  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • A
    ahhk
    great job! I think i will use your board to for small window -sensors.
    But one question: i cannot upload sketches via arduino-ide when the 1mhz bootloader is flashed. i checked the wires and everything else and i tested a 8mhz/internal bootloader - works fine. but the 1mhz-bootloader just does not accept uploads?
    m26872M 1 Reply Last reply
    • A ahhk
      m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      @ahhk There's also the precompiled bootloader for 4800 baud in the link above. Did you try that one too? I think 9600 baud was maximum serial speed at 1MHz. Lower should be safer.
      Or what do you mean with "does not accept uploads"? Is it locked?
      Double checked boards.txt settings?
      • A
        ahhk
        wrote on last edited by ahhk
        i can upload via RX/TX with arduino IDE with the 8mhz/internal bootloader. but if i flash the 1mhz bootloader from the link above (atmega328_1a.hex), i cannot upload the same way...
        TX/RX is connected correctly. I can upload a sketch via "Upload with programmer" and receive and transmit characters with 9600baud. tested with the example-sketch "SerialEvent".
        IT is a brand new 328P - not locked...
        boards.txt shows
        apm96.upload.tool=avrdude
        apm96.upload.protocol=arduino
        apm96.upload.speed=9600
        apm96.bootloader.tool=avrdude
        apm96.build.mcu=atmega328p
        apm96.build.f_cpu=1000000L
        apm96.build.core=arduino
        apm96.build.variant=standard
        i didnt try the 4800baud bootloader until now....i will do now...
        • A ahhk
          boards.txt shows
          m26872M
          m26872M
          m26872
          @ahhk Reset issue? Maybe try other startup times (low fuse 42h or 52h), other usb2serial or adjust reset R and C.
          • m26872M
            m26872M
            m26872
            For info. I've prototyped and ordered a slightly improved version of the pcb. Note that this is UNTESTED and experimental.
            Eagle brd-file and board house link. Use it for inspiration. Don't expect it to be and tested until next month at least.
            • mfalkviddM
              Great work @m26872
              Thanks for sharing!
              • F
                F
                frenchclem
                Really great idea @m26872 !!
                I'm waiting for the V1.2 test and review before ordering some boards on DirtyPcb.
                One Tip/question : have you thought on panelizing your slimnode, because we could easily fit 3 board on the 5X5 limitation ? I also think that DirtyPCB would even process the break routing to ease board separation.
                • F frenchclem
                  m26872M
                  m26872M
                  m26872
                  #22
                  @frenchclem
                  AAMOF I ordered a panelized version just a few days ago. I'm completely new to all this, so I leave no guarantees...
                  Here's the brd-file.
                  Edit 3/12: Boardhouse link removed (the panelized version of v1.2 contains a faulty via between D13 and SCK.)
                  • F
                    F
                    frenchclem
                    I guess if you ordered panelized version, you have tested the V1.2 ? Would you mind sharing the schematics also please ?
                    I'm also very new to this, I've never ordered PCB on Dirtypcb, how long does it takes to arrive in Europe ?
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      Delivery times depend mostly on shipping time. DirtyPCB have their boards made usually within a week after uploading the files. But shipping can take 3-4 weeks to get to Europe.
                      • F frenchclem
                        m26872M
                        m26872M
                        m26872
                        @frenchclem
                        No I actually ordered before I got the first sample, due to the delivery time. But now (just a day after) I got the first v1.2. Delivery time was 4 weeks (to Sweden). Soon tested...
                        I don't think there are any changes to the already published schematics.
                        • F
                          F
                          frenchclem
                          @GertSanders @m26872
                          Thanks guys for the good work I just ordered your boards
                          Will definitely let you know how things goes
                          GertSanders, did you find a nice box for your board + battery ?
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            #27
                            @frenchclem Not yet, the height is indeed the limiting factor. I'm now looking for a small box that can hold the sensor on it's side. SO for the moment the sensors are scattered around the house without a box around them (usually in places where the cat does not go or could find them).
                            • F
                              F
                              frenchclem
                              @GertSanders thats what I was worried about. What is the height of the sensor + battery ?
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                #29
                                @frenchclem
                                I can not measure that now (at work), but I guess around 35mm if batteries are mounted on he bottom. By using the extrnal (JST connector) power option, the height of PCB, processor and radio is around 22mm I think.
                                Most boxes have an internal clearance of around 20-25mm.
                                Some boxes have 40mm internal clearance and are good in height, but those are usually also to long and wide for my taste.
                                @m26872 's board certainly is lower, since batteries are not on the bottom but in the axis of the board. The radio is also directed away from the processor on his board, so it can be mounted lower (directly on PCB instead of on a header). I really like that concept, since it will fit the plastic cableducts made by Legrand:
                                http://www.ecataleg.be/fr/categorie/3020/moulure-et-goulotte-murale-en-pc-abs-sans-halogene
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @frenchclem
                                  Just to confirm: 35mm is the height with the small radio.
                                  Using the larger radio (with PA+LNA) you need 41mm height
                                  Without battery holders, and the small radio, the height is 22 mm
                                  Width is 25mm for AAA battery holders mounted, 33mm for AA battery holder, and length is 53mm (AAA batteries) and 58mm (AA batteries)
                                  • m26872M
                                    m26872M
                                    m26872
                                    v1.2 tested and working. But the design of crossing R1 and C2 was a horrible choice - it's impossible to fit both nicely under/inside the uC socket. Perhaps possible with a 1/8W R1, but otherwise R1, C2 or both must be placed on bottom side.
                                    Good news is that all versions and orders are OK apart from this little inconvenience.
                                    I'll try to make a better version ASAP.
                                    AWIA 1 Reply Last reply
                                    • m26872M m26872
                                      AWIA
                                      AWIA
                                      AWI
                                      wrote on last edited by AWI
                                      #32
                                      @m26872 I have assembled 6 boards now and am very happy with the design. I use strips as a socket for the Atmega. This leaves enough room for components under it. Also made one with SPI connector. Works perfect! Thank you for sharing the design and instructions.upload-422d1df5-f52b-46fd-b28c-67493daa9fdc upload-aea4bc1e-e16a-4881-a378-e609a6c2f0c8
                                      • AWIA AWI
                                        m26872M
                                        m26872M
                                        m26872
                                        @AWI Great idea with the strips! And thanks for verifying (v1.2?).
                                        • m26872M
                                          m26872M
                                          m26872
                                          #34
                                          I've now ordered yet another prototype version (1.4):
                                          http://dirtypcbs.com/view.php?share=13310&accesskey=58c87fe605eb91958938f70b5efc8629
                                          Eagle brd-file.
                                          Photo here.
