  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • balloonguyB
    balloonguyB
    balloonguy
    Hi, download link for MYSController is broken. Error on attempt to download. thank you
    tekkaT 1 Reply Last reply
    • balloonguyB balloonguy
      tekkaT
      tekkaT
      tekka
      @balloonguy Not on my side. Please try again.
      balloonguyB 1 Reply Last reply
      • tekkaT tekka
        balloonguyB
        balloonguyB
        balloonguy
        @tekka thanks for the quick response - i have tried the {http://goo.gl/9DCWNo} with no luck, all i get is a "this page is not available" message. I have tried with different browsers and different pc's - still the same response.
        BTW- Merry Christmas.
        R 1 Reply Last reply
          R
          R
          robosensor
          @balloonguy just tried this link. Everything is working, MYSController.zip file with md5 checksum dfe98f9e7ed6e1c3d5c418a862c23ee0 is downloaded.
          • D
            drock1985
            Hi @tekka
            When editing/adding items to the firmware_config.csv file, what should go in the types column? Could you please explain it?
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            • D drock1985
              Hi @tekka
              tekkaT
              tekkaT
              tekka
              The type field is intended for defining a FW type, e.g. a node with a DHT humidity/temperature sensor may be FW type 1, whereas a node with a different sensor FW type 2 and so on...
              • P
                P
                p0lar
                Now that I have sensors that have the correct bootloader I have been able to upload firmware a few times. But now that I have made changed to the sketch and copied the new hex file over I even bumped the version tag in the file. I can't get it to flash. Nothing I do makes it upload the new code? Thoughts?
                N tekkaT 2 Replies Last reply
                • P p0lar
                  N
                  N
                  niccodemi
                  @p0lar are you still able to remotely reboot node?
                  • P p0lar
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    #326
                    @p0lar Please provide MYSController log with DEBUG enabled for further troubleshooting.
                    • P
                      P
                      p0lar
                      Yes I can reboot the node. trying to upload dallastemp to it.
                      MySensors_20160102-104854.log
                      • P p0lar
                        tekkaT
                        tekkaT
                        tekka
                        @p0lar I do not see any DEBUG nor bootloader messages. Can you update the GW sketch with DEBUG enabled? Also, what bootloader did you flash?
                        • P
                          P
                          p0lar
                          Its turned on in MySensors.h and reuploaded
                          MyConfig.h
                          • P
                            P
                            p0lar
                            But i dont see anything. UNO ethernet GW with SoftSPI enabled
                            • P
                              P
                              p0lar
                              Bootloader on the sensors is the one from your firmware directory. on the GW its the standard arduino one... do I need yours on the GW?
                              • P p0lar
                                tekkaT
                                tekkaT
                                tekka
                                @p0lar No, GW should have normal (i.e. Arduino) bootloader. However, without DEBUG output it's gonna be hard to diagnose what's wrong - can you double-check your settings and re-upload the GW sketch just to be on the safe side.
                                Also, I'd like to see the log during a manual reset (not remote reboot) of your node.
                                • P
                                  P
                                  p0lar
                                  Thanks. Ill check that when I get back into town end of this week.
                                    stebra
                                    Hi @tekka,
                                    tried now some evenings to change node-id / clear the eeprom. No luck. FW update works always. After reading the bootloader code I expected myscontroller to send a invalid fwrequestresponse packet with special crc for the bootloader commands. Never showed up in the log.
                                    Myscontroller .282 on Win xp and msbootloader 1.1 on nano. 47uF on nrf. No transmission errors.
                                    Any ideas where to look next ? Maybe .278 will do the trick ?
                                    Thanks for your efforts ,
                                    stebra
                                    • S stebra
                                      Hi @tekka,
                                      stebra
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @stebra please post the myscontroller log with gw DEBUG enabled that shows OTA update and ID reassign request.
                                        stebra
                                        MySensors_20160110-115615_stebra.log
                                        hi tekka,
                                        here is the log. Contains:
                                        [2016-01-10 12:02:26.390 Info] INFO *** Logging START *** // stebra : succesful reboot of node 6 via myscontroller
                                        [2016-01-10 12:02:59.000 Info] INFO *** Logging START *** // stebra : succesful FW update of node 6 via myscontroller
                                        [2016-01-10 12:05:35.109 Info] INFO *** Logging START *** // stebra : ID reassign attempt of node 6 to node 12 via myscontroller
                                        [2016-01-10 12:05:48.328 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                                        [2016-01-10 12:06:37.437 Info] INFO *** Logging START *** // stebra: Clear eeprom attempt on node 6
                                        [2016-01-10 12:06:44.812 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                                        thank you for having a look..
                                          stebra
                                          and also a ss for another reassign attempt node 6--> 12.
                                          FIRMWARE_CONFIG_REQUEST is not answered from myscontroller. therefore no reassign of node id.
