Strange behavior of connection Node => Gateway
Hello
EDIT: I posted this thread to General diskussions, because I don't know if there is somethink to troubleshoot or bugreport ...
I have the following behavior:
When starting a node after it's off some time, it fails to connect to the gateway:Starting sensor (RNNNA-, 1.6.0-beta) Radio init successful. send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=fail:0 send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=fail: send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:Test Sensor send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:0.1 find parent send: 99-99-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:Erm .. ok: 0/6 messages are ok. Powering it off and on (and mybe pressing the reset buttin once or twice) results in partial st=ok:
Radio init successful. send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=fail:0 send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=fail: send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:Test Sensor send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:0.1 Init complete, id=99, parent=0, distance=1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:1Strange ... 2/6 messages are ok ok lets reset the node again:
Starting sensor (RNNNA-, 1.6.0-beta) Radio init successful. send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=fail:0 send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0 send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok: send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:Test Sensor send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:0.1 Init complete, id=99, parent=0, distance=1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1Hmm .. almost ... 4/6 messages are ok ... reset again:
Starting sensor (RNNNA-, 1.6.0-beta) Radio init successful. send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=ok:0 send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0 send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok: send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:Test Sensor send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:0.1 Init complete, id=99, parent=0, distance=1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:1Here we are 6/6 messages are ok ... but i can image, that's not the way it's inted to be, isn't it? I did not change the wiring or something on the code between the power cycles/resets.
** Some time went by trying to get more infos **
Ah i could narrow it down: It's the gateway causing the problem: When the GW was off some time (simple unplug/plug does not cause this problem) it takes some time until the nodes could connect again.
Times:
GW offline: ~7m
Node can reconnect: ~1m20sNot shure if this is a real world problem or not ... maybe i should think about a mini usv for the gateway
**EDIT: can someone move thes thread to the troubleshoot section? **
hmm maybe it's more of a problem than i thought: the first connection of the node to the ggateway does still require one or two resets of the node :(I turned off and on the gateway and simply waited in order to have the node reconnected to the gw. But this does not happen:
Every 6 "actions/sendings" from the node to the gw i can see:
send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 find parent send: 99-99-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0 send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1 find parent send: 99-99-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:Only resetting the node connects it to the network again.
recap:
after a longer downtime of the gw the nodes need- some time (~1-2min) after the startup of the GW
- a reset
in order to reconnect
EDIT. Code attached
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik Ekblad * * DESCRIPTION * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker. * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network * * LED purposes: * - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly * - ERR (red) - fast blink on error during transmission error or recieve crc error * * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions. * nRF24L01+ ESP8266 * VCC VCC * CE GPIO4 * CSN/CS GPIO15 * SCK GPIO14 * MISO GPIO12 * MOSI GPIO13 * * Not all ESP8266 modules have all pins available on their external interface. * This code has been tested on an ESP-12 module. * The ESP8266 requires a certain pin configuration to download code, and another one to run code: * - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch') * - Connect GPIO15 via 10K pulldown resistor to GND * - Connect CH_PD via 10K resistor to VCC * - Connect GPIO2 via 10K resistor to VCC * - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch') * * Inclusion mode button: * - Connect GPIO5 via switch to GND ('inclusion switch') * * Hardware SHA204 signing is currently not supported! * * Make sure to fill in your ssid and WiFi password below for ssid & pass. */ // Custom Settings #define SKETCH_NAME "mqttClientGateway" #define SKETCH_MAJOR_VERSION "1" #define SKETCH_MINOR_VERSION "0" #include <EEPROM.h> #include <SPI.h> // Enable debug prints to serial monitor #define MY_DEBUG // Enables and select radio type (if attached) #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #define MY_GATEWAY_MQTT_CLIENT // Set this nodes subscripe and publish topic prefix #define MY_MQTT_PUBLISH_TOPIC_PREFIX "sensor-gw1-out" #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "sensor-gw1-in" // Set MQTT client id #define MY_MQTT_CLIENT_ID "sensor-gw1" // W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal) //#define MY_W5100_SPI_EN 4 // Enable Soft SPI for NRF radio (note different radio wiring is required) // The W5100 ethernet module seems to have a hard time co-operate with // radio on the same spi bus. #if !defined(MY_W5100_SPI_EN) #define MY_SOFTSPI // Arduino Uno //#define MY_SOFT_SPI_SCK_PIN 14 //#define MY_SOFT_SPI_MISO_PIN 16 //#define MY_SOFT_SPI_MOSI_PIN 15 // Arduino Mega #define MY_SOFT_SPI_SCK_PIN A0 #define MY_SOFT_SPI_MISO_PIN A2 #define MY_SOFT_SPI_MOSI_PIN A1 #endif // When W5100 is connected we have to move CE/CSN pins for NRF radio #define MY_RF24_CE_PIN 5 #define MY_RF24_CS_PIN 6 // Enable these if your MQTT broker requires usenrame/password //#define MY_MQTT_USER "username" //#define MY_MQTT_PASSWORD "password" // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP) #define MY_IP_ADDRESS 192,168,100,10 // If using static ip you need to define Gateway and Subnet address as well #define MY_IP_GATEWAY_ADDRESS 192,168,100,1 #define MY_IP_SUBNET_ADDRESS 255,255,0,0 // MQTT broker ip address. #define MY_CONTROLLER_IP_ADDRESS 192, 168, 100, 3 // The MQTT broker port to to open #define MY_PORT 1883 /* // Flash leds on rx/tx/err #define MY_LEDS_BLINKING_FEATURE // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Enable inclusion mode #define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway #define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) #define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button #define MY_INCLUSION_MODE_BUTTON_PIN 3 #define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin #define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin #define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED */ #include <Ethernet.h> #include <MySensor.h> void setup() { } void presentation() { // Present locally attached sensors here sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VERSION"."SKETCH_MINOR_VERSION); } void loop() { // Send locally attech sensors data here } -
I don't know any MQTT but apart from that I guess that it could be a problem with nRF, power or routing.
- How's your MySensors net(s) look like? How many Nodes? Repeaters? Gateways?
- As I understand it, you've now ruled out down to that it's a Gateway issue? Any other to test with? MQTT, Serial and Ethernet.
- What does your Gateway etc look like i.e. What's your power source? Tried another? Filter (capacitors up to 200uF)? Battery (2AA) to nRF only, just for a test?
- Tried different nRF radio modules? Tried another PA level (low) in the config file?
- Have you cleared eeprom (routing table) of Nodes, Repeaters and Gateways? Any difference?
- Tried to add delay (100-500ms) before and in between begin and presentation messages? (This could be an easy first step).
I'll try to answer as much as possible :D
- My Network is quite simple at the moment: one gateway, one testnode
- the reconnect problem seems to come from the gateway. when powering off the node for a while, reconnection goes out of the box
- not really some other gateways for testing
- my gateway is power via USB from my pc. Filter capacitor is at 4,7nF. I try to increase it.
- Changed nrf already with no improvements. i'll try to set pa level to low. whats the impact of this? lower range? speed?
- nope have not cleared any eeprom ... musst search for a howto
- the delay in the gateway i assume?
thx ;) again
Hi dakky!
I would also guess power problems - but its just a guess.
I would try different power sources if possible. -
ok i think this can be regarded as solved: have tested very many on/of roundtrips and with an 100nf and an additional 4,7nf cap it's rocking stable. Maybe this would be worth a sidenote here: http://www.mysensors.org/build/connect_radio
