  3. Wireless nRF24L01+ sniffer for MySensors
omgsnifferwiresharknrf24l01+
108 Posts 19 Posters 99.6k Views 18 Watching
    For those following this topic I have not solved it but it could be related to this:
    Upgrade to 8.1 and stuff stops working (not what most people would call an "up"-grade).
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    OK, for those of you on Windows 8.1 this will probably not work 'out of the box'.
    For me, a Mac user, the following solution makes complete sense :-P
    You have to install or repair Microsoft Essentials and the dll will be available.
    Don't ask me why but it works!
    Fulltime Servoy Developer
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      Everything works now.
      Did not see any packets coming in though but I remember having an issue with a couple of Uno's and I am not sure if this was one of them.
      Anyway, I will do some more testing tomorrow.
      Very exited :)
      YveauxY 2 Replies Last reply
        Very exited :)
        @marceltrapman Great you got it working man!
        In the meantime, please have a look at the last part I wrote, detailing the use of Wireshark and the sniffer: http://yveaux.blogspot.nl/2014/07/nrf24l01-sniffer-part-3.html
        For tonight I'm totally done with this sniffer -- Aaaarghhh! ;-)
        Btw. Could you also post stuff you had to do to get it working (just a wrapup) to my blog, to keep stuff together? Thanks!
        • YveauxY Yveaux
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @Yveaux When I am sure that everything really works (including my Uno/Radio) I will sure write a wrap-up to you blog!
            @Yveaux Not a problem, I like being a pioneer and I greatly appreciate the efforts you put into this :)
            I thought I had everything in order this afternoon.
            Installed Visual C++ Redistributable Packages for Visual Studio 2012 SP 4 but forgot to test...
            Right now, whatever I use 'Visual C++ Redistributable Packages for Visual Studio 2012 SP 4' or (for testing purposes) 'Visual C++ Redistributable Packages for Visual Studio 2013' both x64 I still see the error message 'The program can't start because MSVCR110.dll is missing...'.
            A restart should not be necessary but even a restart did not help.
            Uninstalling all packages and reinstalling did not help either.
            Any idea?
            @marceltrapman said:
            both x64
            The console application is 32bits. I don't know if the 32 bits versions are included in the 64 bits installers...
            • YveauxY Yveaux
              both x64
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              wrote on last edited by marceltrapman
              #25
              That was not the issue...
              Below is the wrap-up that I also posted on your blog:
              There are 3 things that I bumped into though that I would like to share with you and those that decide to use the sniffer.
              1. Immediately after starting** 'Nrf24Sniff.exe -P6'** (the rest is default in my case) I got this error message 'The program can't start because MSVCR110.dll is missing...'. It basically complains that 'Visual C++ Redistributable Packages for Visual Studio 2012 SP 4' is not installed but that is not true. After doing a bit of searching I found that I needed to** install or repair 'Microsoft Essentials'**.
                Once this was done the program works as expected (don't ask me why, this must be pure MS genius).
              2. Once Wireshark was started like described I noticed that the Nrf24Sniff console window displayed a *'Wait for sniffer to restart' *message. The author mentions that this will only take a few seconds but in my case I actually needed to reset the Arduino for it to go away. No exception.
              3. After creating the correct setup in Wireshark I expected data to show up but it did not. I wondered why and ran a complete test to see that the Ardiuno was ok, radio sufficiently powered etc. but that was all ok. I then re-read the article and found that the author says 'when monitoring MySensors 1.4beta traffic (at non-default 1Mb/s)'. I completely missed this and that caused the issue.The MySensors 1.4beta is set to 250b/s by default. Once I started the sniffer like 'Nrf24Sniff.exe -P6 -r2' everything works as expected.
              Now I have to find some time to read the third article so that I understand what happens on my screen :)
              Anyway, good stuff and a big thank you goes to @Yveaux ...
              • epierreE
                epierreE
                epierre
                @Yveaux can you do me a favour ? colord blind people cannot read red on black... they represent 10% of the population...
                Also, does your software runs under nano ;-)
                z-wave - Vera -> Domoticz
                marceltrapmanM epierreE YveauxY 3 Replies Last reply
                • epierreE epierre
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  I can't think of a reason why it would not work.
                  Just try (once you can read the blog :) ).
                  epierreE 1 Reply Last reply
                  • epierreE epierre
                    epierreE
                    epierreE
                    epierre
                    @Yveaux ah a vb programmer... you need to install the msvcr110.dll msvcr110.dll t to make it start with wine. (does not work with mono...)
                    then I have wireshark but I don't understand what to do next...
                    "Connect Wireshark to \.\pipe\wireshark to continue..."
                      epierreE
                      epierreE
                      epierre
                      #29
                      @marceltrapman yes but for the reason just above I can't... had to select all the text to read...
                       mono Nrf24Sniff.exe
                       Cannot open assembly 'Nrf24Sniff.exe': File does not contain a valid CIL image.
                      • epierreE epierre
                         mono Nrf24Sniff.exe
                        marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        #30
                        I was really... Joking with you :)
                        BTW I can imagine that trying to make this work with wine will give you all sorts of issues that are hard to comment on for those that don't use it.
                          Ok, thanks again man!
                          • epierreE epierre
                            #32
                            What is red on black? Some coloring in Wireshark?
                            If so, I don't choose the colors, Wireshark does! I just mark it as 'warning'.
                            Have a look at Edit->Preferences->User Interface->Font and colors to see if you can change it to your likings.
                            AH, now I see what you mean! The text on my blog :-)
                            I didn't test it, but don't see why it shouldn't!
                            • YveauxY Yveaux
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              It is your blog.
                              Mostly white on black but, when highlighted, also red on black...
                                It is your blog.
                                @marceltrapman Colors are not my top priority right now, but I'll put in on the list then. Thanks for the hint.
                                • epierreE epierre
                                  @epierre It's not written in vb! Shame on your! It's pure hardcore C!
                                  If you get it to run on Linux (?) using Wine then let us know please!
                                  • YveauxY Yveaux
                                    epierreE
                                    epierreE
                                    epierre
                                    @Yveaux yes I did... but I stopped here not knowing how to do it:
                                    • epierreE epierre
                                      @epierre It's in the blog: start a new command window and navigate to the wiresrak directory (c:\program files\wireshark)
                                      Then run:
                                       wireshark -k -i \\.\pipe\wireshark
                                      And it should automatically connect to the named pipe (which is written to from the nrf24sniff.exe tool) and start capturing.
                                      • YveauxY Yveaux
                                        Then run:
                                        epierreE
                                        epierreE
                                        epierre
                                        @Yveaux yes but through wine are they POSIX compliant so my linux wireshark can connect to it ?
                                        • epierreE epierre
                                          @epierre I guess not, as Linux uses files as named pipes and \.\pipe\wireshark is not a regular Linux file path...
                                          Furthermore the Wireshark dissectors should compile on Linux, but I didn't test it.
                                          You could try to also run windows Wireshark through Wine, maybe the named pipes will pass the data along just fine...
                                          12.5k
