  3. motion and relay
motion and relay
12 Posts 3 Posters 6.2k Views 3 Watching
  • D
    Dalhoj
    Hey maybe you can modify this sketch:
    http://forum.mysensors.org/topic/902/relay-motion-multisensor
    • D
      dias
      I have modified the code, I have no error message but:
      the relay remains on position but n not appear in domoticz
      in the logs they have the same name
      dth11 the works
      #include <SimpleTimer.h>
      #define CHILD_ID_HUM 1
      #define CHILD_ID_TEMP 2
      #define CHILD_ID_MOTION 3
      #define CHILD_ID_RELAY 4
      #define RELAY  3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define MOTION_SENSOR_DIGITAL_PIN 5
      #define MOTION_SENSOR_DIGITAL_PIN2 6
      #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
      unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
      DHT dht;
      SimpleTimer timer;
      float lastTemp;
      float lastHum;
      boolean lastTripped;
      boolean lastTripped2;
      boolean metric = true;
      MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
        gw.sendSketchInfo("HumTempRelayMotion", "1.0");
        // REGISTER all sensors to gw (they will be created as child devices)
        gw.present(CHILD_ID_MOTION, S_MOTION);
        gw.present(CHILD_ID_RELAY, V_LIGHT);
        pinMode(RELAY, OUTPUT);
        digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
        //Serial.begin(9600);
        timer.setInterval(30000, getMeasure);
        timer.run();
        boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
        if (tripped != lastTripped) {
          lastTripped = tripped;
          Serial.print("M: ");
          Serial.println(tripped);
          gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        boolean tripped2 = digitalRead(MOTION_SENSOR_DIGITAL_PIN2) == HIGH;   //
        if (tripped2 != lastTripped2) {
          lastTripped2 = tripped2;
          Serial.print("M2: ");
          Serial.println(tripped2);
          gw.send(msg.set(tripped2?"1":"0"));  // Send tripped value to gw   //
        if (message.type==V_LIGHT) {
           // Change relay state
           digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
           // Store state in eeprom
      void getMeasure() {
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
      Insert Code Here
      TheoLT 1 Reply Last reply
      • D dias
        dth11 the works
        DHT dht;
        SimpleTimer timer;
        float lastTemp;
        float lastHum;
          timer.run();
        void getMeasure() {
            if (!metric) {
              lastHum = humidity;
        Insert Code Here
        TheoLT
        TheoLT
        TheoL
        wrote on last edited by TheoL
        @dias You're presenting the relay incorrect.
        this line in the setup
        needs to be
        gw.present(CHILD_ID_RELAY, S_LIGHT);
        And then you should see the sensor in Domoticz
        • D
          dias
          the relay is present in domoticz but not the more it is driven on position when I connect the Arduino
          the motion sensor works well but they have the same name in domoticz so that I have one that appears
          • D dias
            TheoLT
            TheoLT
            TheoL
            @dias I'm sorry but I really don't understand what you mean. Try to insert some Serial.println("") and check the serial monitor. That way you can debug your sensor.
            • D
              dias
              I use google translation
              the relay remains stuck on walk
              2 pir sensor works well but in domoticz with the same name
              • TheoLT
                TheoLT
                TheoL
                I think this might cause your problem. It's in the incommingMessage method
                I think you copied it from the multiple relays example.
                try changing that code to
                     digitalWrite( RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
                In your code, you are not writing the value to the pin you've assigned to the relay.
                • D
                  dias
                  Thank you for your help
                  it works for relay and dth11
                  always the same pir sensors
                  • D
                    dias
                    on the picture have there a motion sensor that appears
                    • D
                      dias
                      wrote on last edited by dias
                      • D
                        dias
                        AC works thank you for your help
                        #define MOTION_SENSOR_DIGITAL_PIN 3
                        #define RELAY  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                        DHT dht;
                        SimpleTimer timer;
                        float lastTemp;
                        float lastHum;
                          timer.run();
                        void getMeasure() {
                            if (!metric) {
                              lastHum = humidity;
                        Insert Code Here
