  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.9k Views 36 Watching
  • mfalkviddM
    @soward that wasn't quite the feedback I got, but what I wrote didn't make much sense either so I have corrected it now. Thanks!
      minscof
      wrote on last edited by minscof
      I have a trouble with CPU utilization when I start the gateway : 100% all the time. I use Jessie and not Wheezy on a RPI 2. Does someone can help me to troubleshoot this problem ? I have not add a decoupling capacitor , can it be the reason ?
      Solved : see this post
      C 1 Reply Last reply
      • M minscof
        C
        C
        christian
        This happened to me as well, I mixed up the boards I had at home and discover later it was a B+ and not a RPI2 :-) Maybe you've made the same mistake?
        • mfalkviddM
          #21
          @minscof got an answer in this thread: http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/3
          The high cpu usage will go away as soon as you start your controller (or something else that reads from the tty the gateway creates).
          • E
            E
            Eawo
            Is it possible to use NRF24L01+PA+LNA Antenna version or is it to power hungry? Do i have to change something in the code?
            • G
              G
              georgep56
              @Eawo If you look at the excellent original post from @mfalkvidd above:
              The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required.
              I don't believe that you will need to make any changes to code.
              • E
                E
                Eawo
                wrote on last edited by Eawo
                #24
                My friend also started with mysensors and i gave him my old raspberry with the 26 pin gpio. Can he also use this guide? Also if it possible how do u wire it? Im just a beginner so i ask stupid questions. maybe serial gateway is the way to go but we are waiting for arduino's
                • mfalkviddM
                  @Eawo Yes, it should work. I ran Domoticz and MySensors Gateway on my Raspberry Pi 1 when I first tried MySensors. If I remember correctly I had to connect CE to pin 15 instead of 22 but I am not sure why. Try using the same connections as on your Raspberry Pi 2 first, and switch CE pin if you get "check wires". Please report back here how it goes, so I can add the necessary information to the original post.
                  • OitzuO
                    OitzuO
                    Oitzu
                    I get stuff like
                    read: 2-2-0 s=255,c=0,t=17,pt=0,l=3:1.5
                    send: 2-194-1-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.5
                    read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
                    send: 2-194-1-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                    read: 2-2-0 s=1,c=1,t=2,pt=2,l=2:1
                    send: 2-194-1-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
                    from 'PiGatewaySerial' but no results on the Serial Port. Any idea what i'm doing wrong?
                    • OitzuO
                      OitzuO
                      Oitzu
                      Somehow the node thought it is node id 194 and a repeater...
                      I hacked in node id 0 and it worked. But it even works slower then the arduino serial gateway.
                      • mfalkviddM
                        In http://forum.mysensors.org/topic/2305/nrf24l01-rpi2-direct-connection-problem/1 an user also got node id 194. Maybe the discussion there can help?
                        • J
                          J
                          jpbabou
                          wrote on last edited by jpbabou
                          #29
                          Hi
                          something is missing..
                          Is there a problem with the repository
                          Tks a lot for your job!
                          pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
                          Cloning into 'Raspberry'...
                          remote: Counting objects: 273, done.
                          remote: Compressing objects: 100% (3/3), done.
                          remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
                          Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
                          Resolving deltas: 100% (114/114), done.
                          Checking connectivity... done.
                          pi@domoticjp ~ $ cd Raspberry/librf24-bcm
                          -bash: cd: Raspberry/librf24-bcm: No such file or directory
                          alexsh1A mfalkviddM 2 Replies Last reply
                          • mfalkviddM
                            Ah yes, the guide became invalid yesterday when a PR was merged. I'll update the guide, thanks for noticing.
                            Information about how to get the rf library is available in the readme in the Raspberry folder if you want to get going.
                              msantang
                              wrote on last edited by msantang
                              #31
                              I got it working on my rb2 but i got 100% of cpu ussage.
                              I read a lot of post about this but i cant found a solution.
                              Some one know how to fix this?
                              OitzuO 1 Reply Last reply
                              • J jpbabou
                                Hi
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @jpbabou said:
                                Hi
                                Please go ahead and install the rf24 library from https://github.com/TMRh20/RF24
                                The rest should be the same
                                • M msantang
                                  OitzuO
                                  OitzuO
                                  Oitzu
                                  wrote on last edited by Oitzu
                                  #33
                                  The 100% cpu usage is probably due to the style of receiving new messages from rf24/serial port.
                                  The current state is that the PiSerialGateway tries to poll data in a endless loop from rf24/serial.
                                  This could maybe fixed with using the interrupt of the nrf24l01+ to signal new data and reading data from the serial in blocking mode.
                                  I want to solve this but using interrupts on the RPi isn't that trivial.
                                  • mfalkviddM
                                    http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/2 has information on how to use interrupts. I haven't tried it myself though.
                                      OitzuO
                                      OitzuO
                                      Oitzu
                                      Oh yeah, thanks for the hint @Bens got the exact same problem and seem to solved the rf24 part already. I hope he gets back online and shares his results. :)
                                      • D
                                        den2k
                                        Hi all,
                                        I'm following this thread and have upgraded to MySensors v1.5 and get the following error. Version mismatch.
                                        It looks like the Protocol version is 1.4.
                                        Does the Raspberry MySensors Gateway support v1.5 or only v1.4? Any ideas on how to fix?
                                        upload-27647566-60ff-4341-97aa-4d1186e5e670
                                        alexsh1A 1 Reply Last reply
                                        • D den2k
                                          Hi all,
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @den2k said:
                                          Hi all,
                                          Up until now, MySensors v1.4 only for nrf24l01+ direct connection.
                                          Did you upgrade the GW or the sensors or both ?
                                          D 1 Reply Last reply
