  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.3k Views 39 Watching
    miguelingles
    @Yveaux said:
    y but I
    it,s works !!!!! you have to do is remove the DIO0 while Bots and put it quickly . If not removed DIO0 not start.
    • P
      P
      Pseudomizer
      I have done EXTENSIVE testing and I got it working now but I don't understand why.
      It seems like my MyConfig.h is broken which is the one which I copied over from your development package. I used one of my MyConfig.h files and the module boot was successfull and it did not crash anymore. It is stable and fully integrated into Vera with sensors now.
      I also tested the different data rates. I tested 250KBPS and 1MBPS and both work fine as long as I configure the gateway and the sensor clients with the same data rate. If I use different data rates between client and gateway, the gateway does NOT crash but the sensor clients simply don't connect.
      Now I have a working MyConfig.h and a broken MyConfig.h. Here is the WORKING MyConfig.h file.
      #ifndef MyConfig_h
      #define MyConfig_h
      #include <stdint.h>
      //#define DEBUG
      //#define MY_DEBUG_VERBOSE
      // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
      #define ENABLED_SERIAL
      #define BAUD_RATE 115200
      #define MY_OTA_FLASH_SS 8
      // Flash jdecid
      *  Information LEDs blinking
      // disabled in the gateway.
      // #define WITH_LEDS_BLINKING
      // off when blinking
      // The RX LED default pin
      #define DEFAULT_RX_LED_PIN 6
      // The TX LED default pin
      #define DEFAULT_TX_LED_PIN 5
      // The Error LED default pin
      #define DEFAULT_ERR_LED_PIN 4
      *  Message Signing Settings
      //#define MY_SIGNING_FEATURE
      #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
      *  NRF24L01 Driver Defaults
      #define RF24_CE_PIN		   9
      #define RF24_CS_PIN		   10
      #define RF24_CHANNEL	   76
      //#define RF24_DATARATE 	   RF24_1MBPS
      //#define SOFTSPI
      #ifdef SOFTSPI
      *  RFM69 Driver Defaults
      And here is the NON WORKING MyConfig.h file.
      #ifndef MyConfig_h
      #define MyConfig_h
      #include <stdint.h>
      #define DEBUG
      // Enable MY_DEBUG_VERBOSE flag for verbose debug prints. Requires DEBUG to be enabled.
      // Flash jdecid
      //#define SOFTSPI
      #ifdef SOFTSPI
      I don't understand why the second one makes the module reboot constantly. However, I am happy now that it is working but I wanted to share my experience and maybe it can help others to troubleshoot this and understand why this was happening as I am sure I will not be the only one having that issue in the future.
      I do appreciate all the help so far and I wouldn't have been able to solve it without your help Yveaux. THANK YOU!!!
        You cannot mix MyConfig.h between branches.
        In the development brach all MySensors related defines has the prefix "MY_".
        • Frank HerrmannF
          Frank HerrmannF
          Frank Herrmann
          Hi, if it possible to show a sketch with an ESP8266 WIFI => MQTT gateway? I figure out, that the received sensor data will automatic publish to my MQTT Server running on my Raspi. Then i can install this pice of wonderfull work in every room from my house :)
            I created a simple ESP-MQTT sketch a while ago. I've only done some simple tests using it. Feedback appreciated.
            Frank HerrmannF FotoFieberF V 3 Replies Last reply
              Frank HerrmannF
              Frank HerrmannF
              Frank Herrmann
              wrote on last edited by Frank Herrmann
              #135
              @hek Very nice! the code are magic :) Very nice solution, i'll test this next days.
              #include <ESP8266WiFi.h>
                FotoFieberF
                FotoFieberF
                FotoFieber
                Testing the above sket from the development branch with a new sensbender micro I get:
                mygateway/255/255/3/0/3 (null) on MQTT
                This is an id request. I answer this request with
                mosquitto_pub -h ds -t "mygateway/255/255/3/0/4" -m 8
                which should set the ID 8 on the sensbender micro in my undestanding. I can see the message in the serial terminal on the ESP-8266 but the message doesn't arrive at the sensbender micro.
                Is my message to set the id correct?
                  Yes, the response message looks ok. But I must confess that I haven't verified the MQTT gateway much yet. Probably something I've missed (=bug).
                  Do you have the possibility to to see where the message ends up or being thrown away (debug-print-debugging is awesome, yes I know...) in the MQTT gateway?
                  Or wait a few days until I've had time to look at it.
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    There seems to be a bug in incomingMQTT:
                    replace
                    with
                    for (str = strtok_r(topic, "/", &p); str && i <= 5;
                    or it will never send a message.
                    There seems to be another problem:
                    0;0;3;0;9;send: 0-0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0,st=fail:8
                    Why is the payload in st=fail?
                    The messages sent to MQTT seem to make a merry go round and come back.... :)
                      The payload (8) seems correct. Gateway just never received any ack from node... which is fine for broadcast messages (to node 255) such as this.
                      Ok, like you suspected earlier? So we need to subscribe to something else than we publish to then...
                        FotoFieberF
                        FotoFieberF
                        FotoFieber
                        @hek
                        Loaded the ethernet ESP-8266 gateway and entered with telnet:
                        255;255;3;0;4;8
                        It is working as it should. Now I have assigned the id 8.
                        Tried to solve the merry go round but it didn't help. Now I let the stage to the pros.. :)
                        • F
                          F
                          Fabien
                          Do you think we can use this board with MySensors (with NRF24 or RFM69) ?
                          https://github.com/hallard/NodeMCU-Gateway
                            Mike Cayouette
                            If I want to use the GatewayESP8266MQTTClient sketch located in the development branch do I also need to use the mysensors libraries in that branch?
                            Thank you,
                            Mike
                            hekH 1 Reply Last reply
                            • M Mike Cayouette
                              Thank you,
                              Mike
                              @Mike-Cayouette
                              Yes
                                V
                                V
                                vickey
                                wrote on last edited by vickey
                                #144
                                @hek Thanks for the code. I have few questions in my mind. Firstly do I just have to upload this ESP8266MQTTClient.ino sketch on esp8266 12-E model? or does it needs anything to add in the sketch except SSID and password? I want to use ESP-8266-E and NRF24L01+ as gateway for openhab. If it is possible then, do I have to adopt the same procedure for configuring openhab as ethernet gateway? Secondly, Can I make two gateways using this sketch, is this possible? As I want to add sensors which are 500 meters away at my farmhouse.
                                • J
                                  J
                                  joshmosh
                                  This is a bit off topic, but hopefully not too off ;-)
                                  What about a port of the MySensors library /API to ESP8266 ? Instead of two "boards" (Arduino nano plus nRF24L01+) only one would be required. For simple sensors an ESP-01 would be sufficient - about the size of a nRF24, but with much more muscle than an Arduino. Of course, running off a battery probably would not work because of the high power consumption of the ESP.
                                  Or am I asking for something which is already possible ?
                                  Josh
                                  • V vickey
                                    Yes
                                    Entering SSID/PW should be enough.
                                    I'm not an expert on openhab.. so I'll let someone else answer this one. But the ESP variant behaves exactly like the W5100 version.
                                    If openhab supports multiple gateways, sure. But you might wanna run sensor networks on different frequencies or changing MY_RF24_BASE_RADIO_ID.
                                    @joshmosh
                                    Yes, the code runs directly on the ESP8266.
                                    • J
                                      J
                                      joshmosh
                                      @hek
                                      that's good news, thank you ! Now the most expensive part will be the power supply ;-)
                                      Josh
                                      • V
                                        V
                                        vickey
                                        #148
                                        @hek I have installed GatewayESP8266MQTTClient sketch on my ESP-8266 12E.
                                        Here is sketch I am using
                                        #include <EEPROM.h>
                                        #define MY_BAUD_RATE 9600
                                        // Set this nodes topic prefix
                                        #define MY_MQTT_TOPIC_PREFIX "mygateway"
                                        // Set MQTT client id
                                        //#define MY_MQTT_USER "admin"
                                        //#define MY_MQTT_PASSWORD "MyPassword"
                                        // Set WIFI SSID and password
                                        #define MY_ESP8266_SSID "Ahmed"
                                        #define MY_ESP8266_PASSWORD "MyPassword"
                                        #define MY_IP_ADDRESS 192,168,0,31
                                        // MQTT broker ip address.
                                        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 30
                                        #define MY_PORT 1883
                                        // Flash leds on rx/tx/err
                                        // Set blinking period
                                        // Enable inclusion mode
                                        Here is the debug
                                        0;0;3;0;9;Starting...
                                        scandone
                                        f 0, ....scandone
                                        state: 0 -> 2 (b0)
                                        .state: 2 -> 3 (0)
                                        state: 3 -> 5 (10)
                                        add 0
                                        aid 1
                                        cnt
                                        connected with Ahmed, channel 1
                                        ip:192.168.0.31,mask:255.255.255.0,gw:192.168.0.1
                                        .IP: 192.168.0.31
                                        And it keeps attempinng for MQTT connection.
                                        I have installed Domoticz on my RPi and added a hardware Mysensors Gateway with LAN interface with remote address i.e. 192.168.0.31 in my case and port 1883. Here is Domoticz log
                                        2015-10-17 12:50:26.675  Hardware Monitor: Fetching data (System sensors)
                                        2015-10-17 12:50:31.590  Error: MySensors: Error: Connection refused
                                        2015-10-17 12:50:31.590  Error: TCP: Error: Connection refused
                                        I don't have mosquitto installed in my Rpi.
                                        May someone suggest me any solution.
                                        • J
                                          J
                                          joshmosh
                                          @hek
                                          Good morning. I had wired up my nodemcu a nRF24L01+, loaded the gateway sketch and bingo ! Zero problems, works like charm. Thanks a lot !!!
                                          I am using Domoticz as controller, with a serial USB gateway to connect my various sensors. In the serial console of the ESP8266 gateway I see that the messages of my sensors show up, but since I have not yet announced the gateway to Domoticz, there seems to be no interference. If I connect the ESP8266 gateway to a controller (in my case Domoticz), I guess that it will be required that the nodes need to choose the respective gateway (by using the parentNodeId) with which they like to communicate ? Currently, I am using parentNodeId = AUTO in all my nodes.
                                          I will do some testing to get an idea of the reach of my WiFi compared to the reach of my serial USB gateway (I have a nRF24L01+ with external antanna and booster in my gateway, so I am able to "see" a portable node even outside my house and 50 m away.
                                          Again, thank you for this very useful extension of MySensors. I think I have not yet an estimate of the full potential of it
                                          Josh
