  3. relay with delay feature
5 Posts 3 Posters 3.4k Views 3 Watching
  • P
    P
    punter9
    Hi everyone I have been reading and am struggling getting a grip with this situation.
    I have
    3 Binary switches - need to be read 2-4 times daily
    2 Soil Moisture sensors - need to be read 4 times daily
    1 relay - needs to work on demand
    The issue I have right now is that my 3 binary switches and 2 moisture sensors are susceptible to electrolysis and the current read settings erode my terminals in less than 2 weeks.
    I would like to put a wait/delay/whatever command to only cue those reading to happen 2-4 times a day, this should really extend the life of my cheap sensors!
    What would be the best way to implement this in my code? Currently I have zero gateway sleep commands/delay/etc.
    Below is the void loop and incoming message commands
      debouncer.update();
      // Get the update value
      int value1 = debouncer.read();
      int value2 = debouncer.read();
      int value3 = debouncer.read();
      int soilValue1 = analogRead(ANALOG_INPUT_SOIL_SENSOR1);
      int soilValue2 = analogRead(ANALOG_INPUT_SOIL_SENSOR2);
      value1 = digitalRead(BUTTON_PIN1);
      value2 = digitalRead(BUTTON_PIN2);
      value3 = digitalRead(BUTTON_PIN3);
      if (value1 != oldValue1) {
         // Send in the new value
         gw.send(msg1.set(value1==HIGH ? 1 : 0));
         oldValue1 = value1;
      if (value2 != oldValue2) {
         gw.send(msg2.set(value2==HIGH ? 1 : 0));
         oldValue2 = value2;
      if (value3 != oldValue3) {
         gw.send(msg3.set(value3==HIGH ? 1 : 0));
         oldValue3 = value3;
      if (soilValue1 != lastSoilValue1) {
        Serial.println(soilValue1);
        gw.send(msg4.set(constrain(map(soilValue1, 1023, 250, 0, 100),0,100)));
        lastSoilValue1 = soilValue1;
      if (soilValue2 != lastSoilValue2) {
        Serial.println(soilValue2);
        gw.send(msg5.set(constrain(map(soilValue2, 1023, 250, 0, 100),0,100)));
        lastSoilValue2 = soilValue2;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    • TheoLT
      TheoLT
      TheoL
      I'm currently at work and cannot look to deep into your sketch. But a debouncer can only be used on one pin. You have to declare a debouncer for each digital input you want to debounce. And read the input like in the following snippet.
      debouncer2.update();
      debouncer3.update();
      int value3 = debouncer3.update();
      You can also delete these lines. Because you're reading the values from the debouncer:
      • P
        P
        punter9
        yea this code is messy, I am reworking it today. Any insight on the best way to delay those commands without impacting the relay?
        • TheoLT
          TheoLT
          TheoL
          I use something like this
          unsigned long nextEvent;
            nextEvent = millis() + ( 5 *  60 + 1000); // 5 hours
            if ( nextEvent <= millis() ) {
              // do reading
            gw.wait( 500 ); // or whatever you want.
          But that's just the algorithm
          • P punter9
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @punter9
            I would implement some way of knowing time passed. Either by sleeping or waiting for a set time. Then each time the loop runs after wake-up, or similar, increment a counter. Define a variable setting the number the counter should have reached when you want to read the sensors. Then implement a function per sensor or sensor type. Call the functions in a conditional statement, checking the counter, in the main loop.
            Check the sensebender micro sketch for example of a counter. That sketch sleeps the sensebender for 1 min in the end of each loop, default settting, so that way you know that at least 1 min has passed for each loop run. Each loop run it increments the counter, so +1 for the counter means +1 min, more or less.
            edit
            @TheoL beat me to it, with code example, even. =)
