  3. Strange behavior of connection Node => Gateway
10 Posts 4 Posters 3.3k Views 3 Watching
  • dakkyD
    dakkyD
    dakky
    Hello
    EDIT: I posted this thread to General diskussions, because I don't know if there is somethink to troubleshoot or bugreport ...
    I have the following behavior:
    When starting a node after it's off some time, it fails to connect to the gateway:
    Starting sensor (RNNNA-, 1.6.0-beta)
    Radio init successful.
    send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=fail:0
    send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
    send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=fail:
    send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:Test Sensor
    send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:0.1
    find parent
    send: 99-99-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    Erm .. ok: 0/6 messages are ok. Powering it off and on (and mybe pressing the reset buttin once or twice) results in partial st=ok:
    send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:0.1
    Init complete, id=99, parent=0, distance=1
    send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:1
    Strange ... 2/6 messages are ok ok lets reset the node again:
    send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
    send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    send: 99-99-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok:
    send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:Test Sensor
    send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1
    Hmm .. almost ... 4/6 messages are ok ... reset again:
    send: 99-99-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=ok:0
    Here we are 6/6 messages are ok ... but i can image, that's not the way it's inted to be, isn't it? I did not change the wiring or something on the code between the power cycles/resets.
    ** Some time went by trying to get more infos **
    Ah i could narrow it down: It's the gateway causing the problem: When the GW was off some time (simple unplug/plug does not cause this problem) it takes some time until the nodes could connect again.
    Times:
    GW offline: ~7m
    Node can reconnect: ~1m20s
    Not shure if this is a real world problem or not ... maybe i should think about a mini usv for the gateway
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • dakkyD
      dakkyD
      dakky
      wrote on last edited by dakky
      **EDIT: can someone move thes thread to the troubleshoot section? **
      hmm maybe it's more of a problem than i thought: the first connection of the node to the ggateway does still require one or two resets of the node :(
      I turned off and on the gateway and simply waited in order to have the node reconnected to the gw. But this does not happen:
      Every 6 "actions/sendings" from the node to the gw i can see:
      send: 99-99-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0
      find parent
      find parent
      Only resetting the node connects it to the network again.
      • dakkyD
        dakkyD
        dakky
        recap:
        after a longer downtime of the gw the nodes need
        • some time (~1-2min) after the startup of the GW
        • a reset
        in order to reconnect
        EDIT. Code attached
         * Version 1.0 - Henrik Ekblad
         * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
         * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
         * LED purposes:
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
          * Inclusion mode button:
        // Custom Settings
        #define SKETCH_NAME "mqttClientGateway"
        #define SKETCH_MAJOR_VERSION "1"
        #define SKETCH_MINOR_VERSION "0"
        #include <EEPROM.h>
        // Set this nodes subscripe and publish topic prefix
        #define MY_MQTT_PUBLISH_TOPIC_PREFIX "sensor-gw1-out"
        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "sensor-gw1-in"
        // Set MQTT client id
        #define MY_MQTT_CLIENT_ID "sensor-gw1"
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
        #if !defined(MY_W5100_SPI_EN)
          #define MY_SOFTSPI
          // Arduino Uno
          //#define MY_SOFT_SPI_SCK_PIN 14
          //#define MY_SOFT_SPI_MISO_PIN 16
          //#define MY_SOFT_SPI_MOSI_PIN 15
          // Arduino Mega
          #define MY_SOFT_SPI_SCK_PIN A0
          #define MY_SOFT_SPI_MISO_PIN A2
          #define MY_SOFT_SPI_MOSI_PIN A1
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        #define MY_IP_ADDRESS 192,168,100,10
        #define MY_IP_GATEWAY_ADDRESS 192,168,100,1
        #define MY_IP_SUBNET_ADDRESS 255,255,0,0
        // MQTT broker ip address.
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 100, 3
        #define MY_PORT 1883
        // Flash leds on rx/tx/err
        #define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // Enable inclusion mode
        #include <Ethernet.h>
        void presentation() {
            sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VERSION"."SKETCH_MINOR_VERSION);
          // Send locally attech sensors data here
        • m26872M
          m26872M
          m26872
          I don't know any MQTT but apart from that I guess that it could be a problem with nRF, power or routing.
          • How's your MySensors net(s) look like? How many Nodes? Repeaters? Gateways?
          • As I understand it, you've now ruled out down to that it's a Gateway issue? Any other to test with? MQTT, Serial and Ethernet.
          • What does your Gateway etc look like i.e. What's your power source? Tried another? Filter (capacitors up to 200uF)? Battery (2AA) to nRF only, just for a test?
          • Tried different nRF radio modules? Tried another PA level (low) in the config file?
          • Have you cleared eeprom (routing table) of Nodes, Repeaters and Gateways? Any difference?
          • Tried to add delay (100-500ms) before and in between begin and presentation messages? (This could be an easy first step).
          • dakkyD
            dakkyD
            dakky
            I'll try to answer as much as possible :D
            1. My Network is quite simple at the moment: one gateway, one testnode
            2. the reconnect problem seems to come from the gateway. when powering off the node for a while, reconnection goes out of the box
            3. not really some other gateways for testing
            4. my gateway is power via USB from my pc. Filter capacitor is at 4,7nF. I try to increase it.
            5. Changed nrf already with no improvements. i'll try to set pa level to low. whats the impact of this? lower range? speed?
            6. nope have not cleared any eeprom ... musst search for a howto
            7. the delay in the gateway i assume?
            thx ;) again
            • sundberg84S
              Hi dakky!
              I would also guess power problems - but its just a guess.
              I would try different power sources if possible.
              • dakkyD
                dakkyD
                dakky
                hmmm i changed the filter cap to 100nF and powered off the gateway over night: today the node connected at once. I will test again later.
                • dakkyD
                  dakkyD
                  dakky
                  retested ... works.
                  Does the cap size has any "disadvantages"?
                    Larger caps react slower, so you might want to use both caps. The small will take care of small quick dips and the large will take care of larger slower dips.
                    • dakkyD
                      dakkyD
                      dakky
                      ok i think this can be regarded as solved: have tested very many on/of roundtrips and with an 100nf and an additional 4,7nf cap it's rocking stable. Maybe this would be worth a sidenote here: http://www.mysensors.org/build/connect_radio
