  3. In wall - PCB, (AC to DC 5v)
pcbinwall
89 Posts 14 Posters 78.2k Views 24 Watching
  • sundberg84S
    sundberg84S
    @m26872 Its the slow blow fuse, and I ordered 240v, dont remember which current and that is offcourse whats interesting. On a business trip but can check this weekend when i get home. The datasheet for the HLK refers to:
    Maximum input current ≤0.2 A
    Input current surge ; ≤10 A
    S m26872M 2 Replies Last reply
    • bjacobseB
      bjacobseB
      bjacobse
      Maybe you should add a ground plane on the low voltage part of your design on both sides, but avoid the area where the NRF24L01+ antenna is placed
      • sundberg84S sundberg84
        Samuel235
        @sundberg84 Could I ask where you order your boards from, which manufacturer do you use and would you recommend them?
        MySensors 2.1.1
        • sundberg84S
          sundberg84S
          I order from itead. Works great and good quality.
          S 1 Reply Last reply
            m26872M
            m26872M
            m26872
            wrote on last edited by m26872
            #52
            @sundberg84 The closest fuse-alike I've found in a DO-204 (semiconductor-) package, is the TVS diode. Typical breakdown voltage seems to usually be a lot lower than 230V, so I guess you should apply a low voltage (<10V) if you want to test if it conducts. Fuse break current is the most interesting test of course.
              Samuel235
              @sundberg84 They look like they provide a pretty stable and awesome service. What sort of turn around did you get from ordering to receiving the PCB?
              MySensors 2.1.1
              • sundberg84S
                sundberg84S
                @mzuidwijk : The HLK library for eagles: HKLPM01.rar
                @m26872 : Since the ciriut works it conducts, i have not tested at which point it breaks because i dont have that equipment :( would be great if we somehow could estabilsh the right compont to use.
                m26872M 1 Reply Last reply
                  m26872M
                  m26872M
                  m26872
                  #55
                  @sundberg84 Of course it conducts, probably bidirectional too since it works well for you. That's why I suggested a TVS diode. The test was meant as an easy way to find more info even if it does not fully rule out that it still could be something else than a normal fuse. I'm sure you have possibility to test if something conducts or not at low voltages. If it does not, it is not a fuse. Use a new component since it could be a "fail-short" type one.
                  Then if you connect it in series to a load (> 230V*0.2A "=" 46W), it should blow if it's a fuse.
                  That first fuse is the no1 safety component and should be trusted. I would never just rely an some 10A house fuse to a diy design like this. Removing the varistor could limit the failure modes in the meantime.
                  • sundberg84S
                    sundberg84S
                    @m26872 Ok, you seem to know more about this - i have pretty much tried to sum up what was told in the safe-in-wall thread.
                    Do you agree with that thread or would you do it some other way ? (High power parts and HKL PM01).
                      m26872M
                      m26872M
                      m26872
                      #57
                      @sundberg84 I think the conclusions of that thread is just fine. Now here, it's just a matter of a single component. If you feel safe as it is, ok by me.
                      I've done quite a few diy's over the years and that fuse has been my insurance. And saved me, more than once...
                      Edit: That last sentence sounded a bit bumptious, sorry. I now understand that you probably meant what I said about removing the varistor. There I meant that the varistor is after the fuse because of its hazards. If there is no fuse, it could be better to remove the varistor or at least place it after the thermal fuse.
                      • sundberg84S
                        sundberg84S
                        #58
                        @m26872 I really appreiacte your posts! I never feel safe enough! Would it be safer to have the varistor after the thermal fuse as well? Then the thermal fuse breaks both if the varistor gets hot from over voltage and also protect the HLK.
                        I will try to test my fuses as well - its a good thought. - You never know what you get from Ebay!
                        Edit: The "fuse" conducts low voltages (1.3V) connected to a normal battery and my Multimeter - so this excludes that it is a TVS diode?
                        Will later find some eqipment drawing more than 45W and see if that blows it :) Love to blow stuff... :collision:
                          m26872M
                          m26872M
                          m26872
                          @sundberg84 Yes, that fuses-varistor arrangement is like how I do it.
                          Great that it conducts, I hope in both directions or else it's a diode.
                          • sundberg84S
                            sundberg84S
                            #60
                            @m26872 It conducts both ways, and there is some voltage depending resistance because the volage drops and its different depending which way i put gnd.
                            Also, it does not blow :( so its not a fuse.
                            At the end i connected my vaccumcleaner (1000w) and it didnt blow, all it did was vaccum really slow so i guess its some sort of bidirectional TVS. Good find, thank you!
                            I will keep looking for a 250v 200mA fuse (small) one - you dont happen to know one?
                            • sundberg84S
                              sundberg84S
                              #61
                              Also, i tested the thermal fuse and that one killed/blew! Couldnt measure the exakt temp because all i had was my barbecue thermometer atm and i fired to much to fast... but it blew pretty much were it was supposed to.,
                                m26872M
                                m26872M
                                m26872
                                Maybe a zener diode? Can you read some figures on it?
                                :thumbsup: Good job with the testing!
                                You're welcome.
                                This far I've only used standard replacable 5x20mm glass fuses and holders (preferably covered). These are safe and proven but quite bulky and hence not as convienient for our PCB designs. I've ordered a few small ones with solderlegs for testing but not yet recieved them.
                                • sundberg84S
                                  sundberg84S
                                  New revision ordered:
                                  and also some new fuses:
                                  http://www.ebay.com/itm/290767404446?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                  http://www.ebay.com/itm/231765976267?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                  Of of them is 500mA but that cant matter that much?
                                  Spec of HKL:
                                  • petewillP
                                    petewillP
                                    petewill
                                    @sundberg84 Would you mind posting pictures of your fuses that turned out not to be fuses? I think a few of us ordered from the same store and I'd like to update my original post with a warning. Also, if you don't mind can you post a step by step way for to easily test? If there is another way besides connecting to my vacuum cleaner that would be awesome :)
                                    @m26872 & @sundberg84 can you describe in a little more detail the change of placement of the Varistor? I don't really understand why it's better to change the placement. I'd like to update my first post in this thread with the best/safest method http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                                    • petewillP petewill
                                      m26872M
                                      m26872M
                                      m26872
                                      @petewill The varistor itself is a risk. The moved thermal fuse will then also work as a redundant and diversified protection (to the main fuse) of the varistor and still protect the load as before.
                                        Samuel235
                                        I now have my boards in transit on their way to me as we speak @sundberg84, the next revision will see some development towards some AC/DC conversion i think. However i have a lot of work to do, a lot of learning electronics before i go anywhere near to installing a AC/DC converted board into my wall. Safety first and all that jazz! I love the look of your board layout with the arduino being a add-on board essentially. So as soon as i have my battery version up, working and dialed in for performance, i will be using your board as a learning curve for some AC/DC powering. I actually have printed the above picture of your board out and i'm creating a schematic of it, using it to learn the steps you have taken to get your power to the arduino. I love the fact you have added a temp sensor in there, i'm not too sure why you did that (your personal requirements) but i would love to use this as another trip out sensor to cut the board's power if it detects it getting too hot inside of the socket.
                                        By creating my own i'm not trying to better or improve yours, its simply because for mine to work i would like it to be acceptable into a 29mm depth back box (29mm is with the switch back too, its pretty cramped inside these).
                                        Lastly, is there any chance you could point me in the direction to a copy of your logo/design on the board (The open source, join MySensors.org) so i could include it into mine. I would also like to have the MySensors' official logo on my finished board too, do you know if there is any links/pages/repos to this data or would i just need to create my own as a BMP or Library device?
                                        MySensors 2.1.1
                                        • sundberg84S
                                          sundberg84S
                                          #67
                                          @petewill
                                          The test I did was just to strip a extension cord, attach "the fuse" to it and apply different equipment with spec from 5W up to my vaccumcl 1000+W Not proffessional but I dont have any other equipment.
                                          I dont think we changed the placement? I made a misstake in my first rev but now my varistor placement is like your post (after both fuse and termal fuse). But @m26872 link describes it good why.
                                          @samuel235 Good luck with your board! Do not take my board as "thats how it should be". My board is the result and my interpretation of the discussions so far in this forum. If that is right or wrong i not able to tell (yet). The tempsensor is to initially be able to measure the temp in that closed box to see that the node doesnt produce to much heat.
                                          Im glad you are creating your own... as i said before, my wish is that we all come together and in the end create a small and safe in wall PCB. And If you want (and use Eagles) ill send over the files for the PCB. I will also post them here when i recieved the boards offcourse.
                                          Here is my bitmap I use as a logo... in eagles you can import that to layer 21 and apply to your board.
                                          S YveauxY 2 Replies Last reply
