  3. [SOLVED] Node with 2 Buttons, both debounced, always having the same status
3 Posts 2 Posters 2.1k Views 2 Watching
  • AndurilA
    AndurilA
    Anduril
    wrote on last edited by Anduril
    Hey,
    I tried to programm a nano to have 2 relays and 2 buttons for controlling them. But every time, I change the status of one of the switches, the other is changed, too. Maybe it is something about the debouncing, but afaik you can create 2 instances of debounce.
    I minimized the sketch to avoid problems with further code, but still the same:
    // digitial I/O pin 3 (BUTTON_PIN below) and GND.
    #define CHILD_ID 4
    #define BUTTON_PIN  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID2 5
    #define BUTTON2_PIN  5  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValue=-1;
    int oldValue2=-1;
    MyMessage msg2(CHILD_ID2,V_LIGHT);
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      pinMode(BUTTON2_PIN,INPUT);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      gw.present(CHILD_ID2, S_LIGHT);
      debouncer.update();
      debouncer2.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         oldValue = value;
      if (value2 != oldValue2) {
         gw.send(msg2.set(value2==HIGH ? 1 : 0));
         oldValue2 = value2;
    I would be greatful for any kind of hint.
    • AndurilA
      AndurilA
      Anduril
      OK I solved the problem: there was a litte solder brigde between PIN 4 and 5. I didn't checked that carefully before because I bought it with already soldered headers.
        Ok ;) Looked at the code earlier but couldn't find anything wrong.
