  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 209.7k Views 36 Watching
  • mfalkviddM
    @Eawo Yes, it should work. I ran Domoticz and MySensors Gateway on my Raspberry Pi 1 when I first tried MySensors. If I remember correctly I had to connect CE to pin 15 instead of 22 but I am not sure why. Try using the same connections as on your Raspberry Pi 2 first, and switch CE pin if you get "check wires". Please report back here how it goes, so I can add the necessary information to the original post.
    • OitzuO
      OitzuO
      Oitzu
      I get stuff like
      read: 2-2-0 s=255,c=0,t=17,pt=0,l=3:1.5
      send: 2-194-1-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.5
      read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
      send: 2-194-1-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
      read: 2-2-0 s=1,c=1,t=2,pt=2,l=2:1
      send: 2-194-1-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
      from 'PiGatewaySerial' but no results on the Serial Port. Any idea what i'm doing wrong?
      • OitzuO
        OitzuO
        Oitzu
        Somehow the node thought it is node id 194 and a repeater...
        I hacked in node id 0 and it worked. But it even works slower then the arduino serial gateway.
        • mfalkviddM
          In http://forum.mysensors.org/topic/2305/nrf24l01-rpi2-direct-connection-problem/1 an user also got node id 194. Maybe the discussion there can help?
          • J
            J
            jpbabou
            wrote on last edited by jpbabou
            #29
            Hi
            something is missing..
            Is there a problem with the repository
            Tks a lot for your job!
            pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
            Cloning into 'Raspberry'...
            remote: Counting objects: 273, done.
            remote: Compressing objects: 100% (3/3), done.
            remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
            Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
            Resolving deltas: 100% (114/114), done.
            Checking connectivity... done.
            pi@domoticjp ~ $ cd Raspberry/librf24-bcm
            -bash: cd: Raspberry/librf24-bcm: No such file or directory
            alexsh1A mfalkviddM 2 Replies Last reply
            • mfalkviddM
              Ah yes, the guide became invalid yesterday when a PR was merged. I'll update the guide, thanks for noticing.
              Information about how to get the rf library is available in the readme in the Raspberry folder if you want to get going.
                msantang
                wrote on last edited by msantang
                #31
                I got it working on my rb2 but i got 100% of cpu ussage.
                I read a lot of post about this but i cant found a solution.
                Some one know how to fix this?
                OitzuO 1 Reply Last reply
                • J jpbabou
                  Hi
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @jpbabou said:
                  Hi
                  Please go ahead and install the rf24 library from https://github.com/TMRh20/RF24
                  The rest should be the same
                  • M msantang
                    OitzuO
                    OitzuO
                    Oitzu
                    wrote on last edited by Oitzu
                    #33
                    The 100% cpu usage is probably due to the style of receiving new messages from rf24/serial port.
                    The current state is that the PiSerialGateway tries to poll data in a endless loop from rf24/serial.
                    This could maybe fixed with using the interrupt of the nrf24l01+ to signal new data and reading data from the serial in blocking mode.
                    I want to solve this but using interrupts on the RPi isn't that trivial.
                    • mfalkviddM
                      http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/2 has information on how to use interrupts. I haven't tried it myself though.
                        OitzuO
                        OitzuO
                        Oitzu
                        Oh yeah, thanks for the hint @Bens got the exact same problem and seem to solved the rf24 part already. I hope he gets back online and shares his results. :)
                        • D
                          den2k
                          Hi all,
                          I'm following this thread and have upgraded to MySensors v1.5 and get the following error. Version mismatch.
                          It looks like the Protocol version is 1.4.
                          Does the Raspberry MySensors Gateway support v1.5 or only v1.4? Any ideas on how to fix?
                          upload-27647566-60ff-4341-97aa-4d1186e5e670
                          alexsh1A 1 Reply Last reply
                          • D den2k
                            Hi all,
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @den2k said:
                            Hi all,
                            Up until now, MySensors v1.4 only for nrf24l01+ direct connection.
                            Did you upgrade the GW or the sensors or both ?
                            D 1 Reply Last reply
                              Protocol version hasn't changed since 1.4
                              https://github.com/mysensors/Raspberry/blob/master/MyMessage.h#L41
                              So you must have some other problem.. As you can see you only get zeroes in the log...
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                #39
                                You can "fake" a later version (e.g, 1.5) on the Raspberry by changing the version code in the version.h file and recompiling the Gateway software.
                                As far as I understand, the gateway will still pass the messages to the controller, even is there is a version mismatch message on the console.
                                • alexsh1A alexsh1
                                  @den2k said:
                                  Hi all,
                                  den2k
                                  @alexsh1 I know the sensors are on v1.5. As for the Raspberry Gateway, it looks like based on the info here, that is running v1.4.
                                    den2k
                                    @hek I'm running a custom 1Mhz build bootloader on a Pro Mini for the Sensor side. This was paired with the standard Serial Gateway running on another Pro Mini with v1.5 on both gateway and sensor. That setup was working. But I moved over to using the Pi gatway+nRF24+ radio and have this issue. I don't believe the hookup is the problem. I've seen the 0 readings before, and that usually meant node side issue or uninitiated Gateway. I have not changed the Node, so it must be the Pi gateway that is the problem. Any thoughts on what to test?
                                    • D
                                      den2k
                                      Noob question. Any one have an idea on solving the "Permission denied" error.
                                      upload-a7ed9c85-5b6b-4198-af00-909e1861374e
                                      • D
                                        den2k
                                        Solved my own problem. Using the following command did the trick.
                                        sudo chown -h pi:pi ttyUSB20
                                        • D
                                          den2k
                                          weird. Permission Denied problem again.
                                          What is the USER : GROUP that is needed for this to work?
