  3. Will the Arduino mini 3.3v give enough stable power for nRF ?
4 Posts 3 Posters 2.2k Views 2 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    Hello all,
    As mentioned in topic, I want to know if the 3.3v version will give enough and stable power for the nrf ?
    Also what is the totoal maximum power consumption which the mini can support if I want also to power up transistors or TRIACs ?
    Thank you.
    • rvendrameR
      rvendrameR
      rvendrame
      @ahmedadelhosni , for a definitive answer you must check what kind of regulator your board has, as well as how much each component of your circuit will consume.
      The official pro-mini uses an MIC5205 voltage regulator that can deliver maximum of 150mA.
      Most clones uses a cheaper regulator (such as the 100mA LP2981 that I found in my pro-minis).
      The official nRF24l01 radio consumes about 15mA while transmitting/receiving. You have to add on top of it the arduino itself, as well as any other components that you are powering up.
      And to be on safe side I would not use more than 60-70% of nominal regulator's output.
      Hope it helps...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • rvendrameR rvendrame
        Hope it helps...
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @rvendrame Great. That's so clear.
        Thank you.
        • L
          L
          LastSamurai
          @rvendrame Does the mysensors library use high power modes on the nrf? As far as I remember these can use much more power.
