  3. Implementing Controller(arduino yun) In Gateway
16 Posts 5 Posters 6.3k Views 3 Watching
    Maybe you could start with explaining exactly what you want to do? :)
    I presumed you wanted to control something in your green house via radio link from some other place... the "green-house-controller" without the need of setting up a gateway to the outside world (I.e full fledged controller software).
    A 1 Reply Last reply
      azlan
      @hek No, the problem is there is no controller on this site that I can use, so I have to write code for my controller, simple one just to fit my needs, but the problem is "mysensors library is not used on the raspberry pi" so controller code will have to run on arduino.
        You mean a standalone arduino sketch running in your greenhouse? No radio communication or anything else MySensors related?
        Hmm.. sorry, can't help you with that one. Guess you need to learn the Arduino basics and start playing around.
          azlan
          @hek You got it wrong, of course I want sensors and actuators to be controlled wirelessly, if not why would I want to use MySensors Library, but to write controller on raspberry pi without having mysensors library for Rasp.Pi is too complicated for me, so I decided to do it on arduino since you have the library for arduino, that is all.
          J 1 Reply Last reply
          • A azlan
            J
            J
            jkandasa
            @azlan If you elaborate what exactly you are going to do with your greenhouse project, many people will help you here to choose controller for you. I hope definitely a controller will fulfill your requirement.
              You don't necessarily need to put the code in the actual gateway if you don't want. You can put it on any node your radio network and let the greenhouse and controller communicate by sending messages between each-other.
              Just set static id's like I do below.
              (development branch example code)
              In your controller sketch
              #define MY_NODE_ID 47
              #define MY_RADIO_RFM69
                // Handle incoming messages from your "greenhouse"
              And in your "greenhouse" sketch
              #define MY_NODE_ID 11
              MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP)
                  msgHum.setDestination(47);
                  msgTemp.setDestination(47);
                  send(msgHum.set(87));
                  send(msgTemp.set(32));
                  wait(10000); // Wait 10 seconds
                // Handle incoming messages from your controller
              azlan
              @hek Hi There,
              Thank you for your help,
              I am trying to understand this code. On controller side you define the sensor with first line, but there will be multiple sensors so how do you determine on "void receive()" method that from which sensor we receive the data?
                You'll have to inspect the MyMessage. Many of the actuator examples does this.
                  azlan
                  @hek So you do not want to help no more...
                    msg.sender contains node id of sender
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMessage.h#L280-L292
                      azlan
                      @hek Hi There,
                      Does MySensors library has any similarities with RF24.h library, for example for receiving data could this"radio.read(&text, sizeof(text));" be used.
                      • P
                        P
                        phill
                        hey guys, so i want to make a controller for my green house could anyone help me? from what i need to build what platform should i use and a wiring schematic to fit such a design? plz help
                        • P phill
                          azlan
                          @phill No one is helping here.............
