  3. Implementing Controller(arduino yun) In Gateway
16 Posts 5 Posters 6.3k Views 3 Watching
    You mean a standalone arduino sketch running in your greenhouse? No radio communication or anything else MySensors related?
    Hmm.. sorry, can't help you with that one. Guess you need to learn the Arduino basics and start playing around.
    A 1 Reply Last reply
      azlan
      @hek You got it wrong, of course I want sensors and actuators to be controlled wirelessly, if not why would I want to use MySensors Library, but to write controller on raspberry pi without having mysensors library for Rasp.Pi is too complicated for me, so I decided to do it on arduino since you have the library for arduino, that is all.
      J 1 Reply Last reply
      • A azlan
        J
        J
        jkandasa
        @azlan If you elaborate what exactly you are going to do with your greenhouse project, many people will help you here to choose controller for you. I hope definitely a controller will fulfill your requirement.
          You don't necessarily need to put the code in the actual gateway if you don't want. You can put it on any node your radio network and let the greenhouse and controller communicate by sending messages between each-other.
          Just set static id's like I do below.
          (development branch example code)
          In your controller sketch
          #define MY_NODE_ID 47
          #define MY_RADIO_RFM69
            // Handle incoming messages from your "greenhouse"
          And in your "greenhouse" sketch
          #define MY_NODE_ID 11
          MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP)
              msgHum.setDestination(47);
              msgTemp.setDestination(47);
              send(msgHum.set(87));
              send(msgTemp.set(32));
              wait(10000); // Wait 10 seconds
            // Handle incoming messages from your controller
          azlan
          @hek Hi There,
          Thank you for your help,
          I am trying to understand this code. On controller side you define the sensor with first line, but there will be multiple sensors so how do you determine on "void receive()" method that from which sensor we receive the data?
            You'll have to inspect the MyMessage. Many of the actuator examples does this.
              azlan
              @hek So you do not want to help no more...
                msg.sender contains node id of sender
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMessage.h#L280-L292
                  azlan
                  @hek Hi There,
                  Does MySensors library has any similarities with RF24.h library, for example for receiving data could this"radio.read(&text, sizeof(text));" be used.
                  • P
                    P
                    phill
                    hey guys, so i want to make a controller for my green house could anyone help me? from what i need to build what platform should i use and a wiring schematic to fit such a design? plz help
                    • P phill
                      azlan
                      @phill No one is helping here.............
