  3. Need some clarifications on Repeater node
13 Posts 6 Posters 4.6k Views 2 Watching
  • sundberg84S
    sundberg84S
    When a route is calculated for a node and that works - I dont think it will change.
    I read somewhere that it needs like 6 fails to recalculate.
    Im a control freak and set the parent manually on the nodes i want to go through the repeater (fourth argument in gw.begin)... but that should not be nessecary,
    If the nodes keep failing i guess over time it will find its way throught the repetater.
    • D
      doblanch
      Hello Thanks for your help. I understand now why I didn't see anything.
      I have another question, I need to send the message from my Weatherstation to the GW, however the ceiling is pretty thick and nothing is passing though ... Even with repetear , I can't cross the ceiling.
      I have an Ethernet cable there, do you think that we can carry something over it ? or is there some solution for this kind of case. I guess that some people got this issue also ...
      thanks
      rgds
      • mfalkviddM
        Maybe you could buy a Raspberry Pi and use it as ethernet gateway over the ethernet cable?
        • sundberg84S
          sundberg84S
          Which radio do you use ? I have my gw in the cellar with a thick concrete floor and that works fine even from outside. Do you have the 4.7 cap if you use the nrf radio ?
          • D
            doblanch
            @sundberg84 said:
            Yes I use NRF24.it's not a wall, but a ceiling with a steel mesh inside... I have the capacitor, and I'm use to work with NRF, I tried many of them china, or other items... I don't have any issue in the flat...
            In fact I have a window , but the gateway is undo a stair made 100% of steel... and a lot of message doesn't reach the destination !.
            • GertSandersG
              GertSandersG
              GertSanders
              If you can work with a second gateway in your controller, then why not use an ethernet gateway (NRF24+Pro Mini+ethernetport module) ?
              In Domoticz you can have several gateways, not sure which controller you use, but that could be a low cost solution.
              • D
                deki
                Two GW's would fix a similar problem I am having. Are there details anywhere talking about how to implement duel GW's??
                • sundberg84S
                  sundberg84S
                  If you use Domoticz you just need to add another hardware with that IP adress assigned to the etnerhet gw.
                  • D
                    deki
                    Yes I am using Domoticz. Will give it a try this weekend.
                    • sundberg84S
                      sundberg84S
                      Might be that you need to set parent so data its not picked up by both GWs. I dont know how Domoticz handles this, but normaly if a value comes in which is the same as the one before i dont think it will register...
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        As far as I know, you can't have two gateways on the same network. You will have to change channel for one gateway and connected network nodes, in config. The controller will be the bridge between networks.
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          Indeed, I would use two different channels. The question remains which controller is used. I have two networks on my test-Domoticz setup which use different channels from my production setup. So I have nodes on 3 different channels. Domoticz handles this fine. I did not yet test the move of a node with known ID from one channel to another. When time permits I should check this ...
