  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Just a hint, itead studio is starting a sale with 10% off on all imall items.. So maybe it's time to buy some Christmas presents for the inner geek :)
    • A
      akbooer
      Oh no! Lousy timing, I just bought some...
      ... in fact, they arrived today.
      Speaking of which, whilst I got them to run the default sketch, do I actually need a programmer to do anything different, or can this be done OTA (from a Mac) ?
      • tbowmoT
        tbowmoT
        tbowmo
        @akbooer
        The default sketch doesn't support OTA, as it wasn't available in the stable branch at the time of launch
        • 5546dug5
          5546dug5
          5546dug
          @tbowmo Good sales but did not see the Sensebender too bad .
          • tbowmoT
            tbowmoT
            tbowmo
            @akbooer
            It's here http://www.itead.cc/mysensors-micro.html
            • epierreE
              epierreE
              epierre
              #281
              @hek I've soldered a second unit to compare, same error, I flashed back the sensebender version from the examples and on both I am stuck here: "Sensebender Micro FW 1.2radio init fail"
              Gateway is 1.5 BTW, one radio is from itead the other not.
              z-wave - Vera -> Domoticz
              • SparkmanS Sparkman
                @epierre Can you confirm the settings you used in the IDE to program it? Are you sure there are no solder bridges where you soldered the radio or socket for the radio? Have you tried powering it with a couple of AA batteries after you uploaded the sketch?
                Al
                epierreE
                epierreE
                epierre
                1.6.5 version
                same behavior on two units
                not yet but why should that change anything ?
                  mvader
                  • A
                    akbooer
                    Just tried out my first Sensebender...
                    soldered pins and battery power...
                    turn on...
                    led flashes once...
                    start inclusion...
                    3 devices...
                    Vera restarts (actually, it's openLuup running on an Arduino Yún)...
                    there they are...
                    and updating every minute!
                    Thanks so much to all who made this level of sophistication so easy!! (Z-wave was never this simple!)
                    Whilst I need a couple of temp/humidity sensors, I also need to reflash one as a 4-switch sensor. Can I do this with an Arduino Uno configured with the ArduinoISP sketch as described here ?
                    https://www.arduino.cc/en/Tutorial/ArduinoISP
                    Any advice or useful pointers? Thanks.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @epierre
                      What do you use as supply voltage for the thing? What is the output from testmode?
                      Did you add a capacitor on the radio module? How did you mount them together? (picture?)
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @akbooer
                        Should be doable with an arduino as isp. Another option is to use the serial upload.
                        • J
                          J
                          jovo
                          I am a noob in coding so I need some advice for tuning the sensebender.ino
                          current observed problems:
                          1. sensor values transmitted every minutes
                          2. battery level info seems wrong
                          I am running the default senseblender.ino.
                          on 1) What I understood in this forum, it should transmit the temp. values only every 30min (or direct when change is >.05). However, I see them arriving in my controller (Domoticz) every minute. What should I change to have it send every 30min?
                          on 2) I observe in Domoticz that the battery levels reported (in the Devices section) are inaccurate. For example: one sensebender with 3.2v measured power reports 80, where I would expect round 100 (this one has new batteries). Other sensebenders with still 2.63v report 53. How to calibrate the battery measurement?
                          I have been searching this forum, but was unable to find the answer.
                          Alternatively, a pointer to a wiki on sensebender.ino that has this explained would work as well.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @jovo
                            The firmware that the sensebender is shipped with is pretty old, compared to the one that's available in the current master branch of mysensors library. A lot have been done to do better transmit control (like, limiting number of transmits etc.)
                            About the battery voltage, the sensebender is measuring against an internal vref, which isn't that accurate. I can't remember the specifics at the moment, but it's hidden somewhere in the datasheet. The measurement method has a lot of inaccuracy, but on the other hand it saves external components and power.
                            I didn't focus on it, but one could perhaps make some kind of calibration routine, use a known supply voltage and do some internal calculations and store an offset in eeprom.
                            • F
                              F
                              Fabien
                              @jovo for battery mesurement it's correct 100% is for 3.3V and 0% for 1.9 V (BOD fuse setting). so for 2.63 you have 52,14 %
                              • J jovo
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @jovo As @Fabien wrote, the default code puts 3.3 V as 100%. Look for the percentage calculation. You will see that it's basically (vcc - 1900)/14. This makes sense if using a step-up converter where you get 3.3 V. But if connecting directly to two AAs, 100% should be around 3 V. So just replace 14 with 11 in the calculation.
                                • J
                                  J
                                  jovo
                                  wrote on last edited by jovo
                                  #291
                                  Thanks for the comments and suggestion.
                                  Now I have installed the master branch code from the mys. library.
                                  Unfortunately no change. Still very frequent updates (under the same circumstances).
                                  I sense it has something to do with :
                                  bool tx = force;
                                  but I am not quite sure where to change it in.
                                  I will continue my search.....
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @jovo
                                    There is a small error in the sketch, that falsely converts floats to ints. Look at line 243, it's dividing by 100:
                                    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100);
                                    This should be changed to 100.0 instead. This way the calculation is returning as a float.
                                    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                                    • 5546dug5
                                      5546dug5
                                      5546dug
                                      @fabian how is the box working out were there any mods and are the stl files ready yet?
                                      F 1 Reply Last reply
                                      • J
                                        J
                                        jovo
                                        #294
                                        ok, it seems the aggregated upload is solved with the change from Thomas.
                                        Now I modify the "14" in "11" as suggested by martin. I have 105% now, but that could be right because I measure 3.1V from my 2 fresh AA's
                                        The only 'new issue' I discovered is that one sensor actually stops being received updates from due low power. The measured voltage on the batteries is still 2.1V and the battery indicator was at 23%.
                                        Could it be that I have bad fake radios that don't operate lower then 2.1V? (since there is no other external components added to my setup, I suspect only the radios).
                                        • 5546dug5 5546dug
                                          F
                                          F
                                          Fabien
                                          wrote on last edited by Fabien
                                          #295
                                          Sorry, my 3D printer is out of service, I'm waiting for chinese parts ... I will post correct STL files in 1 or 2 weeks.
                                          alexsh1A 1 Reply Last reply
