  3. Ethernet Gateway on Arduino nano
11 Posts 5 Posters 4.6k Views 4 Watching
  • M Offline
    M Offline
    MrTomtom
    Hi
    i try to compile the ethernet gateway sketch for an adruino nano with a ENC28J60 module. I get the error:
    Sketch uses 33,370 bytes (108%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,672 bytes (81%) of dynamic memory, leaving 376 bytes for local variables. Maximum is 2,048 bytes.
    Sketch too big
    I have comment out the lines as described in the begin of the sketch:
    //#include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
    // Use this if you have attached a Ethernet ENC28J60 shields
    #include <UIPEthernet.h>
    // Use this for WizNET W5100 module and Arduino Ethernet Shield
    // #include <Ethernet.h>
    and also comment out the DEBUG in the MyConfig.h file:
    // #define DEBUG
    I use the arduino 1.6.5 on Windows 7.
    Thanks for your support.
    Regards
    Thomas
    • M Offline
      M Offline
      meddie
      i am new to mysensors, and i have an another Problem, but i have an Arduino Nano and when i compile the Sketch it shows that this use 95%. So it dows work for me.
      I hope its usefull for you.
      Maybe you have some libriaries which will be comiled in to arduino. Try to load only MySensors libs in Arduino Programm.
      Greets Eddie
      • Y Offline
        Y Offline
        @MrTomtom said:
        ENC28J60
        Code footprint for ENC28J60 is significantly larger than for W5100.
        Any chance you can use a W5100 for the gateway?
        • M Offline
          M Offline
          MrTomtom
          @meddie: did you use also an ENC28J60 for lan-connection? or an W5100?
          @Yveaux: yes, the chance is real. I can order a lan-shield with W5100. But i could not believer that it's not possible to compile the gateway with an ENC28J60... And the ENC28J60 looks nicer with the arduino, so i get a small package with lan-shield, arduino and rf-shield. :)
          Anyone had compile successfull the lan-gateway wtih ENC28J60?
          Greets
          Thomas
          • M Offline
            M Offline
            meddie
            Hi yes i have an enc and I can compile. 95% used.
            • M Offline
              M Offline
              MrTomtom
              Strange.... on which platform do you compile? Windows, Linux? and which version do you use of arduino ide?
              • M Offline
                M Offline
                meddie
                on Windows 7 arduino IDE 1.6.6.
                I have to use win 7 because i use a Clone of arduino nano and this have a prolific 2303 Chip wich Has only drivers for win 7.
                • Y Offline
                  Y Offline
                  @MrTomtom @meddie Which MySensors library are you using?
                  • M Offline
                    M Offline
                    meddie
                    the newest 1.5.1
                    • B Offline
                      B Offline
                      BSB
                      Remark out as many serial statements as you can.
                      With any luck you can scrape a few bytes back and it will compile and run.
                      Even if you have some form of debug define set for serial output the serial statements are still viable memory hogs.
                      • mfalkviddM Offline
                        MySensors 1.6 (still in development) is quite a lot smaller than 1.5. You cound try it and see if it is enough.
