  3. OpenHAB
  4. Serial Gateway connection to Openhab
development ope
86 Posts 16 Posters 94.1k Views 10 Watching
  • T TimO
    The access to the serial port is exclusive, stop OpenHAB to access the serial port of The gateway with the arduino IDE.
    E
    E
    ewgor
    @TimO i saw that I can access the gateway and see what node point transmit but as you say without having the server start.
    How do I see temp and hum on the local host? And what do I need to do to switch the two LEDs from local host?
    As always, thanks for sharing a little part of your experience :)
    • T
      TimO
      Use something like this in the rules file:
      For a button (always sends on when activated):
      rule "Licht Flur EG"
              when
                      Item corridorLight01 received update
              then
                      sendCommand(Arduino, "102;1;1;0;2;1\n")
      For a switch use something like
      rule "Küche"
              when
                      Item kitchenLight01 received command
              then
                      if(receivedCommand==ON) {
                      if(receivedCommand==OFF) {
                              sendCommand(Arduino, "102;1;1;0;2;0\n")
      end
      • E
        E
        ewgor
        So TimO you say your example above (arduinos sketches for the serial gateway and the 2nd one for temp, hum and two switches + openhab items, rules and sitemap) is not working? i just followed and nothing happen ... still strugling. Now you give me this example which has nothing to do with your example. If i want to use it i need to modify all files and i dont know how!
        Can anyone help me??
        • T
          TimO
          Well, I thought your base is my tutorial: http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
          The advantage of OpenHAB is, you're very free and are able to do things you like to do. The disadvantage is, you currently have to "program" your rules.
          It would help to know your OpenHAB configurations, sketches and so on, because I'm using my own OpenHAB (and MySensors) configuration/installation, that certainly is not the best configuration für everyone.
          (But it works the way I want it to work ;-))
          You only asked for (and got) pieces of the puzzle, you have to put it together by yourself or ask for the complete solution, as you did in another thread. :D
          E 1 Reply Last reply
          • T TimO
            E
            E
            ewgor
            @TimO
            I see, so if are not a programmer and you don't know how to make your own sketches (arduino, rules) you don't have any chance to make your own project .... i thought, being open source and asking for help in a community where you can find a lot of guys who have idea about the subject, maybe you can make it easier without spending hours and hours just to come back to the same place you started , moreover without a solution.
            Anyhow, thanks a lot, with the help you gave i am almost there but i think i still need to wait maybe a half year till i'll see my project on :(
            • E
              E
              ewgor
              Can anyone help? I'm trying to move my server from my laptop to my raspberry pi 2 and I'm having problems.
              I changed the port in the items file with
              "String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }"
              And now the server receive the commands from my laptop or from my phone but it not sends the info to the node point and it not receive info from the node point too.
              If I start the server from my laptop with start.bat it works but when I start the server from my pi with
              Sudo /opt/openhab/start.sh it acts as I said above!
              Can anyone please help me understand what I'm missing?
              • T
                TimO
                Try to connect with a terminal software like miniterm to /dev/ttyUSB0 and check if data from the serial gateway is received.
                miniterm.py -b 115200 -p /dev/ttyUSB0
                You may have to install miniterm first.
                • T TimO
                  E
                  E
                  ewgor
                  @TimO i solved following your tutorial here with dmesg and checking for what usb name rpi have for the gateway. Still not did those steps for a permanent usb but its on going.
                  • T TimO
                    @CARSTEN I've compiled a modified version of the OpenHab Serial binding with a baud rate of 115200 as this is standard in mysensors.
                    Download: org.openhab.binding.serial_1.6.0.201411271703.jar
                    As @tboha suggested you currently have to manage all commands by yourself.
                    I've attached my modified serial binding here. Please be aware, that all other configurations that depend on serial binding won't work with the modified version, because of the changed baud rate.
                    I'm currently testing with this Serial Gateway:
                    Serial Gateway
                    Here is my OpenHab configuration for simple testing:
                    demo.items: demo.items
                    demo.rules: demo.rules
                    demo.sitemap: demo.sitemap
                    F
                    F
                    Fay Candiliari
                    wrote on last edited by Fay Candiliari
                    #76
                    @TimO Hi TimO! This is Fay from codebender.cc Thank you for using codebender! I just wanted to let you know that one of the sketches you are using in this comment has been deleted and so it is not available for users to view it. Let me know if you have any question. :)
                    hekH 1 Reply Last reply
                    • T
                      TimO
                      @Fay-Candiliari : Thank you very much for the hint!
                      F 1 Reply Last reply
                      • F Fay Candiliari
                        wrote on last edited by hek
                        #78
                        @Fay-Candiliari
                        Hi @Fay-Candiliari , Nice to see you here!
                        • T TimO
                          F
                          F
                          Fay Candiliari
                          @TimO You are welcome :)
                            @Fay-Candiliari
                            F
                            F
                            Fay Candiliari
                            Hi @hek Likewise! :)
                            • K
                              K
                              knoid
                              I'm having trouble with test.rules when two switches change its values really quickly one after the other. I can do that in a couple of tries via the web UI or the android UI. This is the output that looks odd:
                              2016-01-05 19:39:54.405 [INFO ] [runtime.busevents             ] - relay01 received command ON
                              2016-01-05 19:39:54.469 [INFO ] [runtime.busevents             ] - relay02 received command ON
                              Function: switchOperation >> 1;1;1;1;2;1
                              Function: switchOperation >> 1;2;1;1;2;1
                              2016-01-05 19:39:54.772 [INFO ] [runtime.busevents             ] - Arduino received command 1;1;1;0;2;1
                              2016-01-05 19:39:54.797 [INFO ] [runtime.busevents             ] - Arduino received command 1;2;1;0;2;1
                              2016-01-05 19:39:55.033 [INFO ] [runtime.busevents             ] - relay01 received command ON
                              2016-01-05 19:39:55.338 [INFO ] [runtime.busevents             ] - relay02 state updated to ON
                              2016-01-05 19:39:55.398 [INFO ] [runtime.busevents             ] - relay02 state updated to ON
                              Light Item: relay02 Light: ON
                              As you can see, it starts fine but at the end it is talking about the same relay twice and I end up with just one relay on. It actually looks like an openhab issue but I'm not sure.
                              Any help is appreciated.
                              • aaron832A
                                aaron832A
                                aaron832
                                I am having the same issue. When I start my sensor, it sends a lot of information seemingly at once. The rule gets confused and runs the rule multiple times on one serial command (rather than each individually).
                                Notice below the "Arduino" item is getting updates frequently. Below that is my output in the rule to handle the update. Notice it prints multiple 105;0;0;0;7; in place of the other inputs (105;255;3;0;15; for example)
                                2016-01-26 16:15:36.414 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;15;
                                2016-01-26 16:15:36.418 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;0;0;17;2.0.0-beta
                                2016-01-26 16:15:36.425 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;6;0
                                2016-01-26 16:15:36.429 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;11;Garage Sensor
                                2016-01-26 16:15:36.433 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;12;1.0
                                2016-01-26 16:15:36.438 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;0;0;0;7;
                                2016-01-26 16:15:36.557 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;1;1;0;0;68.0
                                2016-01-26 16:15:37.058 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;0;1;0;1;36.0
                                105;0;0;0;7;
                                105;0;0;0;7;
                                105;0;0;0;7;
                                105;0;0;0;7;
                                105;1;1;0;0;68.0
                                105;0;1;0;1;36.0
                                105;0;0;0;7;
                                105;0;0;0;7;
                                • aaron832A
                                  aaron832A
                                  aaron832
                                  wrote on last edited by aaron832
                                  #83
                                  @knoid
                                  Found out that you can use locks in the rules to prevent uncertainty with the "Arduino" variable caused from multiple instances of the rule running simultaneously.
                                  Example:
                                  import java.util.concurrent.locks.ReentrantLock
                                  var java.util.concurrent.locks.ReentrantLock lock  = new java.util.concurrent.locks.ReentrantLock()
                                      rule "Arduino sends to Openhab"
                                      when
                                          Item Arduino received update
                                      then
                                          lock.lock()
                                          try {
                                              // do stuff (e.g. create and start a timer ...)
                                          } finally{
                                             lock.unlock()
                                      end
                                  • T
                                    TimO
                                    Cool! Thanks for sharing!
                                    • edsteveE
                                      edsteveE
                                      edsteve
                                      wrote on last edited by edsteve
                                      #85
                                      I know... it's an old thread. And i know openHAB2 is there. But it's still Alpha and i am beginner. Maybe not a good idea ;)
                                      Somehow my sensors will not bind. I downloaded and installed all fresh.
                                      When i start openHAB with sudo it loads normal but nodes never connected to openHAB :(
                                      EDIT:
                                      I just made a new install combined the infos from these instructions and that worked for me:
                                      https://github.com/openhab/openhab/wiki/Linux-and-OS-X#apt-get
                                      http://www.makeuseof.com/tag/getting-started-openhab-home-automation-raspberry-pi/
                                      Thx for your answer Tim0 and sorry for posting in wrong thread
                                      • T
                                        TimO
                                        Hey @edsteve !
                                        This thread mainly covers the serial connection via the serial binding and by using rules.
                                        You are using the binding for OH1, so I suggest to start a new thread or trigger @bkl. :-)
