Ethernet Gateway not showing on network
I've built an ethernet gateway with a genuine Arduino Uno and an ENC28J60 ethernet module. I was getting a check wires error until I started powering the ENC28J60 with a seperate power supply. Now I am getting the Gateway Startup Complete message, which is great, but when I try to ping my device it is not on my network.
Here is my sketch if that is helpful:
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik EKblad * Contribution by a-lurker and Anticimex, * Contribution by Norbert Truchsess <norbert.truchsess@t-online.de> * * * DESCRIPTION * The EthernetGateway sends data received from sensors to the ethernet link. * The gateway also accepts input on ethernet interface, which is then sent out to the radio network. * * The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program. * * * COMPILING WIZNET (W5100) ETHERNET MODULE * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI"). * * COMPILING ENC28J60 ETHERNET MODULE * > Use Arduino IDE 1.5.7 (or later) * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading. * > Remove Ethernet.h include below and include UIPEthernet.h * > Remove DigitalIO include * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module) * * VERA CONFIGURATION: * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin. * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003 * * LED purposes: * - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly * - ERR (red) - fast blink on error during transmission error or recieve crc error * * See http://www.mysensors.org/build/ethernet_gateway for wiring instructions. * */ #define NO_PORTB_PINCHANGES //#include <DigitalIO.h> // This include can be removed when using UIPEthernet module #include <SPI.h> #include <MySigningNone.h> #include <MyTransportRFM69.h> #include <MyTransportNRF24.h> #include <MyHwATMega328.h> #include <MySigningAtsha204Soft.h> #include <MySigningAtsha204.h> #include <MyParserSerial.h> #include <MySensor.h> #include <stdarg.h> #include <PinChangeInt.h> #include "GatewayUtil.h" // Use this if you have attached a Ethernet ENC28J60 shields #include <UIPEthernet.h> // Use this for WizNET W5100 module and Arduino Ethernet Shield //#include <Ethernet.h> #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button #define RADIO_CE_PIN 5 // radio chip enable #define RADIO_SPI_SS_PIN 6 // radio SPI serial select #define RADIO_ERROR_LED_PIN 7 // Error led pin #define RADIO_RX_LED_PIN 8 // Receive led pin #define RADIO_TX_LED_PIN 9 // the PCB, on board LED // NRFRF24L01 radio driver (set low transmit power by default) MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW); //MyTransportRFM69 transport; // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h) //MySigningNone signer; //MySigningAtsha204Soft signer; //MySigningAtsha204 signer; // Hardware profile MyHwATMega328 hw; // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h) // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h #ifdef WITH_LEDS_BLINKING MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN); #else MySensor gw(transport, hw /*, signer*/); #endif #define IP_PORT 5003 // The port you want to open IPAddress myIp (192, 168, 1, 25); // Configure your static ip-address here COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later! // The MAC address can be anything you want but should be unique on your network. // Newer boards have a MAC address printed on the underside of the PCB, which you can (optionally) use. // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address. byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // DEAD BEEF FEED // a R/W server on the port EthernetServer server = EthernetServer(IP_PORT); // handle to open connection EthernetClient client = EthernetClient(); char inputString[MAX_RECEIVE_LENGTH] = ""; // A string to hold incoming commands from serial/ethernet interface int inputPos = 0; bool sentReady = false; void output(const char *fmt, ... ) { va_list args; va_start (args, fmt ); vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args); va_end (args); Serial.print(serialBuffer); server.write(serialBuffer); } void setup() { Ethernet.begin(mac, myIp); setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output); // Add interrupt for inclusion button to pin PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING); // give the Ethernet interface a second to initialize delay(1000); // Initialize gateway at maximum PA level, channel 70 and callback for write operations gw.begin(incomingMessage, 0, true, 0); // start listening for clients server.begin(); } void loop() { gw.process(); checkButtonTriggeredInclusion(); checkInclusionFinished(); // if an incoming client connects, there will be // bytes available to read via the client object EthernetClient newclient = server.available(); // if a new client connects make sure to dispose any previous existing sockets if (newclient) { if (client != newclient) { client.stop(); client = newclient; output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"), C_INTERNAL, I_GATEWAY_READY); } } if (client) { if (!client.connected()) { client.stop(); } else if (client.available()) { // read the bytes incoming from the client char inChar = client.read(); if (inputPos<MAX_RECEIVE_LENGTH-1) { // if newline then command is complete if (inChar == '\n') { Serial.println("Finished"); // a command was issued by the client // we will now try to send it to the actuator inputString[inputPos] = 0; // echo the string to the serial port Serial.print(inputString); parseAndSend(gw, inputString); // clear the string: inputPos = 0; } else { // add it to the inputString: inputString[inputPos] = inChar; inputPos++; } } else { // Incoming message too long. Throw away inputPos = 0; } } } } -
I've updated with no luck. Here is my serial monitor output:
0;0;3;0;9;Starting gateway (1.6.0-beta)
0;0;3;0;9;Radio init successful.
IP: 192.168.1.25
0;0;3;0;9;Init complete, id=0, parent=0, distance=0When I ping 192.168.1.25, I get "Destination host unreachable."
I have the same problem.
I'm building a mqtt gateway with a dccduino and a ENC28J60 ethernet module, 1.6.6 Arduino IDE, 1.5 mysensors library.
I used the mysensors sketch for mqtt gateway and your sketch with the same results.
After that I tried the webserver sketch example from the arduino IDE and ... it works : I can ping the ethernert card and reach the arduino webserver.
Then my wiring is right and I think something wrong in mysensors library. -
For me the problem was the hang in setup at gw.begin call.
I solved reading this old topic : http://forum.mysensors.org/topic/773/ethernetgateway-hangs-after-gateway-startup-complete.
