  3. OpenHAB
  4. Serial Gateway connection to Openhab
development ope
86 Posts 16 Posters 94.1k Views 10 Watching
  • E
    E
    ewgor
    wrote on last edited by ewgor
    #63
    Anyone, any idea how to test the serial gateway? At this point on the serial monitor i get 0;0;3;0;14;Gateway startup complete. How to test it with Openhab? PLS HELP :)
    For gateway im using a UNO and i try to have my mega as a node point. If i use Arduino Mega as a gateway its ok, i couldnt find any connection scheme for the node point (mega or uno). Right now i see on the serial monitor of the node point check wires and on the gateway startup complete! Where is the problem? how to connect the node point with my relays and what should i see on the serial monitor? Again somebody pls help me understand how to test it with Openhab?
    • T
      TimO
      For the Arduino Mega you have to change the connections. Check out this thread:
      http://forum.mysensors.org/topic/249/arduino-mega-sensor-shield-2
      When the "node point" starts up fine you should see a lot of messages coming on the serial monitor of the gateway. Then the communication between both nodes is working.
      E 1 Reply Last reply
      • T TimO
        E
        E
        ewgor
        @TimO with your help again i managed to find the right pins on my mega and now with my dht11 connected i get the temp and hum values constantly. On the server side when i start the bat file or sh file i get the values on the node serial monitor but nothing apears on the localhost.
        there are any changes that needs to be done in the items, rules or the sitemap?
        thanks for replay.
        • E
          E
          ewgor
          #66
          today, trying to make it work i discovered that if i start the Openhab server i get the DHT11 values on the server and i can access the serial monitor of the node point but when i switch the arduino IDE to the serial gateway com4 i get this errors on the arduino IDE and i cannot acces the serial monitor:
          Arduino: 1.5.8 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
          processing.app.SerialException: Error opening serial port 'COM4'.
          	at processing.app.Serial.<init>(Serial.java:145)
          	at processing.app.Serial.<init>(Serial.java:90)
          	at processing.app.SerialMonitor.open(SerialMonitor.java:93)
          	at processing.app.Editor.handleSerial(Editor.java:2537)
          	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:357)
          	at java.awt.Component.processMouseEvent(Unknown Source)
          	at javax.swing.JComponent.processMouseEvent(Unknown Source)
          	at java.awt.Component.processEvent(Unknown Source)
          	at java.awt.Container.processEvent(Unknown Source)
          	at java.awt.Component.dispatchEventImpl(Unknown Source)
          	at java.awt.Container.dispatchEventImpl(Unknown Source)
          	at java.awt.Component.dispatchEvent(Unknown Source)
          	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
          	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
          	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
          	at java.awt.Window.dispatchEventImpl(Unknown Source)
          	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
          	at java.awt.EventQueue.access$200(Unknown Source)
          	at java.awt.EventQueue$3.run(Unknown Source)
          	at java.security.AccessController.doPrivileged(Native Method)
          	at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
          	at java.awt.EventQueue$4.run(Unknown Source)
          	at java.awt.EventQueue.dispatchEvent(Unknown Source)
          	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
          	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
          	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
          	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
          	at java.awt.EventDispatchThread.run(Unknown Source)
          Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port busy.
          	at jssc.SerialPort.openPort(SerialPort.java:164)
          	at processing.app.Serial.<init>(Serial.java:141)
          	... 35 more
          On the serial monitor of the node point i receive this:
          repeater started, id 101
          send: 101-101-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
          send: 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          send: 101-101-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
          send: 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
          send: 101-101-0-0 s=1,c=0,t=3,pt=0,l=0,st=fail:
          send: 101-101-0-0 s=2,c=0,t=3,pt=0,l=0,st=ok:
          send: 101-101-0-0 s=0,c=0,t=7,pt=0,l=0,st=ok:
          send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=0,st=ok:
          Failed reading humidity from DHT
          Failed reading temperature from DHT
          send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:31.0
          T: 31.00
          send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:30.0
          T: 30.00
          T: 31.00
          and on the Openhab start.bat i see this:
          2015-07-15 17:48:14.153 [INFO ] [runtime.busevents             ] - Arduino state
           updated to 0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=5:Relay
          101;255;3;0;11;Relay
          0;0;3;0;9;read: 101-101-0 s=255,c=3,t=12,pt=0,l=3:1.0
          101;255;3;0;12;1.0
          0;0;3;0;9;read: 101-101-0 s=1,c=0,t=3,pt=0,l=0:
          101;1;0;0;3;
          0;0;3;0;9;read: 101-101-0 s=2,c=0,t=3,pt=0,l=0:
          101;2;0;0;3;
          0;0;3;0;9;read: 101-101-0 s=0,c=0,t=7,pt=0,l=0:
          101;0;0;0;7;
          0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=0:
          101;1;0;0;6;
          ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=5:Relay
          101;255;3;0;12;1.0
          101;1;0;0;3;
          101;2;0;0;3;
          101;0;0;0;7;
          101;1;0;0;6;
          2015-07-15 17:48:15.171 [INFO ] [runtime.busevents             ] - Arduino state
           updated to 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:31.0
          101;1;1;0;0;31.0
          ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:31.0
          101;1;1;0;0;31.0
          2015-07-15 17:48:44.203 [INFO ] [runtime.busevents             ] - Arduino state
           updated to 0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:35.0
          101;0;1;0;1;35.0
          ArduinoUpdate -> 0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:35.0
          101;0;1;0;1;35.0
          help :)
          • T
            TimO
            The access to the serial port is exclusive, stop OpenHAB to access the serial port of The gateway with the arduino IDE.
            • T TimO
              E
              E
              ewgor
              @TimO i saw that I can access the gateway and see what node point transmit but as you say without having the server start.
              How do I see temp and hum on the local host? And what do I need to do to switch the two LEDs from local host?
              As always, thanks for sharing a little part of your experience :)
              • T
                TimO
                Use something like this in the rules file:
                For a button (always sends on when activated):
                rule "Licht Flur EG"
                        when
                                Item corridorLight01 received update
                        then
                                sendCommand(Arduino, "102;1;1;0;2;1\n")
                For a switch use something like
                rule "Küche"
                        when
                                Item kitchenLight01 received command
                        then
                                if(receivedCommand==ON) {
                                if(receivedCommand==OFF) {
                                        sendCommand(Arduino, "102;1;1;0;2;0\n")
                end
                • E
                  E
                  ewgor
                  So TimO you say your example above (arduinos sketches for the serial gateway and the 2nd one for temp, hum and two switches + openhab items, rules and sitemap) is not working? i just followed and nothing happen ... still strugling. Now you give me this example which has nothing to do with your example. If i want to use it i need to modify all files and i dont know how!
                  Can anyone help me??
                  • T
                    TimO
                    Well, I thought your base is my tutorial: http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
                    The advantage of OpenHAB is, you're very free and are able to do things you like to do. The disadvantage is, you currently have to "program" your rules.
                    It would help to know your OpenHAB configurations, sketches and so on, because I'm using my own OpenHAB (and MySensors) configuration/installation, that certainly is not the best configuration für everyone.
                    (But it works the way I want it to work ;-))
                    You only asked for (and got) pieces of the puzzle, you have to put it together by yourself or ask for the complete solution, as you did in another thread. :D
                    • T TimO
                      E
                      E
                      ewgor
                      @TimO
                      I see, so if are not a programmer and you don't know how to make your own sketches (arduino, rules) you don't have any chance to make your own project .... i thought, being open source and asking for help in a community where you can find a lot of guys who have idea about the subject, maybe you can make it easier without spending hours and hours just to come back to the same place you started , moreover without a solution.
                      Anyhow, thanks a lot, with the help you gave i am almost there but i think i still need to wait maybe a half year till i'll see my project on :(
                      • E
                        E
                        ewgor
                        Can anyone help? I'm trying to move my server from my laptop to my raspberry pi 2 and I'm having problems.
                        I changed the port in the items file with
                        "String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }"
                        And now the server receive the commands from my laptop or from my phone but it not sends the info to the node point and it not receive info from the node point too.
                        If I start the server from my laptop with start.bat it works but when I start the server from my pi with
                        Sudo /opt/openhab/start.sh it acts as I said above!
                        Can anyone please help me understand what I'm missing?
                        • T
                          TimO
                          Try to connect with a terminal software like miniterm to /dev/ttyUSB0 and check if data from the serial gateway is received.
                          miniterm.py -b 115200 -p /dev/ttyUSB0
                          You may have to install miniterm first.
                          • T TimO
                            E
                            E
                            ewgor
                            @TimO i solved following your tutorial here with dmesg and checking for what usb name rpi have for the gateway. Still not did those steps for a permanent usb but its on going.
                            • T TimO
                              @CARSTEN I've compiled a modified version of the OpenHab Serial binding with a baud rate of 115200 as this is standard in mysensors.
                              Download: org.openhab.binding.serial_1.6.0.201411271703.jar
                              As @tboha suggested you currently have to manage all commands by yourself.
                              I've attached my modified serial binding here. Please be aware, that all other configurations that depend on serial binding won't work with the modified version, because of the changed baud rate.
                              I'm currently testing with this Serial Gateway:
                              Serial Gateway
                              Here is my OpenHab configuration for simple testing:
                              demo.items: demo.items
                              demo.rules: demo.rules
                              demo.sitemap: demo.sitemap
                              F
                              F
                              Fay Candiliari
                              wrote on last edited by Fay Candiliari
                              #76
                              @TimO Hi TimO! This is Fay from codebender.cc Thank you for using codebender! I just wanted to let you know that one of the sketches you are using in this comment has been deleted and so it is not available for users to view it. Let me know if you have any question. :)
                              hekH 1 Reply Last reply
                              • T
                                TimO
                                @Fay-Candiliari : Thank you very much for the hint!
                                F 1 Reply Last reply
                                • F Fay Candiliari
                                  wrote on last edited by hek
                                  #78
                                  @Fay-Candiliari
                                  Hi @Fay-Candiliari , Nice to see you here!
                                  • T TimO
                                    F
                                    F
                                    Fay Candiliari
                                    @TimO You are welcome :)
                                      @Fay-Candiliari
                                      F
                                      F
                                      Fay Candiliari
                                      Hi @hek Likewise! :)
                                      • K
                                        K
                                        knoid
                                        I'm having trouble with test.rules when two switches change its values really quickly one after the other. I can do that in a couple of tries via the web UI or the android UI. This is the output that looks odd:
                                        2016-01-05 19:39:54.405 [INFO ] [runtime.busevents             ] - relay01 received command ON
                                        2016-01-05 19:39:54.469 [INFO ] [runtime.busevents             ] - relay02 received command ON
                                        Function: switchOperation >> 1;1;1;1;2;1
                                        Function: switchOperation >> 1;2;1;1;2;1
                                        2016-01-05 19:39:54.772 [INFO ] [runtime.busevents             ] - Arduino received command 1;1;1;0;2;1
                                        2016-01-05 19:39:54.797 [INFO ] [runtime.busevents             ] - Arduino received command 1;2;1;0;2;1
                                        2016-01-05 19:39:55.033 [INFO ] [runtime.busevents             ] - relay01 received command ON
                                        2016-01-05 19:39:55.338 [INFO ] [runtime.busevents             ] - relay02 state updated to ON
                                        2016-01-05 19:39:55.398 [INFO ] [runtime.busevents             ] - relay02 state updated to ON
                                        Light Item: relay02 Light: ON
                                        As you can see, it starts fine but at the end it is talking about the same relay twice and I end up with just one relay on. It actually looks like an openhab issue but I'm not sure.
                                        Any help is appreciated.
                                        • aaron832A
                                          aaron832A
                                          aaron832
                                          I am having the same issue. When I start my sensor, it sends a lot of information seemingly at once. The rule gets confused and runs the rule multiple times on one serial command (rather than each individually).
                                          Notice below the "Arduino" item is getting updates frequently. Below that is my output in the rule to handle the update. Notice it prints multiple 105;0;0;0;7; in place of the other inputs (105;255;3;0;15; for example)
                                          2016-01-26 16:15:36.414 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;15;
                                          2016-01-26 16:15:36.418 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;0;0;17;2.0.0-beta
                                          2016-01-26 16:15:36.425 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;6;0
                                          2016-01-26 16:15:36.429 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;11;Garage Sensor
                                          2016-01-26 16:15:36.433 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;255;3;0;12;1.0
                                          2016-01-26 16:15:36.438 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;0;0;0;7;
                                          2016-01-26 16:15:36.557 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;1;1;0;0;68.0
                                          2016-01-26 16:15:37.058 [INFO ] [runtime.busevents             ] - Arduino state updated to 105;0;1;0;1;36.0
                                          105;0;0;0;7;
                                          105;0;0;0;7;
                                          105;0;0;0;7;
                                          105;0;0;0;7;
                                          105;1;1;0;0;68.0
                                          105;0;1;0;1;36.0
                                          105;0;0;0;7;
                                          105;0;0;0;7;
