  3. [n00b]]Ethernet GW - without NF24
31 Posts 4 Posters 18.4k Views 3 Watching
    Just did a quick test calling sendSketchInfo in the gateway and it compiles fine for me.
    • B
      B
      brix7be
      hum, strange.
      I continue to search a solution.
      I'll give you a feed back ;-).
      • B
        B
        brix7be
        It doesn't work.
        But i found the code of Bram81 http://forum.mysensors.org/topic/1591/how-to-add-a-sensor-to-the-serial-gateway/22
        and I can compile it well.
        And it calls the gw.sendSketchInfo("Soil_Moist_Sensor_grb", "1.15");
        Do you have another tip?
          remove "gw." from the call.
          • B
            B
            brix7be
            You are right, it blocks when i call sendSketchInfo directly (without to be an attribute of gw) !?!
            • B
              B
              brix7be
              wrote on last edited by brix7be
              Here is the merged code
              Thanks for the advices
              // BELOW the gateway W5100 sketch
              //#define MY_RADIO_NRF24
              //#define MY_RADIO_RFM69 // I DONT WANT TO USE THE RADIO MODULE
              #define MY_GATEWAY_W5100
              //#define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
              //#if !defined(MY_W5100_SPI_EN)
              //  #define MY_SOFTSPI
              //  #define MY_SOFT_SPI_SCK_PIN 14
              //  #define MY_SOFT_SPI_MISO_PIN 16
              //  #define MY_SOFT_SPI_MOSI_PIN 15
              //#endif
              //#define MY_RF24_CE_PIN 5
              //#define MY_RF24_CS_PIN 6
              // Enable to UDP
              //#define MY_USE_UDP
              //#define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
              //#define MY_PORT 5003
              #define IP_PORT 5003        // The port you want to open
              IPAddress myIp (192, 168, 1, 100);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
              //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
              byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
              // a R/W server on the port
              EthernetServer server = EthernetServer(IP_PORT);
              // handle to open connection
              EthernetClient client = EthernetClient();
              // Flash leds on rx/tx/err
              //#define MY_LEDS_BLINKING_FEATURE
              // Set blinking period
              // Enable inclusion mode
              //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
              #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
              #include <Ethernet.h>
              //Below the Dallas temp sketch
              #include <OneWire.h>
              int numSensors=0;
              boolean receivedConfig = false;
              boolean metric = true;
              MyMessage msg(0,V_TEMP);
              char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
              int inputPos = 0;
              bool sentReady = false;
              void output(const char *fmt, ... ) {
                 va_list args;
                 va_start (args, fmt );
                 va_end (args);
                 Serial.print(serialBuffer);
                 server.write(serialBuffer);
                // ////Prepare the ethernet connection
                Ethernet.begin(mac, myIp);
                sensors.begin();
                   present(i, S_TEMP);
                sleep(conversionTime);
                  float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  #if COMPARE_TEMP == 1
                sleep(SLEEP_TIME);
                Looks like you added your own stuff..
                Should simply be
                #define MY_IP_ADDRESS 192, 168, 1, 100 // If this is disabled, DHCP is used to retrieve address
                And what the following doing here?
                And you include <SPI.h> and <MySensor.h> twice.
                • B
                  B
                  brix7be
                  to be honnest, i don't know ...
                  • B
                    B
                    brix7be
                    With the #define MY_IP_ADDRESS i can't compile the projet.
                    With the arduino command it works now, i can ping it on 192.168.1.100.
                    But still nothing in domoticz.
                    Am I on the right way?
                    thanks again :-)
                    // Enable to UDP
                    byte ip[] = { 192, 168, 1, 100 };
                    byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
                    int numSensors=0;
                      Ethernet.begin(mac , ip);
                      wait(1000);
                      sensors.begin();
                         present(i, S_TEMP);
                      sleep(SLEEP_TIME);
                      I don't understand.. why do you declare ip and mac like that? It most surely isn't picked up by the library. You're probably just getting an ip from your DHCP server.
                      What compile error do you get when using the defines?
                      • B
                        B
                        brix7be
                        i've changed as before and it won't compile.
                        The error is:
                        no matching function for call to 'EthernetClass::begin(int, int, int, int, int, int, int, int, int, int)'
                        No it takes the ip I put on the code before, cause the ping respond at this one.
                        Thks
                        // Enable to UDP
                        //byte ip[] = { 192, 168, 1, 100 };
                        //byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
                        int numSensors=0;
                          Ethernet.begin(MY_MAC_ADDRESS , MY_IP_ADDRESS);
                          wait(1000);
                          sensors.begin();
                             present(i, S_TEMP);
                          sleep(SLEEP_TIME);
                        • B
                          B
                          brix7be
                          The final goal for me is the build ethernet sensor(s) (2 or 3 one each arduino board) connected to domoticz by lan gw.
                          • B
                            B
                            brix7be
                            Is there anyone who have done a sketch to connect sensor directly on an ethernet gateway ?
                            Iam searching a working exemple or a working draft to see the process to build my own code.
                            Thank everyone for your advices.
                            • B
                              B
                              brix7be
                              #23
                              Hi Hek, Everyone,
                              I've clean the approximative sketch I've made before to simply try to see the value of a DS18b20 sensor trough a serial gw in domoticz.
                              So i've placed the merged code below to have your advices.
                              In domoticz's log i can see the declaration of the gw but neither the dallas sensor!?
                              Does someone could check my sketch please?
                              To be sure that the arduino see the dallas, i've tested a sketch wich send the value to the serial terminal (it works properly :-).
                              Thank you in advance for your help.
                              Have a nice sunday all. (clouday in belgium today ;-)).
                              // Enable serial gateway
                              #define MY_GATEWAY_SERIAL
                              int numSensors=0;
                                sensors.begin();
                                   present(i, S_TEMP);
                                sleep(SLEEP_TIME);
                              To be complete, there is the domoticz log.
                              2015-10-25 10:44:40.157 MySensors: Using serial port: COM3
                              2015-10-25 10:44:41.892 MySensors: Gateway Ready...
                              2015-10-25 10:44:41.892 MySensors: Node: 0, Sketch Name: Temperature Sensor
                              2015-10-25 10:44:41.946 MySensors: Node: 0, Sketch Version: 1.1
                              • B
                                B
                                brix7be
                                No idea?
                                  Sensors attached to gateway (node id=0) is a new feature.
                                  Might be Domoticz filtering these type of messages perhaps?
                                  @GizMoCuz might know if this is the case.
                                  • A
                                    afick
                                    I have created ethernet gateway :) with 2 sensors :) (DHT11, and door/windows sensor) all data are send to domoticz without problem.But when i adds "przekaznik" - one channel relay - i can't send/receive data about this relay. Can anyone check why ?
                                    sorry for mess in code
                                    #define MY_SOFTSPI
                                    // Enable to UDP
                                    #define MY_IP_ADDRESS 192,168,0,250   // If this is disabled, DHCP is used to retrieve address
                                    //Przekaznik
                                    #define MY_REPEATER_FEATURE
                                    #define RELAY_1  22  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    #include <DHT.h>   //dodany czujnik
                                    //czujnik temp i wilgotnosci
                                    #define CHILD_ID_HUM 0
                                    #define CHILD_ID_TEMP 1
                                    #define DOOR_ID1 4
                                    #define DOOR_ID1_PIN A0
                                    unsigned long SLEEP_TIME = 300; // Sleep time between reads (in milliseconds)
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    MyMessage msgDOOR_ID1(DOOR_ID1, V_TRIPPED);
                                    int old_DOOR_ID1_STATE = -1;
                                      //temp + hum
                                      //  kontaktron DOOR_ID1
                                      pinMode(DOOR_ID1_PIN, INPUT);
                                      //  //przekaznik
                                      //    // Then set relay pins in output mode
                                          pinMode(pin, OUTPUT);
                                      //    // Set relay to last known state (using eeprom storage)
                                      //temp + hum
                                      sendSketchInfo("Humidity", "1.0");
                                      present(CHILD_ID_HUM, S_HUM);
                                      present(DOOR_ID1, S_DOOR);
                                      //przekaznik
                                      sendSketchInfo("Relay", "1.0");
                                      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                                        present(sensor, S_LIGHT);
                                        Serial.print("Petla presentation");
                                      //temp + hum
                                      if (isnan(temperature)) {
                                        lastTemp = temperature;
                                        if (!metric) {
                                        Serial.print("T: ");
                                      if (isnan(humidity)) {
                                        lastHum = humidity;
                                        Serial.print("H: ");
                                        Serial.println(humidity);
                                      int DOOR_ID1_STATE = analogRead(DOOR_ID1_PIN);
                                      Serial.print("Analog= ");
                                      Serial.println(DOOR_ID1_STATE);
                                      Serial.println(old_DOOR_ID1_STATE);
                                      if (DOOR_ID1_STATE == 0) {
                                        DOOR_ID1_STATE = 0;
                                        send(msgDOOR_ID1.set(DOOR_ID1_STATE));
                                        old_DOOR_ID1_STATE = DOOR_ID1_STATE;
                                        Serial.print("drzwi_1=");
                                        DOOR_ID1_STATE = 1;
                                        Serial.print("drzwi_2=");
                                        // Change relay state
                                        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                                        // Store state in eeprom
                                      Just did some verification of message receiving in gateway on the ESP8266 sent from my shell (using netcat). Messages is showing up in receive() just fine here.
                                      Are you sending to node 0 from Domoticz? What does the log say in the gateway?
                                      • A
                                        afick
                                        wrote on last edited by afick
                                        #28
                                        Nothing special
                                        0;0;3;0;9;Starting...
                                        IP: 192.168.0.250
                                        Domoticz log
                                         2015-11-09 23:09:50.588 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:09:53.599 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:09:56.614 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:09:56.620 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:00.632 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:00.680 (GW) Lighting 2 (Security Sensor)
                                        2015-11-09 23:10:03.706 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:07.718 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:12.730 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:17.745 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:21.762 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:22.770 (GW) Lighting 2 (Security Sensor)
                                        2015-11-09 23:10:27.791 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:31.805 (GW) Temp + Humidity (TempHum)
                                        2015-11-09 23:10:32.812 (GW) Temp + Humidity (TempHum)
                                        I'm receiving only this kind of information.
                                        How can i send "0" from domoticz to GW ?
                                          Your have messed up the presentation of your S_LIGHT devices in the loop. They start with id 1 in the loop. But that id has already been used by CHILD_ID_TEMP.
                                          12.5k
