  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • F
    F
    Fabien
    I recently switch to RFM69 and I know it's not yet compatible with MYSBootloader. But I can't find information about RFM69 and dualoptiboot support for OTA in MYSController (without a sensebender). Is it possible ? I have to make special config ? Thank !
    AnticimexA 1 Reply Last reply
    • F Fabien
      AnticimexA
      AnticimexA
      Anticimex
      #310
      @Fabien DualOptiboot is completely radio agnostic. You should not need any custom config to use OTA with DualOptiboot and rfm69. You do need an external flash on your board though.
      • F
        F
        Fabien
        @Anticimex ok but in MYSController is there a way in the GUI for setting the bootloader (DualOptiboot or MYSBootloader) or is ti automatic. I ask this because you have to tell MYSBootloader your are running SenseBender (DualOptiboot).
        tekkaT 1 Reply Last reply
        • F Fabien
          tekkaT
          tekkaT
          tekka
          @Fabien yes, select "sensebender"...this will do the trick
          • F
            F
            Fabien
            Thank you @tekka I don't test your new bootloader beacuse I think you don't have RFM69 version (perhaps in th future ?)
            • F Fabien
              tekkaT
              tekkaT
              tekka
              @Fabien perhaps, will have to get some RFM69 hardware first...
              • N niccodemi
                @petewill did you have any success finding out how to change default channel?
                petewillP
                petewillP
                petewill
                Sorry, don't know how I missed this. No, I haven't. I got sidetracked (kids) and I haven't had a chance to work on it further.
                • petewillP
                  petewillP
                  petewill
                  @niccodemi I just was able to upload the bootloader using the files provided by @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7. The difference is I used a USBASP (V2.0) instead of an UNO. It worked the first time uploading the blink sketch!! It was a pain getting the USBASP to work on Windows 8.1 but after I got the driver installed (and the wiring connections correct) it worked great. I haven't uploaded any sensor sketches yet but hopefully I'll have time to play with it soon.
                  N 1 Reply Last reply
                  • petewillP petewill
                    N
                    N
                    niccodemi
                    @petewill thanks, I tried ch77 and it works great.
                    • balloonguyB
                      balloonguyB
                      balloonguy
                      Hi, download link for MYSController is broken. Error on attempt to download. thank you
                      • balloonguyB balloonguy
                        tekkaT
                        tekkaT
                        tekka
                        @balloonguy Not on my side. Please try again.
                        balloonguyB 1 Reply Last reply
                        • tekkaT tekka
                          balloonguyB
                          balloonguyB
                          balloonguy
                          @tekka thanks for the quick response - i have tried the {http://goo.gl/9DCWNo} with no luck, all i get is a "this page is not available" message. I have tried with different browsers and different pc's - still the same response.
                          BTW- Merry Christmas.
                          R 1 Reply Last reply
                            R
                            R
                            robosensor
                            @balloonguy just tried this link. Everything is working, MYSController.zip file with md5 checksum dfe98f9e7ed6e1c3d5c418a862c23ee0 is downloaded.
                            • D
                              drock1985
                              Hi @tekka
                              When editing/adding items to the firmware_config.csv file, what should go in the types column? Could you please explain it?
                              My Projects
                              2 Door Chime Sensor
                              Washing Machine Monitor
                              • D drock1985
                                Hi @tekka
                                tekkaT
                                tekkaT
                                tekka
                                The type field is intended for defining a FW type, e.g. a node with a DHT humidity/temperature sensor may be FW type 1, whereas a node with a different sensor FW type 2 and so on...
                                • P
                                  P
                                  p0lar
                                  Now that I have sensors that have the correct bootloader I have been able to upload firmware a few times. But now that I have made changed to the sketch and copied the new hex file over I even bumped the version tag in the file. I can't get it to flash. Nothing I do makes it upload the new code? Thoughts?
                                  N tekkaT 2 Replies Last reply
                                  • P p0lar
                                    N
                                    N
                                    niccodemi
                                    @p0lar are you still able to remotely reboot node?
                                    • P p0lar
                                      tekkaT
                                      tekkaT
                                      tekka
                                      wrote on last edited by tekka
                                      #326
                                      @p0lar Please provide MYSController log with DEBUG enabled for further troubleshooting.
                                      • P
                                        P
                                        p0lar
                                        Yes I can reboot the node. trying to upload dallastemp to it.
                                        MySensors_20160102-104854.log
                                        • P p0lar
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @p0lar I do not see any DEBUG nor bootloader messages. Can you update the GW sketch with DEBUG enabled? Also, what bootloader did you flash?
