  3. Home Link to MySensors
7 Posts 4 Posters 4.2k Views 3 Watching
  • C
    C
    csa02221862
    I'm looking to be able to hit a button on my cars home link as I drive into the driveway to do...what ever I want through my Vera.
    Any thoughts?
    SparkmanS 1 Reply Last reply
    • C
      C
      Chester
      Might need some more info, such as car model etc to be able to give more feedback.
      • C
        C
        csa02221862
        Home Link is a standard. All cars are the same.
        • C csa02221862
          Any thoughts?
          SparkmanS
          SparkmanS
          Sparkman
          @csa02221862 My understanding is that HomeLink buttons can be programmed to learn devices in a frequency range of about 300-433 MHz so there are a few options. I know some people that have programmed the buttons with an X-10 remote and use an X-10 receiver. There's also (a now discontinued) Wayne Dalton HomeLink to z-wave bridge. You can find them on eBay. You should be able to use some 433MHz remotes to program it as well which you could use with a 433MHz MySensored receiver.
          Al
          • DwaltD
            DwaltD
            Dwalt
            HomeLink is supposed to be able to 'learn' any code from 300-433mhz and then repeat it. It can even learn rolling codes. It could easily be used as a scene controller if you have a MySensors node with a 433mhz RX just following the same methodology used here.
            • C
              C
              csa02221862
              Sparkman, this is exactly what I want to do. Was wondering if anyone had done it yet?
              • C csa02221862
                SparkmanS
                SparkmanS
                Sparkman
                @csa02221862 The easiest may be to use something like this and connect to an Arduino: http://www.ebay.com/itm/321816823725 and use the remote to program your HomeLink buttons. Not sure how secure it would be though.
                Al
