  3. RFM69 problems
RFM69 problems
34 Posts 5 Posters 17.1k Views 2 Watching
    I will do a couple of adjustments of the RF69 stuff tonight here on dev-branch.
    Add a mis-wired check like we do for the RF24 driver. I also currently you have to do a
    #define MY_IS_RFM69HW true
    to activate the HW-version... this will be changed to
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Ok, one more stupid question. If I want to try the developer branch do I just install the regular 1.5 zip amd then just overwrite them with the files from the developer branch on git?
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok, I think I have figured it out. But I am trying this sketch:
         * LEDs (OPTIONAL):
         * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
        //#define MY_RADIO_NRF24
        #define MY_RADIO_RFM69
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Flash leds on rx/tx/err
        // Set blinking period
        // Enable inclusion mode
        #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
        #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
        But I am getting this error when trying to complie:
        Arduino: 1.6.6 (Windows 7), Board: "Arduino Nano, ATmega328"
        Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
        Warning: platform.txt from core 'Mysensors SAMD (32-bits ARM Cortex-M0+) Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
        Library can't use both 'src' and 'utility' folders.
        Error compiling.
          wrote on last edited by hek
          Do like it says, turn on verbose output.
          (you have to replace the old MySensors-folder under libraries with the new)
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Ok, I turned on the verbose output and this is what I got:
            C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Cliff\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10606 -build-path "C:\Users\Cliff\AppData\Local\Temp\build8a702dc9de8b52c506f71d8c8aabed09.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Cliff\AppData\Local\Temp\arduino_8a702dc9de8b52c506f71d8c8aabed09\GatewaySerial.ino"
            Error compiling.
            I have removed arduino IDE and all mysensor libraries, I reinstalled the arduino IDE added/replaced the librarys with the Arduino-master, then replaced again with Arduino-development.
              You must have done something wrong setting it up (I'm also running 1.6.6).
              You should get the following error using the sketch you posted above:
              Users/hek/Documents/ArduinoGithub/libraries/MySensors/MySensor.h:195:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Ok, after trying again I extracted Arduino-development to a separate folder in my sketchbook location witout replacing anything. I then got an error saying it could not find Mysensors.h so I copied it to the Gatewayserial folder and now it complies but gives me the error you specified hek. So how do I solve this? is not the gatewayserial sketch ready to complie as is?
                  Oh, sorry I just copied part of the sketch above when I got the compile error.
                  When compiling the whole file it works fine here.
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Ok so I should use the serialgateway sketch from the arduino master? I did not find any other serialgateway sketch in arduino development than the one I posten.
                    hekH 1 Reply Last reply
                      No, you're using the right one.
                      You must replace the WHOLE MySensors library folder. Not just copying the MySensors.h.
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Ok, tried again and I think I got it right this time as I got three tabs in the arduino IDE when opening the serialgateway-sketch, before I only got one tab.
                        But now I have the same error as you shown hek, what does this mean:
                        #if !defined(MY_GATEWAY_FEATURE) && !defined(MY_RADIO_FEATURE)
                        I already have this in the gateway sketch:
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Ahh, finally. I used the sketchbook location for everything like it says in the info for 1.5. When I copied all the development libraries into the Arduino libraries folder it worked.
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            I tried changing computers and it seems to work better now, But I just realized something where or how do I set the frequency of the rfm radio?
                              Put one of these in your sketch
                              #define MY_RFM69_FREQUENCY   RF69_433MHZ
                              #define MY_RFM69_FREQUENCY   RF69_915MHZ
                              I should probably try to find some time starting to document the 1.6 features. But most of them is already easy to find by reading MyConfig.h.
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                ok, if I dont specify this in my sketch will it default to either frequency?
                                  It'll default to RF69_868MHZ
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    Ok, all my radios is 868Mhz so the problem is something else. I always get similar errors from the serial monitor after complying sensor-sketches.
                                    Starting sensor (1.6.0-beta)
                                    Radio init successful.
                                    send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
                                    send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
                                    send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:Relay
                                    send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
                                    send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                    Init complete, id=7, parent=0, distance=1
                                    What does this mean? It says radio init successful, but can it still be radio problems?
                                      Well, do you receive any messages on the gateway side?
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        Well I changed the CHILD_ID_LIGHT to 7 in the lightlux sensor sketch, I don't know if that was right. But nothing shows up in domoticz.
                                        I get this from serial monitor:
                                        send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=fail:Light Lux Sensor
                                        send: 7-7-0-0 s=7,c=0,t=16,pt=0,l=0,sg=0,st=fail:
                                        54612
                                        send: 7-7-0-0 s=7,c=1,t=23,pt=3,l=2,sg=0,st=fail:54612
                                        find parent
                                        send: 7-7-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                        • Cliff KarlssonC
                                          Cliff KarlssonC
                                          Cliff Karlsson
                                          I dont't know how many times I have tried to fix my rfm69 issues but no success.
                                          I have got a new raspberry pi 2 controller, formatted/reinstalled my pc, bought a powered usb hub, changed my serialgateway and resoldering sensor-nodes and gateways several times.
                                          The gateway seems too start up fine, but when I power any sensor I get this in domoticz log:
                                          015-11-16 21:07:18.763 Domoticz V2.3603 (c)2012-2015 GizMoCuz
                                          2015-11-16 21:07:18.763 Build Hash: 95def9c, Date: 2015-11-16 18:45:30
                                          2015-11-16 21:07:18.764 System: Raspberry Pi
                                          2015-11-16 21:07:18.765 Startup Path: /home/pi/domoticz/
                                          2015-11-16 21:07:19.058 Sunrise: 07:55:00 SunSet:15:15:00
                                          2015-11-16 21:07:19.058 EventSystem: reset all events...
                                          2015-11-16 21:07:19.104 Active notification subsystems: (0/10)
                                          2015-11-16 21:07:19.244 Webserver started on port: 8181
                                          2015-11-16 21:07:19.303 Webserver started on port: 443
                                          2015-11-16 21:07:19.321 Started shared server on: 0.0.0.0
                                          2015-11-16 21:07:21.323 Hardware Monitor: Started
                                          2015-11-16 21:07:21.325 EventSystem: reset all events...
                                          2015-11-16 21:07:21.326 EventSystem: reset all device statuses...
                                          2015-11-16 21:07:21.328 EventSystem: Started
                                          2015-11-16 21:07:22.325 MySensors: Using serial port: /dev/ttyUSB0
                                          2015-11-16 21:07:23.797 MySensors: Gateway Ready...
                                          2015-11-16 21:07:23.872 MySensors: Gateway Version: 1.6.0-beta
                                          2015-11-16 21:07:24.323 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:07:41.272 Incoming connection from: 192.168.0.24
                                          2015-11-16 21:07:45.202 1-Wire support available (By Kernel)...
                                          2015-11-16 21:08:04.752 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:08:34.800 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:09:04.837 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:09:34.886 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:10:04.923 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:10:34.971 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:11:05.008 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:11:35.056 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:12:05.095 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:12:35.146 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:13:05.198 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:13:35.249 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:14:05.301 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:14:35.352 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:15:05.404 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:15:35.455 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:16:05.507 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:16:35.545 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:17:05.598 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:17:35.644 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:18:05.694 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:18:35.732 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:19:05.784 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:19:35.822 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:20:05.871 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:20:35.909 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:21:05.958 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:21:35.996 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:22:06.047 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:22:36.086 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:23:06.138 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:23:36.177 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:24:06.229 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:24:23.700 Error: Serial Port closed!... Error: End of file
                                          2015-11-16 21:24:23.818 MySensors: retrying in 30 seconds...
                                          2015-11-16 21:24:36.269 Hardware Monitor: Fetching data (System sensors)
                                          2015-11-16 21:24:52.821 MySensors: Using serial port: /dev/ttyUSB0
                                          2015-11-16 21:24:52.822 Error: MySensors: Error opening serial port!
                                          2015-11-16 21:24:53.822 MySensors: retrying in 30 seconds...
                                          2015-11-16 21:25:06.318 Hardware Monitor: Fetching data (System sensors)
                                          And when I look at the serial gateway options the usb port (/dev/ttyUSB0) is blank. I have to remove the usb cable and insert it again or reboot to get the usb port back.
