  3. MySensors Network at a High School Farm
11 Posts 5 Posters 7.5k Views 6 Watching
  • B Offline
    B Offline
    bpair
    I have been creating a sensor network at a local high school and the mysensors project is basically what makes it possible. I just launched a website on amazon documenting some of what is deployed with live graphs.
    http://growing.education/index.php/farm-monitoring-and-automation/garinger-sensor-network/
    At this point we are mainly just monitoring and collecting data, so my controller is a very simple node-red installation that saves data locally and transmits data via MQTT to mosquitto runing on an Amazon EC2 instance. Another installation of node-red again saves data to InfluxDB and Grafana displays the data very nicely.
    We have three active nodes. One sensebender node running off battery and another solar powered node. A sample of the graphing is below. Check it out. The site is new so I suspect there are many typos and broken links. Thanks again to this community for helping me.
    • H Offline
      H Offline
      HarryDutch
      Wow! What a great project. It's on the top of my list now. Thanks!!
      • Y Offline
        Y Offline
        @bpair Your setup is comparable to the one I'm running at home. I only have MQTT inbetween the MySensors network and Node-RED, and only one Node-RED instance which directly posts to InfluxDB, running locally.
        Especially Grafana is simply awesome and has been the only graphing tool capable of serving all my needs.
        Thanks for sharing!
        A B 2 Replies Last reply
        • Y Yveaux
          Thanks for sharing!
          A Offline
          A Offline
          andriej
          @Yveaux what controller do you use?
          I currently have domoticz and I'm wondering about getting it somehow to system.
          Y 1 Reply Last reply
          • Y Yveaux
            Thanks for sharing!
            B Offline
            B Offline
            bpair
            @Yveaux Yeah Grafana has been great. I would have something similar to your setup but the greenhouse only has a cell phone hotspot so I wanted to get the data out to the cloud with as little traffic as possible. Then display all the graphs from there (grafana on Amazon)
            • A andriej
              Y Offline
              Y Offline
              @andriej I experimented with various systems and settled with OpenHab, although I'm not very happy with it. I'm mostly monitoring at the moment so Grafana will do the trick.
              • B bpair
                Y Offline
                Y Offline
                @bpair it seems overkill to also store the data and run Grafana locally, but I can imagine this works for you.
                B 1 Reply Last reply
                • F Offline
                  F Offline
                  FotoFieber
                  wrote on last edited by FotoFieber
                  @bpair What gateway-sketch (standard serial?) do you use with which version of mysensors?
                  My setup is quite similar (influx, node-red, grafana) but no cloud deployment. Most sensors are based on mysensors, but there are others (homematic with homegear and netatmo).
                  • Y Yveaux
                    B Offline
                    B Offline
                    bpair
                    @Yveaux The install in the greenhouse is basically because the internet connection is costly and not reliable. I have an old linux computer in teh greenhouse for the following reasons:
                    1. To save the date even if there is no internet
                    2. To display a nice dashboard on the computer in the greenhouse (looks impressive)
                    3. To allow students to look at the graphs locally without internet
                    • F FotoFieber
                      :+1:
                      B Offline
                      B Offline
                      bpair
                      @FotoFieber Just the standard serial gateway. There is a nice node-red node for parsing mysensors serial data. I then have some basic code that recognizes the specific data, e.g. node 9 child 10 is the aquaponics water temperature, so that I can store more information in influxd to mak ethe graphs better.
                      I also have node-red respond to the metric/imperial question. That is basically it.
                      • B Offline
                        B Offline
                        bpair
                        And I just noticed the internet has been down at the greenhouse since early Saturday! More reason to have a local install.
