  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 139.1k Views 27 Watching
  • S shabba
    @LeoDesigner Sorry for not being clear. I was looking to connect my Arduino Mega (has about a dozen sensors and relays connected to it) to my existing RPi2 sensors serial gateway (using a UNO). I was hoping I could use a second USB/Serial port on the RPi2 to receive messages from the Mega.
    L
    L
    LeoDesigner
    @shabba Take a look to https://github.com/MajenkoLibraries/ICSC/tree/master/debian
    It may be a starting point for you. You can adopt this part of the ICSC library to your RPi2 setup.
    • L
      L
      LeoDesigner
      wrote on last edited by LeoDesigner
      Finally I am received my RS485 modules.
      Here is the working example of gateway with two nodes:
      https://youtu.be/4Ls95PKLwng
        @LeoDesigner
        To test this I ordered a few of these..
        http://www.ebay.com/itm/381374599127?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        Hope they are the correct model.
        L 1 Reply Last reply
          @LeoDesigner
          L
          L
          LeoDesigner
          @hek
          My modules are from http://www.aliexpress.com/item/FREE-SHIPPING-5PCS-LOT-MAX485-module-RS485-module-TTL-turn-RS-485-module-MCU-development-accessories/1718665649.html
          They are the same as yours - based on MAX485.
          However, it is possible to run a simple TTL signal level bus on a short distances.
          (https://github.com/leodesigner/mysensors-serial-transport/blob/master/sch.png)
          hekH 1 Reply Last reply
          • L LeoDesigner
            @hek
            @LeoDesigner
            I've incorporated a slimmed down of the RS485 transport layer in this branch (soon to be merged into development):
            https://github.com/mysensors/Arduino/tree/serial-transport/libraries/MySensors
            But I've still haven't received my RS485 modules... Do you have time to run a small test?
            Gateway:
            https://github.com/mysensors/Arduino/tree/serial-transport/libraries/MySensors/examples/GatewaySerialRS485
            And a test-motion sensor sketch:
            https://github.com/mysensors/Arduino/tree/serial-transport/libraries/MySensors/examples/MotionSensorRS485
            But you could use any example just replacing #define MY_RADIO_RF24 with #define MY_RS485
            I've used the AltSerial library for RS485 communication so we can cope with dual serial ports on the serial gateway. This library requires using pins documented in sketch.
              @LeoDesigner
              Gateway:
              L
              L
              LeoDesigner
              @hek
              My example boxes are installed right now on the site and doing a daily job :)
              It will take time to build a new one. I may try a breadboard, but I am still busy to finish additional improvements to mysensors.org project. (I will share them later - it's will be interesting too - I hope :) )
              Actually, it's easy to test RS485 transport without a RS485 converters - just use a simple schematics I have been talking before.
              Also, you may want to look to this: https://github.com/MajenkoLibraries/ICSC/pulls
              It's untested support for SoftwareSerial option for library.
              With AltSerial we will be forced to use only a documented pins.
              Anyway - I am glad to contribute a bit to great mysensors community.
                Yes, I know. But AltSerial can handle higher speeds. I preferred that over the SoftwareSerial flexibility regarding pin selection. Hope I did the right choice ;)
                  L
                  L
                  LeoDesigner
                  @hek
                  Speed is one of the reasons why I have decided to use hardware serial. :)
                  But we should be flexible and universal as much as we can. I had been thinking also to add support for over the wire firmware update. As you have done with wireless.
                    wrote on last edited by hek
                    With a new bootloader? Using external flash+DualOptiBoot it should work already.
                      L
                      L
                      LeoDesigner
                      @hek
                      Sure - but it can be possible done with standard bootloader - we just have to emulate standard Arduino sketch upload process on the gateway side. But I am not sure if it's possible to do with half duplex protocol. Just an idea.
                        Interesting idea. Looking forward hearing about your results.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @LeoDesigner
                          If using the standard bootloader, wouldn't it break the FW update if one of the other nodes on the bus starts to transmit?
                          • tbowmoT tbowmo
                            @LeoDesigner
                            L
                            L
                            LeoDesigner
                            @tbowmo
                            Node will listen RS485 bus before it will try to transmit anything (just like Ethernet).
                            So other nodes will behave yourself :)
                            But we have another difficulty: standard bootloader know nothing about TX/RX (dePin) management. So, we need to modify it to be able correctly emulate Arduino upload process. Maybe a simple schematics with diode will work in that case.
                            I am still busy with other improvements.
                            • T
                              TimO
                              @hek I've tested your code and can't get it working yet.
                              I've installed the gateway and a DHT22 sketch on two nanos and connected them directly via D8 and D9.
                              // Enable RS485 transport layer
                              #define MY_RS485
                              // Set RS485 baud rate to use
                              #define CHILD_ID_HUM 0
                              #define CHILD_ID_TEMP 1
                              #define RS485_DE_PIN 4
                              unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
                              // Initialize motion message
                              DHT dht;
                              boolean metric = true;
                              void presentation()  {
                                sendSketchInfo("Humidity Sensor", "1.0");
                                present(CHILD_ID_HUM, S_HUM);
                                if (isnan(temperature)) {
                                } else  {
                                  Serial.print("T: ");
                                if (isnan(humidity)) {
                                    Serial.print("H: ");
                                    Serial.println(humidity);
                                sleep(SLEEP_TIME);
                              The sketch is working fine according to serial output. But nothing is seen on the gateway.
                              So, to find out, where there is a problem, I connected my Programmer (mySmartUSB MK3) to D8/D9 of the sensor and I'm able to see that there is output but the chars are not readable so I tried different baudrates than 9600. That didn' help. What I can say is, that the output is generated every 3 seconds, so the ports are right.
                              To make sure I'm not doing something wrong with the programmer, I connected it to D0/D1 and switched baudrate to 115200 and it shows the serial output as expected.
                              Any idea where to look next?
                              • T
                                TimO
                                So, I've tried to further invest the problem and there is something wrong with _dev.write() in transportSend(). It is too much C-Kungfu for me but there is something wrong with the conversion of data.
                                • _dev.write("bla") looks good in terminal
                                • _dev.write(to) throws trash in the terminal
                                • Serial.println(to) looks good in terminal
                                Here is the output of the soft-serial:
                                #���X��z
                                               �Humidity Sensor��X
                                     �1.0�X��b�X��b�X
        ��*�������X
        ��*�gfB�X
        ��*�������X
                                    ��*�gfB�X
                                Another thing:
                                The management of the DE-Pin is missing right?
                                  to is a uint_t...so I guess it could generate trash in the terminal when showing the low ASCII values. Guess you'd have to use some other program to view the bytes sent.
                                  Yes, de-pin was stripped away. Would it be useful in your setup?
                                  (thankful for your help out testing it... I need some more time before I can setup a test rig)
                                  • T
                                    TimO
                                    Holy crap ...
                                    It was too obvious. :-(
                                    Gateway can't work with this code:
                                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
                                    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                    @hek: Your code works!
                                    The de-pin is set to high if a node wants to send something, otherwise it is set to ground.
                                    I'll try to add that code.
                                    • T TimO
                                      Holy crap ...
                                      #27
                                      @TimO
                                      :blush: I Sorry.. should have changed those pin assignments of course... I'll push an update ASAP.
                                        @TimO
                                        L
                                        L
                                        LeoDesigner
                                        @hek
                                        I am wondering why did you remove the code responsible for dePin management ?
                                        It's not possible to use MAX485 boards without tx/rx management.
                                        • T
                                          TimO
                                          @LeoDesigner : yeah, you're right, that is needed.
                                          But there seems to be another problem, I can't get the current development code to work. I've simply interconnected two Nanos at D8/D9. The gateway and the motion example come up fine according to serial output and the motion sensor definiatly sends something via AltSerial but the gateway doesn't seem to recognize it.
                                          A simple test, where I pipe the input on hardware serial of one nano to AltSerial on the second nano and from there to hardware serial works just fine, so hardware and AltSerial is working.
                                          Sender:
                                          #include <AltSoftSerial.h>
                                          AltSoftSerial altSerial;
                                            Serial.println("Demo begins");
                                            altSerial.begin(115200);
                                            char c;
                                            if (Serial.available()) {
                                              c = Serial.read();
                                              altSerial.print(c);
                                          Receiver:
                                            char c;
                                            if (altSerial.available()) {
                                              c = altSerial.read();
                                              Serial.print(c);
                                          antiA 1 Reply Last reply
