  3. Domoticz
  4. How do I add the soil-moisture sensor to domoticz?
22 Posts 9 Posters 21.8k Views 4 Watching
  • L
    L
    LastSamurai
    wrote on last edited by LastSamurai
    @hek Where is the question to your answer hek? ;) Can't see it here.
    But corrosion do to the current in the sensor might be the reason for my dead sensor. Any ideas how to avoid that on that kind of cheap Soil Moisture Sensors from the project page?
    PS I guess powering the sensor over a pin of the arduino (or some kind of transistor) would make it possible to disable the sensor when not measuring. That might help?!
    • L LastSamurai
      Basic information are also on the project page. I was using the same kind of sensor (cheap one from ebay). I seemed to work very well for about one week but then suddenly it started to send back only one value.... when I took the sensor out of the soil I saw that the sensor (at least one leg) had mold on it. Has anyone seen such a problem? Any ideas how to prevent that?
      Tried to answer this...
      • L
        L
        LastSamurai
        Great idea hek, I think that is the problem. But the sketch you posted uses a different sensor, doesn't it? There is something about:
         * Connection:
         *  D6, D7: alternative powering to avoid sensor degradation
         * A0, A1: alternative resistance mesuring
        And a link to different sensor. The cheap kind that I am using only has two connections for power and an analog and digital pin. I don't see how you could be alternating power here...
        But perhaps it helps if the sensor isn't constantly powered on but only for measurements.
        Does anyone else have a solution for this?
          Yes, @epierre should clarify what sensors used and how it should be connected in the sketch.
          If a new sensors type is used we should probably keep the old example and create a new one for this.
          epierreE 1 Reply Last reply
          • TheoLT
            TheoLT
            TheoL
            Maybe a bit late. But the soil moisture sketch was the first one I brought into production by soldering it on a PCB. I added it to Domoticz as a motion sensor, not as a switch. And it's working great. If the motion sensor is telling that there's motion, it means the plants aren't thirsty. If there's no motion than the plants need some water. I even let Domoticz send a message to my mobile phone when the plants are thirsty ;-). I keep forgetting to give my plants water on a regular basis, so this sensor is really helpful.
            • sundberg84S
              sundberg84S
              Hi @TheoL
              Motion sensor and Switch (and also the soil moisture sensor) work the same way in Domoticz. Its either 1 (ON/Motion/Wet) or 0 (Off/No motion/dry).
                epierreE
                epierreE
                epierre
                Well it is here in the sketch: " Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N414"
                but it was better in the post: http://forum.mysensors.org/topic/514/soil-humidity-and-temperature-sensor-watermark-davis-granular-matrix-sensor/2
                and yes it works with two connectors this way !
                @hek I'm not in the list ;-) https://github.com/mysensors/Arduino/graphs/contributors
                z-wave - Vera -> Domoticz
                L 1 Reply Last reply
                  I can see you in the list :)
                    epierreE
                    epierreE
                    epierre
                    visibly I searched myself at the bottom, but I had many bugs as it seems ;-)
                    • epierreE epierre
                      L
                      L
                      LastSamurai
                      So this works with the sensor I linked above (= the one in the picture above)? I though changing the voltage way would destroy the sensor..
                      My goal is to have the sensor in soil for years though. Even if I turn it off while not measuring it might break I guess.
                      • L
                        L
                        LastSamurai
                        Anyone? Because I really want to use the sensor but I don't really get the posts her ;)
                          @epierre did an update on the sketch which reverses polarity to help avoiding corrosion.
                          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/SoilMoistSensor/SoilMoistSensor.ino
                          Per Arne BotnP
                          Per Arne BotnP
                          Per Arne Botn
                          wrote on last edited by Per Arne Botn
                          #21
                          And this sketch is supposed to be connected as this? :)
                          Edit: correct link is http://vanderleevineyard.com/1/post/2012/08/-the-vinduino-project-3-make-a-low-cost-soil-moisture-sensor-reader.html
                          • mfalkviddM
                            Not quite. There are no diodes and no resistors in the solution I use.
