kourtis
                                        Hi Gert,
                                        Nice project! I am new to MySensors and Domoticz. Could you please briefly explain how to add the device to Domoticz. I have successfully done the steps from mfalkvidd's guide, but I am not sure how proceed in Domoticz. Any advise would be appreciated..
                                        Best ,
                                        IK<
                                        • Fat FlyF
                                          Fat FlyF
                                          Fat Fly
                                          If you sensors working ok than you need to go domoticz hardware-> devices. Marked with green arrow is new node. You need to press to green arrow and....... you see what you want.
                                          Sorry my english. Maybe you understand. :)
