  3. Node-RED
  4. Node-Red as Controller
Scheduled Pinned Locked Moved Node-RED
node-red
54 Posts 17 Posters 58.7k Views 19 Watching
  • V vikasjee
    @Heinz ,
    Thanks for the flow. kindly post how you have referenced mysensors library for the flow? Split function is spitting out an error as is.
    OR Is it required at all?
    Function Error: TypeError: Cannot call method 'split' of undefined (line 8, col 31)
    Alco van NeckA
    Alco van NeckA
    Alco van Neck
    You need to add an commit to the line 8 like var tokens = splitData[1].split(";");
    I'm getting data at : http://192.168.1.115:1880/mysensorsdata, but the http://192.168.1.115:1880/mysensors don't update.. there is an autoupdate in the flow but it don't work..
    • HeinzH
      HeinzH
      Heinz
      which browser did you take? Probably you should try another one.
      • H
        H
        humblehacker
        I've used NodeRED for various tasks over the years and it still remains my favorite IOT interface. All the while I've tried at least 5 of the officially supported MS controllers out there and nothing has come close! At present I'm trying Home Assistant but am almost ready to give up and set up my own workflow with NodeRED. There's a blog post at https://crankylinuxuser.net/2015/10/01/idiot-crazy-ways-to-make-iot-simple-and-cheap/ that includes a great example of a MySensors+NodeRED flow along with a spot-on critique of mainstream automation services being marketed at present.
        The only reason I havent just used NodeRED in the past is it would still require other components to truly make a unified home automation service. An ideal scenario IMHO would be something that uses NodeRED as a front-end with something more unified running it.
        crankyC 1 Reply Last reply
        • FotoFieberF
          FotoFieberF
          FotoFieber
          Here my approach:
          [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"b5e4f17d.4a1b1","type":"function","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\nfunction encode(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n","outputs":1,"noerr":0,"x":1655.916648864746,"y":536.4166927337646,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6ce260d.1931d8","type":"switch","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1220.166648864746,"y":175.5000171661377,"z":"9592163f.6a6de8","wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1449.916648864746,"y":38.2499885559082,"z":"9592163f.6a6de8","wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1445.5000228881836,"y":175.7500057220459,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1449.5000228881836,"y":226.0000057220459,"z":"9592163f.6a6de8","wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1457.5000228881836,"y":321.0000057220459,"z":"9592163f.6a6de8","wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","name":"debug","active":true,"console":"false","complete":"true","x":1806.7500267028809,"y":235.00000667572021,"z":"9592163f.6a6de8","wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1453.166648864746,"y":100.50000381469727,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","name":"","active":false,"console":"false","complete":"true","x":1179.9166259765625,"y":34.66668891906738,"z":"9592163f.6a6de8","wires":[]},{"id":"6aa2d9f6.955d28","type":"function","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = tokens[0];\n        msg.childSensorId = tokens[1];\n        msg.messageType = tokens[2];\n        msg.ack = tokens[3];\n        msg.subType = tokens[4];\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":984.6666488647461,"y":173.66664505004883,"z":"9592163f.6a6de8","wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1819.9166526794434,"y":174.1666603088379,"z":"9592163f.6a6de8","wires":[]},{"id":"5f03c10e.a0fc4","type":"tcp request","server":"192.168.92.13","port":"5003","out":"char","splitc":"\\n","name":"MySWifi ESP8266 GW AES 13","x":376.6666946411133,"y":140.1666316986084,"z":"9592163f.6a6de8","wires":[["df1e322.f20e1d"]]},{"id":"e6d67f33.19298","type":"inject","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":106.25,"y":74.41665744781494,"z":"9592163f.6a6de8","wires":[["5f03c10e.a0fc4","64617800.9b9e88","c7d0d88b.382f28","56b9f6ab.a94608"]]},{"id":"ebcef3df.14311","type":"function","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":790.1666946411133,"y":174.91669178009033,"z":"9592163f.6a6de8","wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","name":"","x":71,"y":642,"z":"9592163f.6a6de8","wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","name":"","active":false,"console":"false","complete":"true","x":216,"y":642,"z":"9592163f.6a6de8","wires":[]},{"id":"64617800.9b9e88","type":"function","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":325.25,"y":59.00000190734863,"z":"9592163f.6a6de8","wires":[[]]},{"id":"df1e322.f20e1d","type":"function","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":602.0000076293945,"y":140.50000190734863,"z":"9592163f.6a6de8","wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":94,"y":207.25000381469727,"z":"9592163f.6a6de8","wires":[["5f03c10e.a0fc4"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","server":"192.168.92.14","port":"5003","out":"char","splitc":"\\n","name":"MySWifi ESP8266 GW AES 14","x":370.5,"y":217.25000381469727,"z":"9592163f.6a6de8","wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":597.5000076293945,"y":218.750018119812,"z":"9592163f.6a6de8","wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":346,"y":97,"z":"9592163f.6a6de8","wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","name":"Debug","active":true,"console":"false","complete":"true","x":785,"y":470,"z":"9592163f.6a6de8","wires":[]},{"id":"57db23d6.a824dc","type":"function","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":591,"y":96,"z":"9592163f.6a6de8","wires":[[]]},{"id":"dfba7d69.20458","type":"file","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1434,"y":375,"z":"9592163f.6a6de8","wires":[]},{"id":"25efb0d3.da105","type":"inject","name":"Test Backup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":209,"y":456,"z":"9592163f.6a6de8","wires":[["e7d998a7.182668"]]},{"id":"e7d998a7.182668","type":"function","name":"Show context.global.mysnextid","func":"msg.payload = JSON.stringify(context.global.mysnextid);\n\nreturn msg;","outputs":1,"noerr":0,"x":427,"y":453,"z":"9592163f.6a6de8","wires":[["e000bd09.1fff4"]]},{"id":"e0e76d62.1f189","type":"function","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n\nif (msg.nodeid < 255)\n{\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        context.global.mysnextid[msg.controller] = msg.nodeid+1;\n    }\n    \n    if (msg.nodeid >= context.global.mysnextid[msg.controller]) {\n       context.global.mysnextid[msg.controller] = msg.nodeid+1; \n    }\n    \n}\n\nreturn msg;","outputs":1,"noerr":0,"x":1223,"y":368,"z":"9592163f.6a6de8","wires":[["dfba7d69.20458"]]},{"id":"a7d335f6.582cc8","type":"inject","name":"Test GetNodeId","topic":"","payload":"255;0;3;0;3;","payloadType":"string","repeat":"","crontab":"","once":false,"x":456,"y":264,"z":"9592163f.6a6de8","wires":[["c5f14d8f.3a0eb"]]}]
          Features:
          • Publish states to mqtt
          • handle node-ids
          • support multiple ethernet conrollers
          • should be adoptable to serial controllers
          Restrictions:
          • read only, no values can be sent to nodes
          • you will find others :)
          • FotoFieberF
            FotoFieberF
            FotoFieber
            • Fixed node-id handling for new nodes.
            • added write support (see "MQTT to MYS" convert for details)
            • parameters can be set in 'MYS initialize'
            [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"e6ce260d.1931d8","type":"switch","z":"9592163f.6a6de8","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1259.166648864746,"y":182.50001335144043,"wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","z":"9592163f.6a6de8","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.916648864746,"y":45.24998474121094,"wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","z":"9592163f.6a6de8","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1484.5000228881836,"y":182.75000190734863,"wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","z":"9592163f.6a6de8","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.5000228881836,"y":233.00000190734863,"wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","z":"9592163f.6a6de8","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1496.5000228881836,"y":328.00000190734863,"wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","z":"9592163f.6a6de8","name":"debug","active":false,"console":"false","complete":"true","x":1845.7500267028809,"y":242.00000286102295,"wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","z":"9592163f.6a6de8","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1492.166648864746,"y":107.5,"wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":1218.9166259765625,"y":41.66668510437012,"wires":[]},{"id":"6aa2d9f6.955d28","type":"function","z":"9592163f.6a6de8","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = parseInt(tokens[0]);\n        msg.childSensorId = parseInt(tokens[1]);\n        msg.messageType = parseInt(tokens[2]);\n        msg.ack = parseInt(tokens[3]);\n        msg.subType = parseInt(tokens[4]);\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":1023.6666488647461,"y":180.66664123535156,"wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","z":"9592163f.6a6de8","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1858.9166526794434,"y":181.16665649414062,"wires":[]},{"id":"b5e4f17d.4a1b1","type":"function","z":"9592163f.6a6de8","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_CONFIG')\n{\n    var payload = 'M';\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_CONFIG; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n}\nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\n\n","outputs":1,"noerr":0,"x":1694.916648864746,"y":543.4166889190674,"wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6d67f33.19298","type":"inject","z":"9592163f.6a6de8","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":145.25,"y":81.41665363311768,"wires":[["64617800.9b9e88","56b9f6ab.a94608","3e866f6d.c1799"]]},{"id":"ebcef3df.14311","type":"function","z":"9592163f.6a6de8","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":829.1666946411133,"y":181.91668796539307,"wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","z":"9592163f.6a6de8","name":"","x":58,"y":449,"wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":224,"y":450,"wires":[]},{"id":"64617800.9b9e88","type":"function","z":"9592163f.6a6de8","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_STATUS              = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_STATUS:            MySHelper.prototype.V_STATUS,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \nMySHelper.prototype.VNum = function(V_SUBTYPE) {\n    sRet = vtype [V_SUBTYPE];\n    if (sRet === undefined)\n        sRet = V_SUBTYPE;\n    return sRet;\n}\n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n MySHelper.prototype.encode = function(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":364.25,"y":65.99999809265137,"wires":[[]]},{"id":"df1e322.f20e1d","type":"function","z":"9592163f.6a6de8","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":641.0000076293945,"y":147.49999809265137,"wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","z":"9592163f.6a6de8","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":133,"y":214.25,"wires":[["3e866f6d.c1799"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.14","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 14","x":410.5,"y":207.24999618530273,"wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","z":"9592163f.6a6de8","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":653.5,"y":205.7500114440918,"wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","z":"9592163f.6a6de8","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":385,"y":103.99999618530273,"wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","z":"9592163f.6a6de8","name":"Debug","active":false,"console":"false","complete":"true","x":732,"y":361,"wires":[]},{"id":"57db23d6.a824dc","type":"function","z":"9592163f.6a6de8","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":102.99999618530273,"wires":[[]]},{"id":"dfba7d69.20458","type":"file","z":"9592163f.6a6de8","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1473,"y":381.99999618530273,"wires":[]},{"id":"e0e76d62.1f189","type":"function","z":"9592163f.6a6de8","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n// node.log(\"Handling next ids\");\n// node.log(\"nodeId: \" + msg.nodeId);\n\nbChanged = false;\n\nif (msg.nodeId === 0) return;\n\nif (msg.nodeId < 255)\n{\n    // node.log(\"Test if next node-id must be set\");\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        node.log(\"node-id not initialized yet\");\n        context.global.mysnextid[msg.controller] = msg.nodeId+1;\n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n    \n    // node.log(\"Nexid stored \" + parseInt(context.global.mysnextid[msg.controller]));\n    \n    if (msg.nodeId >= parseInt(context.global.mysnextid[msg.controller])) {\n        node.log(\"node-id >= next -> increase\");\n        // convert to int\n        context.global.mysnextid[msg.controller] = parseInt(context.global.mysnextid[msg.controller]);\n        context.global.mysnextid[msg.controller] = msg.nodeId+1; \n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n\n    if (bChanged) {\n        node.log(\"next id must be stored\");\n        msg.payload = JSON.stringify(context.global.mysnextid);   \n        return msg;\n    }\n}\n\n\n","outputs":1,"noerr":0,"x":1262,"y":374.99999618530273,"wires":[["dfba7d69.20458","5c074c19.a3f8b4"]]},{"id":"8da09002.725f7","type":"function","z":"9592163f.6a6de8","name":"MQTT to MYS convert","func":"// topic = MYS-NODERED/set/controller/node-id/sensor-id/ack/sub-type\n// payload = payload :)\n\n    var tokens = msg.topic.split(\"/\")\n    \n    msg.rawData = tokens;\n    msg.tokens = tokens.length;\n    if(tokens.length == 7)\n    {\n        if (tokens[0] != context.global.MYS.TOPIC_PREFIX) // not for us\n            return;\n        if (tokens[1] != 'set') // not for us\n            return;\n            \n        msg.controller = parseInt(tokens[2]);\n        msg.messageType = context.global.MYS.T_SET;\n        msg.nodeId = parseInt(tokens[3]);\n        msg.childSensorId = parseInt(tokens[4]);\n        msg.ack = parseInt(tokens[5]);\n        msg.subType = context.global.MYS.VNum(tokens[6]);\n        \n        msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, msg.messageType, msg.ack, msg.subType, msg.payload);\n    \n        return msg;        \n    }\n","outputs":1,"noerr":0,"x":490,"y":361,"wires":[["e000bd09.1fff4","266b87b3.d99478"]]},{"id":"3e866f6d.c1799","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.13","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 13","x":407,"y":145.99999618530273,"wires":[["df1e322.f20e1d"]]},{"id":"5c074c19.a3f8b4","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":1454,"y":543.9999961853027,"wires":[]},{"id":"c75fd7f4.38a028","type":"mqtt in","z":"9592163f.6a6de8","name":"Read MQTT Stream: change Topic to your needs","topic":"MYS-NODERED/set/#","broker":"ba386057.845d3","x":183.5,"y":362,"wires":[["8da09002.725f7"]]}]```
            fetsF 1 Reply Last reply
            • FotoFieberF
              FotoFieberF
              FotoFieber
              Stability is not sufficient. The connection gets lost from time to time.
              Added a watchdog to add another connection, if no messages arrives.
              Seems, that this is only interesting for me. If I get no feedback I will stop spaming this thread. :smiley:
              [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"e6ce260d.1931d8","type":"switch","z":"9592163f.6a6de8","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1259.166648864746,"y":182.50001335144043,"wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","z":"9592163f.6a6de8","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.916648864746,"y":45.24998474121094,"wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","z":"9592163f.6a6de8","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1484.5000228881836,"y":182.75000190734863,"wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","z":"9592163f.6a6de8","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.5000228881836,"y":233.00000190734863,"wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","z":"9592163f.6a6de8","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1496.5000228881836,"y":328.00000190734863,"wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","z":"9592163f.6a6de8","name":"debug","active":false,"console":"false","complete":"true","x":1845.7500267028809,"y":242.00000286102295,"wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","z":"9592163f.6a6de8","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1492.166648864746,"y":107.5,"wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":1218.9166259765625,"y":41.66668510437012,"wires":[]},{"id":"6aa2d9f6.955d28","type":"function","z":"9592163f.6a6de8","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = parseInt(tokens[0]);\n        msg.childSensorId = parseInt(tokens[1]);\n        msg.messageType = parseInt(tokens[2]);\n        msg.ack = parseInt(tokens[3]);\n        msg.subType = parseInt(tokens[4]);\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":1023.6666488647461,"y":180.66664123535156,"wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","z":"9592163f.6a6de8","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1858.9166526794434,"y":181.16665649414062,"wires":[]},{"id":"b5e4f17d.4a1b1","type":"function","z":"9592163f.6a6de8","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_CONFIG')\n{\n    var payload = 'M';\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_CONFIG; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n}\nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\n\n","outputs":1,"noerr":0,"x":1694.916648864746,"y":543.4166889190674,"wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6d67f33.19298","type":"inject","z":"9592163f.6a6de8","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":145.25,"y":81.41665363311768,"wires":[["64617800.9b9e88","56b9f6ab.a94608","3e866f6d.c1799"]]},{"id":"ebcef3df.14311","type":"function","z":"9592163f.6a6de8","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":829.1666946411133,"y":181.91668796539307,"wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","z":"9592163f.6a6de8","name":"","x":58,"y":449,"wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":224,"y":450,"wires":[]},{"id":"64617800.9b9e88","type":"function","z":"9592163f.6a6de8","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_STATUS              = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_STATUS:            MySHelper.prototype.V_STATUS,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \nMySHelper.prototype.VNum = function(V_SUBTYPE) {\n    sRet = vtype [V_SUBTYPE];\n    if (sRet === undefined)\n        sRet = V_SUBTYPE;\n    return sRet;\n}\n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n MySHelper.prototype.encode = function(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":383.25,"y":20,"wires":[[]]},{"id":"df1e322.f20e1d","type":"function","z":"9592163f.6a6de8","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":641.0000076293945,"y":147.49999809265137,"wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","z":"9592163f.6a6de8","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":133,"y":214.25,"wires":[["3e866f6d.c1799"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.14","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 14","x":410.5,"y":207.24999618530273,"wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","z":"9592163f.6a6de8","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":653.5,"y":205.7500114440918,"wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","z":"9592163f.6a6de8","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":395,"y":65,"wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","z":"9592163f.6a6de8","name":"Debug","active":false,"console":"false","complete":"true","x":732,"y":361,"wires":[]},{"id":"57db23d6.a824dc","type":"function","z":"9592163f.6a6de8","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":658,"y":53,"wires":[[]]},{"id":"dfba7d69.20458","type":"file","z":"9592163f.6a6de8","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1473,"y":381.99999618530273,"wires":[]},{"id":"e0e76d62.1f189","type":"function","z":"9592163f.6a6de8","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n// node.log(\"Handling next ids\");\n// node.log(\"nodeId: \" + msg.nodeId);\n\nbChanged = false;\n\nif (msg.nodeId === 0) return;\n\nif (msg.nodeId < 255)\n{\n    // node.log(\"Test if next node-id must be set\");\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        node.log(\"node-id not initialized yet\");\n        context.global.mysnextid[msg.controller] = msg.nodeId+1;\n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n    \n    // node.log(\"Nexid stored \" + parseInt(context.global.mysnextid[msg.controller]));\n    \n    if (msg.nodeId >= parseInt(context.global.mysnextid[msg.controller])) {\n        node.log(\"node-id >= next -> increase\");\n        // convert to int\n        context.global.mysnextid[msg.controller] = parseInt(context.global.mysnextid[msg.controller]);\n        context.global.mysnextid[msg.controller] = msg.nodeId+1; \n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n\n    if (bChanged) {\n        node.log(\"next id must be stored\");\n        msg.payload = JSON.stringify(context.global.mysnextid);   \n        return msg;\n    }\n}\n\n\n","outputs":1,"noerr":0,"x":1262,"y":374.99999618530273,"wires":[["dfba7d69.20458","5c074c19.a3f8b4"]]},{"id":"8da09002.725f7","type":"function","z":"9592163f.6a6de8","name":"MQTT to MYS convert","func":"// topic = MYS-NODERED/set/controller/node-id/sensor-id/ack/sub-type\n// payload = payload :)\n\n    var tokens = msg.topic.split(\"/\");\n    \n    msg.rawData = tokens;\n    msg.tokens = tokens.length;\n    if(tokens.length == 7)\n    {\n        if (tokens[0] != context.global.MYS.TOPIC_PREFIX) // not for us\n            return;\n        if (tokens[1] != 'set') // not for us\n            return;\n            \n        msg.controller = parseInt(tokens[2]);\n        msg.messageType = context.global.MYS.T_SET;\n        msg.nodeId = parseInt(tokens[3]);\n        msg.childSensorId = parseInt(tokens[4]);\n        msg.ack = parseInt(tokens[5]);\n        msg.subType = context.global.MYS.VNum(tokens[6]);\n        \n        msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, msg.messageType, msg.ack, msg.subType, msg.payload);\n    \n        return msg;        \n    }\n","outputs":1,"noerr":0,"x":490,"y":361,"wires":[["e000bd09.1fff4","266b87b3.d99478"]]},{"id":"3e866f6d.c1799","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.13","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 13","x":407,"y":145.99999618530273,"wires":[["df1e322.f20e1d","9386fdb0.6c79"]]},{"id":"5c074c19.a3f8b4","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":1454,"y":543.9999961853027,"wires":[]},{"id":"c75fd7f4.38a028","type":"mqtt in","z":"9592163f.6a6de8","name":"Read MQTT Stream: change Topic to your needs","topic":"MYS-NODERED/set/#","broker":"ba386057.845d3","x":183.5,"y":362,"wires":[["8da09002.725f7"]]},{"id":"9386fdb0.6c79","type":"function","z":"9592163f.6a6de8","name":"Watchdog controller 1","func":"if (isNaN(context.global.controller1count))\n    context.global.controller1count=0;\n\n\ncontext.global.controller1count++;\n\n","outputs":1,"noerr":0,"x":630,"y":105,"wires":[[]]},{"id":"d465a67.f2b9a58","type":"inject","z":"9592163f.6a6de8","name":"Check health controller 1 every 5 minutes","topic":"","payload":"","payloadType":"none","repeat":"60","crontab":"","once":false,"x":173,"y":516,"wires":[["aa935a.ff556ca8"]]},{"id":"aa935a.ff556ca8","type":"function","z":"9592163f.6a6de8","name":"check health controlller 1","func":"if (isNaN(context.global.controller1count))\n    context.global.controller1count=0;\n    \nif (context.global.controller1count === 0) {\n    // make a new connection to the controller\n    msg.payload = \"\";\n    node.log(\"no message recieved on mys controller 1, try to connect\");\n    \n    return msg;\n}\nelse\n{\n    // reset counter\n    context.global.controller1count=0;\n}\n","outputs":1,"noerr":0,"x":470,"y":510,"wires":[["c8b342e9.374cc","3e866f6d.c1799"]]},{"id":"c8b342e9.374cc","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":682,"y":511,"wires":[]}]```
              AWIA L 2 Replies Last reply
              • F
                F
                Fabien
                It's not spam. You can share your flow !
                • FotoFieberF FotoFieber
                  fetsF
                  fetsF
                  fets
                  @FotoFieber keep going. Each time you post a new release I get it, even if i'm not using it :).
                  But it really gives ideas on what we can do with node-red.
                  Anyway thanks for your work and haring
                    AWIA
                    AWIA
                    AWI
                    @FotoFieber Please keep going. I always load the scripts to node-red to learn. Thanks
                      L
                      L
                      LeoDesigner
                      @FotoFieber
                      Great work, keep going! I have a modified version of your flow with message resend if not received - but it's a bit ugly to publish here.
                      • H humblehacker
                        I've used NodeRED for various tasks over the years and it still remains my favorite IOT interface. All the while I've tried at least 5 of the officially supported MS controllers out there and nothing has come close! At present I'm trying Home Assistant but am almost ready to give up and set up my own workflow with NodeRED. There's a blog post at https://crankylinuxuser.net/2015/10/01/idiot-crazy-ways-to-make-iot-simple-and-cheap/ that includes a great example of a MySensors+NodeRED flow along with a spot-on critique of mainstream automation services being marketed at present.
                        The only reason I havent just used NodeRED in the past is it would still require other components to truly make a unified home automation service. An ideal scenario IMHO would be something that uses NodeRED as a front-end with something more unified running it.
                        crankyC
                        crankyC
                        cranky
                        @humblehacker
                        Hello! I've not had a chance to update my blog with new updates. I'm busy with converting over my site to a pure node-red backend and being able to push updates via NR on my laptop via clone-flow. But that aside....
                        There's currently a regression in the newest serial port node in NR.
                        Arduino Nano->SerialGateway->NR->MySensors works with receiving data. However
                        Data->MySensors encoder->Serial is currently not working. It's NOT MySensors' fault. If I open up console on Serial gateway and an actuator, I can manually send commands and show that radio does in fact work.
                        Where I am at now, is trying to figure out where the node-red-node-serial is in error. I know the recent node.js has caused havoc in the node-red ecosystem, mainly with hardware-to-node modules.
                        But I'm glad people are referencing my work thus far :)
                        The CrankyLinuxUser (whois for email/phone) if you have any further questions.
                        • crankyC
                          crankyC
                          cranky
                          Ok. I think I finally got to the root of the issue. It's a mixture of "Inject" and mysdecenc errors. Inject mangles "\n" on the string inject node, and mysdecenc doesn't add the proper ending of the payload "\n" to complete the transmission from the gateway to the node.
                          I have a flow, and inside it is 2 duplicate paths of the same data. The upper one is a manual MySensors node-red node done with functions, and the lower is using the node-red-contri-mysensors nodes.
                          [{"id":"90402c72.682b08","type":"serial-port","z":"ec82138a.7e61d","serialport":"/dev/ttyUSB4","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false},{"id":"cbb9cba0.69cf1","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"500","payloadType":"string","repeat":"","crontab":"","once":false,"x":131,"y":274,"wires":[["7fb75e44.d87738"]]},{"id":"359a983d.9e87d8","type":"debug","z":"ec82138a.7e61d","name":"","active":true,"console":"false","complete":"true","x":800,"y":380,"wires":[]},{"id":"9a892a68.a4d97","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"1000","payloadType":"string","repeat":"","crontab":"","once":false,"x":131,"y":316,"wires":[["7fb75e44.d87738"]]},{"id":"473303a0.d810ec","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"0","payloadType":"string","repeat":"","crontab":"","once":false,"x":129,"y":233,"wires":[["7fb75e44.d87738"]]},{"id":"c84afb59.3425a8","type":"template","z":"ec82138a.7e61d","name":"convert to payload","field":"payload","format":"handlebars","template":"{{nodeId}};{{childSensorId}};{{subType}};{{messageType}};{{ack}};{{payload}}","x":544,"y":270,"wires":[["359a983d.9e87d8","6fc996d1.7babb"]]},{"id":"7fb75e44.d87738","type":"function","z":"ec82138a.7e61d","name":"Manual MySensors","func":"msg.nodeId = 10;\nmsg.childSensorId = 10;\nmsg.subType = 1;\nmsg.messageType = 1;\nmsg.ack = 3;\n\nmsg.payload = msg.payload + \"\\n\" ;\n\nreturn msg;","outputs":1,"noerr":0,"x":332,"y":270,"wires":[["c84afb59.3425a8"]]},{"id":"6fc996d1.7babb","type":"serial out","z":"ec82138a.7e61d","name":"","serial":"90402c72.682b08","x":818,"y":323,"wires":[]},{"id":"98c26eed.2fb63","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"500","payloadType":"string","repeat":"","crontab":"","once":false,"x":136,"y":431,"wires":[["952f68a.e0ff198"]]},{"id":"5d0a69be.2b841","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"1000","payloadType":"string","repeat":"","crontab":"","once":false,"x":136,"y":473,"wires":[["952f68a.e0ff198"]]},{"id":"f32d1e54.bde4b","type":"inject","z":"ec82138a.7e61d","name":"","topic":"","payload":"0","payloadType":"string","repeat":"","crontab":"","once":false,"x":134,"y":390,"wires":[["952f68a.e0ff198"]]},{"id":"d3587219.c775c8","type":"mysencap","z":"ec82138a.7e61d","name":"","nodeid":"10","childid":"10","subtype":"3","internal":0,"ack":true,"msgtype":"1","presentation":false,"presentationtype":0,"presentationtext":"","fullpresentation":false,"firmwarename":"","firmwareversion":"","x":478,"y":427,"wires":[["cf568bb2.74a438"]]},{"id":"cf568bb2.74a438","type":"mysdecenc","z":"ec82138a.7e61d","name":"","x":618,"y":427,"wires":[["6fc996d1.7babb","359a983d.9e87d8"]]},{"id":"952f68a.e0ff198","type":"function","z":"ec82138a.7e61d","name":"slash n on payload","func":"msg.payload = msg.payload + \"\\n\";\nreturn msg;","outputs":1,"noerr":0,"x":314,"y":427,"wires":[["d3587219.c775c8"]]}]
                          You will have to change the nodes to correspond to your actuators as well as your serial port. Aside that, with the appropriate fix, it works well.
                          / Off to create my NeoPixel Node
                          L 1 Reply Last reply
                          • crankyC cranky
                            L
                            L
                            LeoDesigner
                            wrote on last edited by LeoDesigner
                            #34
                            @cranky
                            One small bugfix to your ToString function.
                            //msg.payload = msg.payload.toString().replace(/[\n\r]/g, '');
                            // sometimes we are receiving a several messages in one packet
                            // we should spit them and emit one by one
                            var outputMsg = [];
                            msg.payload = msg.payload || '';
                            msg.payload = msg.payload.toString();
                            var parts = msg.payload.split("\n");
                            for (var id in parts) {
                                var payload = parts[id].replace(/[\n\r]/g, '');
                                if (payload.length > 0) {
                                    outputMsg.push({
                                        payload: payload,
                                        controller: msg.controller
                            return [outputMsg];
                            • crankyC
                              crankyC
                              cranky
                              The flow you are giving feedback on is from @FotoFieber , not I :)
                              I was a wee confused, as my flow didn't have a string conversion like that in there. Now, the Router->2d array IP addresses on nodered.org does, but I didn't link that.
                              Here's that link: http://flows.nodered.org/flow/9b48db38d8c2bee59367 . If you have a crappy ATT router, you can get a nice list of machines.
                              • crankyC cranky
                                L
                                L
                                LeoDesigner
                                @cranky
                                Yep - you are right :)
                                Does anybody had a problem with retained messages from mqtt broker?
                                Seems to me I am receiving only some retained messages from mosquitto - not all of them :( Looks like it's a bug in nodered mqtt or mosquitto.
                                • L LeoDesigner
                                  @cranky
                                  var outputMsg = [];
                                          outputMsg.push({
                                              payload: payload,
                                  return [outputMsg];
                                  FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  @LeoDesigner
                                  Thx for the bugfix. I have observed this problem on some occations but it didn't hurt too much. :) Glad you found the bug.
                                  • crankyC
                                    crankyC
                                    cranky
                                    @hek As a meta-discussion, would you be so kind as to create a Node-Red Controller Subcategory?
                                    Since Rasberry-Pi's recent addition to Raspbian including NR on all installs, I think we're going to see a lot more questions regarding the nRF and MySensors. And frankly, NR is just amazing :)
                                    • crankyC
                                      crankyC
                                      cranky
                                      Thank you much, @hek !
                                      • msevM
                                        msevM
                                        msev
                                        Node-red is great. I'd be interested in entire flows, entire integrations for home automation purposes (ofc with credentials data taken out). So if anyone has something interesting to show please share :D thanks
                                        • F
                                          F
                                          Fabien
                                          Someone here have a flow working with ACK messages ? And retry feature ? For example 5 retries before failling ?
