  3. [SOLVED]MQTTGatewayW5100 not sending messages to nodes
4 Posts 3 Posters 2.3k Views 2 Watching
    Samuel235
    Whenever i publish a message to the subscribe prefix of my gateway i get this read out on the serial monitor:
    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
    0;0;3;0;9;Sending message on topic: Gateway1-out/2/1/1/0/16
    0;0;3;0;9;Message arrived on topic: Gateway1-in/4/1/1/1/2
    0;0;3;0;9;read: 1-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:51.3
    My relay is attached to node 4, so its got the message from the controller but it just don't seem to be passing it on.
    What i would expect next in the serial monitor would be something like
    0;0;3;0;9;read: 0-4 s=?,c=?,t=?,pt=?,l=?,sg=?
    I'm not sure what s=, c=, t=, etc means so i just put '?'s'
    Any information would be greatly appreciated!
    Thanks in advance, Sam.
    EDIT: Included the Gateway Sketch below in case it is needed
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #include <EEPROM.h>
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mysensors"
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #if !defined(MY_W5100_SPI_EN)
      #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,0,22
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 21
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    MySensors 2.1.1
    • L
      L
      lorisc
      hi, had the same problem. Replace the strcmp_P function with strcmp in MyGatewayTransportMQTTClient.cpp, line 74.
      			// Topic prefix
      			if (strcmp(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0) {
      				return;
      I think that topic comparison could be skipped...
        Samuel235
        Fantastic - Works a treat, i shall update the topic title.
        Really, thank you! Another piece of valuable learning has taken place this morning. Really appreciate the time you took to inform me of this, thank you again!
        MySensors 2.1.1
          @lorisc said:
          strcmp
          Ok, this has been pushed to dev-now. Probably worked for me because I tested on the ESP8266.
