  3. Ethernet Gateway not showing on network
5 Posts 3 Posters 2.6k Views
    spork
    I've built an ethernet gateway with a genuine Arduino Uno and an ENC28J60 ethernet module. I was getting a check wires error until I started powering the ENC28J60 with a seperate power supply. Now I am getting the Gateway Startup Complete message, which is great, but when I try to ping my device it is not on my network.
    Here is my sketch if that is helpful:
     * Version 1.0 - Henrik EKblad
     * COMPILING WIZNET (W5100) ETHERNET MODULE
     * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI").
     * COMPILING ENC28J60 ETHERNET MODULE
     * > Use Arduino IDE 1.5.7 (or later)
     * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
     * > Remove Ethernet.h include below and include UIPEthernet.h
     * > Remove DigitalIO include
     * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
     * VERA CONFIGURATION:
     * LED purposes:
    #define NO_PORTB_PINCHANGES
    //#include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <MyParserSerial.h>
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    // Use this if you have attached a Ethernet ENC28J60 shields
     #include <UIPEthernet.h>
    // Use this for WizNET W5100 module and Arduino Ethernet Shield
    //#include <Ethernet.h>
    #define RADIO_CE_PIN        5  // radio chip enable
    #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
    #define RADIO_ERROR_LED_PIN 7  // Error led pin
    #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
    //MyTransportRFM69 transport;
    //MySigningNone signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    #define IP_PORT 5003        // The port you want to open
    IPAddress myIp (192, 168, 1, 25);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
    // a R/W server on the port
    EthernetServer server = EthernetServer(IP_PORT);
    // handle to open connection
    EthernetClient client = EthernetClient();
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    bool sentReady = false;
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       va_end (args);
       Serial.print(serialBuffer);
       server.write(serialBuffer);
      Ethernet.begin(mac, myIp);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
      // give the Ethernet interface a second to initialize
      delay(1000);
      server.begin();
      checkInclusionFinished();
      // if an incoming client connects, there will be
      // bytes available to read via the client object
      EthernetClient newclient = server.available();
      // if a new client connects make sure to dispose any previous existing sockets
      if (newclient) {
          if (client != newclient) {
           client.stop();
           client = newclient;
           output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
       if (client) {
         if (!client.connected()) {
           client.stop();
         } else if (client.available()) {
           // read the bytes incoming from the client
           char inChar = client.read();
           if (inputPos<MAX_RECEIVE_LENGTH-1) {
             // if newline then command is complete
             if (inChar == '\n') {
               Serial.println("Finished");
                // a command was issued by the client
                // we will now try to send it to the actuator
                inputString[inputPos] = 0;
                // echo the string to the serial port
                Serial.print(inputString);
                parseAndSend(gw, inputString);
                // clear the string:
                inputPos = 0;
               // add it to the inputString:
               inputString[inputPos] = inChar;
               inputPos++;
             inputPos = 0;
      You might wanna update to the development branch and try the ENC-gateway sketch there.
        spork
        I've updated with no luck. Here is my serial monitor output:
        0;0;3;0;9;Starting gateway (1.6.0-beta)
        0;0;3;0;9;Radio init successful.
        IP: 192.168.1.25
        0;0;3;0;9;Init complete, id=0, parent=0, distance=0
        When I ping 192.168.1.25, I get "Destination host unreachable."
        • G
          G
          giova
          I have the same problem.
          I'm building a mqtt gateway with a dccduino and a ENC28J60 ethernet module, 1.6.6 Arduino IDE, 1.5 mysensors library.
          I used the mysensors sketch for mqtt gateway and your sketch with the same results.
          After that I tried the webserver sketch example from the arduino IDE and ... it works : I can ping the ethernert card and reach the arduino webserver.
          Then my wiring is right and I think something wrong in mysensors library.
          • G
            G
            giova
            For me the problem was the hang in setup at gw.begin call.
            I solved reading this old topic : http://forum.mysensors.org/topic/773/ethernetgateway-hangs-after-gateway-startup-complete.
