  3. Wireless nRF24L01+ sniffer for MySensors
omgsnifferwiresharknrf24l01+
108 Posts 19 Posters 98.8k Views 18 Watching
  • epierreE epierre
    @Yveaux can you do me a favour ? colord blind people cannot read red on black... they represent 10% of the population...
    Also, does your software runs under nano ;-)
    epierreE
    epierreE
    epierre
    @Yveaux ah a vb programmer... you need to install the msvcr110.dll msvcr110.dll t to make it start with wine. (does not work with mono...)
    then I have wireshark but I don't understand what to do next...
    "Connect Wireshark to \.\pipe\wireshark to continue..."
    z-wave - Vera -> Domoticz
      I can't think of a reason why it would not work.
      Just try (once you can read the blog :) ).
      epierreE
      epierreE
      epierre
      #29
      @marceltrapman yes but for the reason just above I can't... had to select all the text to read...
       mono Nrf24Sniff.exe
       Cannot open assembly 'Nrf24Sniff.exe': File does not contain a valid CIL image.
      • epierreE epierre
         mono Nrf24Sniff.exe
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        wrote on last edited by marceltrapman
        #30
        I was really... Joking with you :)
        BTW I can imagine that trying to make this work with wine will give you all sorts of issues that are hard to comment on for those that don't use it.
        Fulltime Servoy Developer
          @Yveaux said:
          The console application is 32bits. I don't know if the 32 bits versions are included in the 64 bits installers...
          That was not the issue...
          Below is the wrap-up that I also posted on your blog:
          There are 3 things that I bumped into though that I would like to share with you and those that decide to use the sniffer.
          1. Immediately after starting** 'Nrf24Sniff.exe -P6'** (the rest is default in my case) I got this error message 'The program can't start because MSVCR110.dll is missing...'. It basically complains that 'Visual C++ Redistributable Packages for Visual Studio 2012 SP 4' is not installed but that is not true. After doing a bit of searching I found that I needed to** install or repair 'Microsoft Essentials'**.
            Once this was done the program works as expected (don't ask me why, this must be pure MS genius).
          2. Once Wireshark was started like described I noticed that the Nrf24Sniff console window displayed a *'Wait for sniffer to restart' *message. The author mentions that this will only take a few seconds but in my case I actually needed to reset the Arduino for it to go away. No exception.
          3. After creating the correct setup in Wireshark I expected data to show up but it did not. I wondered why and ran a complete test to see that the Ardiuno was ok, radio sufficiently powered etc. but that was all ok. I then re-read the article and found that the author says 'when monitoring MySensors 1.4beta traffic (at non-default 1Mb/s)'. I completely missed this and that caused the issue.The MySensors 1.4beta is set to 250b/s by default. Once I started the sniffer like 'Nrf24Sniff.exe -P6 -r2' everything works as expected.
          Now I have to find some time to read the third article so that I understand what happens on my screen :)
          Anyway, good stuff and a big thank you goes to @Yveaux ...
          Ok, thanks again man!
          • epierreE epierre
            #32
            What is red on black? Some coloring in Wireshark?
            If so, I don't choose the colors, Wireshark does! I just mark it as 'warning'.
            Have a look at Edit->Preferences->User Interface->Font and colors to see if you can change it to your likings.
            AH, now I see what you mean! The text on my blog :-)
            I didn't test it, but don't see why it shouldn't!
            • YveauxY Yveaux
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              It is your blog.
              Mostly white on black but, when highlighted, also red on black...
                It is your blog.
                @marceltrapman Colors are not my top priority right now, but I'll put in on the list then. Thanks for the hint.
                • epierreE epierre
                  @epierre It's not written in vb! Shame on your! It's pure hardcore C!
                  If you get it to run on Linux (?) using Wine then let us know please!
                  epierreE 1 Reply Last reply
                  • YveauxY Yveaux
                    epierreE
                    epierreE
                    epierre
                    @Yveaux yes I did... but I stopped here not knowing how to do it:
                    • epierreE epierre
                      @epierre It's in the blog: start a new command window and navigate to the wiresrak directory (c:\program files\wireshark)
                      Then run:
                       wireshark -k -i \\.\pipe\wireshark
                      And it should automatically connect to the named pipe (which is written to from the nrf24sniff.exe tool) and start capturing.
                      • YveauxY Yveaux
                        Then run:
                        epierreE
                        epierreE
                        epierre
                        @Yveaux yes but through wine are they POSIX compliant so my linux wireshark can connect to it ?
                        • epierreE epierre
                          @epierre I guess not, as Linux uses files as named pipes and \.\pipe\wireshark is not a regular Linux file path...
                          Furthermore the Wireshark dissectors should compile on Linux, but I didn't test it.
                          You could try to also run windows Wireshark through Wine, maybe the named pipes will pass the data along just fine...
                            #40
                            1. Once Wireshark was started like described I noticed that the Nrf24Sniff console window displayed a *'Wait for sniffer to restart' *message. The author mentions that this will only take a few seconds but in my case I actually needed to reset the Arduino for it to go away. No exception.
                            I changed the nrf24snif.exe to explicitly reset the Arduino (works for Uno) by lowering DTR/RTS lines. Should work for (most?) other Arduino's too, but I don't have any other to test one.
                            For me it seems to work now. Could you test if this works stable for you too?
                            Oh yeah, I added support for some status leds to the Sniffer, connected to A0..A4 and via resistors to GND:
                            • A0 sniffer monitoring (LED turns off during reset)
                            • A1 sniffer receiving a packet
                            • A2 sniffer transmitting (serially) a packet
                            • A3 new configuration received
                            • A4 buffer overflow
                            marceltrapmanM 2 Replies Last reply
                            • YveauxY Yveaux
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              @Yveaux Nice.
                              When I find the time I will test it for Uno and Mega.
                              Not sure that I have a free Nano right now.
                              Also not sure that I have a soldered Pro Mini.
                              • YveauxY Yveaux
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                #42
                                @Yveaux
                                Maybe I should create a (little) shield for this that holds the radio as well.
                                Or just use a prototype board...
                                  @Yveaux
                                  @marceltrapman Maybe all of the LEDs are a bit overkill, but the RX LED and maybe the buffer-full LED can seriously be handy.
                                  • marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    I only checked the UNO with the new sketch (no LEDs) and the new iteration of nrf24snif.exe and both work as expected...
                                    @Yveaux Well done again!
                                      Everything works now.
                                      Did not see any packets coming in though but I remember having an issue with a couple of Uno's and I am not sure if this was one of them.
                                      Anyway, I will do some more testing tomorrow.
                                      Very exited :)
                                      #45
                                      @marceltrapman And? How did the testing go?
                                      I fixed the Nrf24sniff.exe to use static linking so the msvcr110.dll should no longer be required.
                                      Also fixed executable so it runs on WinXP now (untested...).
                                      • YveauxY Yveaux
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        @Yveaux To be honest, I have played with it a little but I have not come much further.
                                        Spent my time this weekend on other things :)
                                        Will let you know soon!
                                        • R
                                          R
                                          Rasmus Eneman
                                          Could the line quality information be queried directly by the gateway so that it can be known without additional hardware?
