  3. How can I set the payload for MQTT v1.6
10 Posts 2 Posters 4.6k Views
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    In the mysensors v1.6 notes (https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#) it was mentioned that the following pattern is used for mqtt usage
    MY-MQTT-TOPIC-PREFIX/NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
    Example topic:
    my-mqtt-gateway/1/2/2/0/1
    But Actually I don't understand where do I assign the payload ? Also the gateways subscribes only to mygateway/+/+/+/+/+
    They are 5 not 6.
    Using the serial interface there is a payload to be set
    7;5;1;0;2;1
      http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway
      • ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        Sorry Hek but I still don't get it.
        When I set my mqtt gateway, it subscribes to mygateway-prefex/+/+/+/+/+
        When I was using serial gateways, I was doing the following to turn on or off a relay.
        7;5;1;0;2;1 This sets node id 7, child id 5, message type '1' (set), no ack, sub-type '2' (V_LIGHT), to be >>> equal 1 (ON)
        7;5;1;0;2;0 This sets node id 7, child id 5, message type '1' (set), no ack, sub-type '2' (V_LIGHT), to be >>> equal 0 (OFF)
        While using mqtt, what I expected that we subscribe to a topic name like mygateway1-in then I shall normally add my 6 bits which are 7/5/1/0/2/1 or 7/5/1/0/2/0
        So my question is about setting the payload to 1 or 0. I still can see that you mentioned that MQTT frame is like this
        while the serial frame has one more option for payload
        node-id;child-sensor-id;message-type;ack;sub-type;payload\n
        I hope that you understood my problem. Thanks.
        • ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          Looks like I misunderstood something..payload will be the message itself. I'll test it now and will be back again
            Using moquitto_pub command line tool you would send it like this:
            > mosquitto_pub -t 'mygateway1-in/7/5/1/0/2' -m '1'
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @hek well I don't have a problem in setting the mqtt environment using mosquitto. I just noticed two things now.
              First, I am working on windows and using chrome plugin MQTTlens. I decided using mosiquitto as you said.But using
              didn't work, I used instead
              mosquitto_pub -t mygateway1-in/7/5/1/0/2 -m 1
              It was received by the gateway and printed
              Message arrived on topic: mygateway1in/23/19/1/0/2
              But the second thing is that incomingMQTT() function, the frame is not evaluated at all. It goes to case 0 and return
              case 0: {
                  // Topic prefix
                  if (strcmp_P(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0)
                      // Message not for us or malformed!
              	    Serial.println("DOOLA - incomingMQTT - case 0 ERROR");
                          return;
                  Serial.println("DOOLA - incomingMQTT - case 0");
              I tried commenting the if condition and I frame was evaluated but i received st=fail:1
              I suppose that it is working and tested and maybe I have a problem, right ?
              hekH 1 Reply Last reply
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                Still unable to connect with a node.
                Serial gateway is working with the same pattern sent.
                I made sure that the buffer sent using serial or using mqtt are the same. I send ;23;19;1;0;2;1 using serial, and mygateway1in/23/19/1/0/2 using mqtt. and both printed same buffer.
                RF24::write > startFastWrite > RF24::write_payload
                023101219490
                I changed the nRF also but it didn't solve the problem.
                  case 0: {
                      // Topic prefix
                              return;
                  Looks like the dash-character is swallowed when you don't quote the topic on windows.
                  Can't debug this on my mac. Just change the topic prefix in sketch to something without without dash.
                  You seem to have problem with your radio. This has been discussed elsewhere on forum and there is a troubleshoot guide on man site.
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    wrote on last edited by ahmedadelhosni
                    @hek sorry this was a typo.
                    Actually it printed Message arrived on topic: mygateway1-in/23/19/1/0/2 on arduino serial. meaning that it received it correctly. I just copied the one without dash with mistake because I was testing with a topic without the dash, cas I thought that this line
                    have problem with the dash.
                    • ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      I guess I solved the problem. Please check http://forum.mysensors.org/topic/2193/gatewayesp8266mqttclient-in-development-branch/11
