  3. Send serial data to vb.net to gw (usb connected)
8 Posts 3 Posters 4.2k Views 1 Watching
  • ch3b7C Offline
    ch3b7C Offline
    ch3b7
    Im use de beta library, i can send data to gw with serial.write("1234") command and show the recieved number. My problem is how can use the incomming data in gw? Im use this example
    if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
    // say what you got:
    Serial.print("I received: ");
    Serial.println(incomingByte, DEC);
    if(SerialValue == 1234){
    Serial.print("WORK ");
    The IF command dont work. I try to send commands from vb.net to gw to turn on or off sensor and put auto ID
    • marceltrapmanM Offline
      marceltrapman
      When you want an example of how a controller works you can look at the vera plugin on github.
      It is the example that I use as well for my plugin for Indigo.
      Make sure you check 'master' out for 1.3 of 'development' for 1.4.
      Fulltime Servoy Developer
      ch3b7C 1 Reply Last reply
        ch3b7C Offline
        ch3b7C Offline
        ch3b7
        @marceltrapman im read de .lua file but if i send the same command lua send like "255;255;3;0;4;2\n" (set radio ID) from vb.net dont work
        • DammeD Offline
          DammeD Offline
          Damme
          Code Contributor
          are you using 1.3 or 1.4b?
          • ch3b7C ch3b7
            marceltrapman
            wrote on last edited by marceltrapman
            @ch3b7 said:
            @marceltrapman im read de .lua file but if i send the same command lua send like "255;255;3;0;4;2\n" (set radio ID) from vb.net don't work
            Please make sure (considering your example) that you are using 1.4 and not 1.3 because the ack paramater (in this case 0/false) is not used in 1.3.
            And make sure that this really respond to a request.
            So in your case you are actually responding to a request for an id?
            • ch3b7C Offline
              ch3b7C Offline
              ch3b7
              Im use 1.4b. If a sensor ask for id and i put this command in the serial windows in arduino it works. If i send the same command from other program like a custom vb.net nothing happend. I think the gw not listening the incomming serial data from the usb. Sorry for my bad english im from Argentina!
              • ch3b7C ch3b7
                marceltrapman
                Ah, you have to use serial-usb. You can not send it to the usb port just like that.
                Sorry for my bad english I am Dutch ;)
                • ch3b7C Offline
                  ch3b7C Offline
                  ch3b7
                  serial-usb adapter?
                  113.2k
