  3. Noob, 1st sensor (Motion) and SerialGW not talking
6 Posts 2 Posters 2.1k Views
  • A Offline
    A Offline
    atomicpapa
    wrote on last edited by atomicpapa
    Setting up my first sensor (motion sensor) on a serial gateway connected to a RPi running Domoticz. Sensor is running on a Geuine Uno r3, GW is running on a Nano. Domoticz recognizes the gateway and is visible in Log. Looks like mybe they are talking based on serial monitor on gateway...
    0;0;3;0;9;read: 255-255-255 s=250;0;3;0;9;gateway started, id=0, parent=0, distance=0
    0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0```
    Serial Monitor for sensor shows...
    find parent
    send: 255-255-ind parent
    s0,l=0,sg=0,st=bc:
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    find parent
    and repeats ad infinitum. No nodes or children show up in Domoticz. I am running stock Gateway and Sensor scripts with only 2 changes in MyConfig.h - Channel set to 100 and signal strength for sensors set to MAX.
    MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    #define DEBUG
    // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
    #define ENABLED_SERIAL
    #define BAUD_RATE 115200
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    *  Information LEDs blinking
    // disabled in the gateway.
    // #define WITH_LEDS_BLINKING
    // off when blinking
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    //#define MY_SIGNING_FEATURE
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    #define RF24_PA_LEVEL_GW   RF24_PA_MAX
    #define RF24_CHANNEL	   100
    //#define SOFTSPI
    #ifdef SOFTSPI
    *  RFM69 Driver Defaults
    Am I missing something simple here?
    • H Offline
      H Offline
      Do you use an amplified radio on the gateway? How are you powering it? Capacitor?
      • A Offline
        A Offline
        atomicpapa
        Should have mentioned that. Running NRF24's, both with capacitors, both being powered off a USB hub hooked to my laptop.
        • H Offline
          H Offline
          Strange.
          You node isn't receiving the FIND_PARENT broadcast message sent by your gateway. Hard to say what the problem is.. Try lowering the signal strength to see if that helps.. in that case you have a powering issue.
          • A Offline
            A Offline
            atomicpapa
            changed the MyConfig.h to lower power, but now getting an out of sync error from avrdude when I try to upload sketch, which appears to mean I need to reflash the bootloader from what I have been able to find. I'll update you on sig strength result when that's done.
            • H Offline
              H Offline
              Not sure why the bootloader should have been corrupted? Have you disconnected everything from the Arduino board?
              12.1k
