  3. Why MySensors isn't using interrupts for nrf24?
24 Posts 7 Posters 13.1k Views 2 Watching
  • OitzuO
    OitzuO
    Oitzu
    wrote on last edited by Oitzu
    @robosensor okay. I don't have any experience with the esp8266 port yet.
    @Yveaux: Ah okay, you mean like the mysensors ack flag but with automatic buffering and handling by the library?
    • F
      F
      Fabien
      I'm sure of my setup too.
      First board : NRF+PA+LNA with nano on PCB
      Second board : Same NRF with Iboard in the same place
      Same power supply. Test on 2 different ethernet switchs.
      I doesn't move the sensebender (send every 30s). library 1.6 with softSPI on Iboard.
      Store value with node-red flow in influxdb database on ODROID C1
      24 hours of test fo eache setup. 0% of packet loss for the first setup. Lot of lost packet in the second setup especially during the day when the network is in use.
      I can try with UNO and W5100 if you want but I have same issue on ESP8266.
      For me I want to have someting simple to ensure acknoledge for destination. For temperature regulation or roller shutter it's very important. You can do it but it's not very easy.
      Example Yesterday with serial gateway
      And Today with IBoard
      • OitzuO Oitzu
        Yes. There's the ack-flag, which is part of the nRF24L01+ chip, that automatically resends packets to the next node when a packet reception is not acknowledged. After a number of failed attempts the nRF24 will give up and return an error.
        On top of this is the MySensor's ack-flag which will track a message from source to destination and back again, even when the message gets routed by repeaters. The library however does not automatically resend a message which does not get ack'ed -- your application has to take care of this.
        For reliable communication the gateway, repeaters and sensor nodes all have to be able to buffer messages and automatically resend them. Depending on the maximum number of messages in transit simultaneously an ATMega328 will most likely not be able to buffer sufficient messages for a gateway or repeater node (too little ram).
        • YveauxY
          @Fabien So your network only consists of 1 node (sensebender) that sends every 30 seconds, and 1 gateway, correct?
          How many messages does the node produce every 30 seconds?
          The nRF24 is able to buffer upto 3 messages before it starts dropping packets, but I would have to dig into the MySensors/nRF24 code to see if these buffers are actually used.
          • OitzuO
            OitzuO
            Oitzu
            @Fabien also interesting: how is the nrf24l01 pa/lna powered? You are talking about the same power supply on both boards, but are you powering the nrf directly from this power supply or from a onboard 3.3V regulator?
            Especially the pa/lna versions tends to be a little bit problematic especially on the maximum power setting.
            • L
              L
              LeoDesigner
              wrote on last edited by LeoDesigner
              I have implemented a resend if not received algorithm based on node-red.
              It is working only one way from controller/mqtt/gw -> node.
              The message will be resend after timeout in case if it is not acknowledged by a node. I can gather stats based on number of packets/lost per node. Even my RS485 nodes have a small packet loss. An average packet/command roundtrip (gw->node->gw) on radio is about 40-50ms, and 10-30ms on wired RS485 bus. Usually acknowledgement arrives after 50ms for sure - but some packets are received after 150ms and even after 250ms (who knows - maybe node is busy or gw). I am still testing this approach based on node-red. Seems to me the packets from gw to nodes are lost more frequently. One of my distant radio nodes loosing about 70% of messages :(
              • F
                F
                Fabien
                My sensebender node is with default sketch so 2 messages (temp and hum). I just change MEASURE_INTERVAL and FORCE_TRANSMIT_INTERVAL. And yes the RFM is powered with onboard regulator.
                I will made another test with serial gateway sketch on Iboard. I will post results in few days. So the hardware will be exactly the same.
                • YveauxY
                  @Fabien said:
                  RFM
                  One post you say NRF, now RFM... Which one are you actually using :question: :question: :question:
                  • F
                    F
                    Fabien
                    Sorry, I made my tests with NRF !
                    • YveauxY
                      And a send of battery level every 60 runs of loop() (according to https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino)
                      Anyway, that's 3 messages in total every 30 seconds. The nRF has a 3-message receive buffer, so when used correctly those 3 messages should just stay in that buffer waiting for the MySensors stack to retrieve them.
                      Could you retry by changing the following line in your gateway code:
                      into
                      This will try to read 3 messages (the whole message buffer) at each run of the gateway loop().
                      @hek I had a look at the MySensors code and have some doubts about following line: https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L556
                      Shouldn't the receive function be called repeatedly until no message is available anymore ? Now it will only read & process one message maximum on each gateway.process() call, while there could be up to 3 messages waiting in the fifo and new messages can come in while processing others.
                      Furthermore I'm not sure of the code around https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/utility/RF24.cpp#L878
                      This listeningStarted flag seems to be used to force a delay of 800us after start listening, but the flag is not set when listening starts. In e.g. Thomas' nrf24 github repo (https://github.com/thozza/MySensors-Raspberry/blob/master/librf24-bcm/RF24.cpp#L527) the flag is set when listening starts and TMRh20 doesn't implement this delay (https://github.com/TMRh20/RF24/blob/master/RF24.cpp#L1067)
                      Seems like we have some halve-merged code, but I wasn't able to track its origin (it was committed by you on 16 Sep 2014)
                        @Yveaux
                        Yep, might be good to dequeue the NRF fifo as fast as possible.
                        Same goes for dev-branch
                        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyTransport.cpp#L47
                        Process should probably return true (when new message was available) and be "whiled" from here:
                        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MySensorCore.cpp#L52
                        Hmm.. don't recognize the listeningStarted flag.. As you say.. Might be some half done refactoring... Let's ping @thozza .
                        • F Fabien
                          @Fabien Now I think about it; calling gw.process() three times in a row on the gateway will probably make no difference, as each gw.process() will end up in transmitting data to a remote server and block like it used to do...
                            @Yveaux
                            Especially for a sleeping slave (which uses the same code as a gateway).
                            tekkaT 1 Reply Last reply
                            • YveauxY Yveaux
                              tekkaT
                              tekkaT
                              tekka
                              @Hek: In the dev branch, _process() is called in main(): https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMainDefault.cpp#L12.
                              As long as nodes are non-blocking and not sleeping, all queued messages are processed. However, for sleeping nodes we have to make sure the queue is processed before sending the node to sleep. The 800us delay code snippet (if correctly implemented) may help to stabilize the RF after switching to RX...
                              • F
                                F
                                Fabien
                                Ok so I continue my test with the same code. And you are right the sensebender send battery level every 30mins.
                                For this test, I use exactly the same hardware and same wiring (including ethernet câble for both sketch). I will post result on monday (about 24h for each sketch).
                                Serial sketch
                                 * LEDs (OPTIONAL):
                                 * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                                #define MY_SOFTSPI
                                #define MY_SOFT_SPI_SCK_PIN 7
                                #define MY_SOFT_SPI_MISO_PIN 6
                                #define MY_SOFT_SPI_MOSI_PIN 5
                                #define MY_RF24_CE_PIN 3
                                #define MY_RF24_CS_PIN 8
                                // Enable serial gateway
                                #define MY_GATEWAY_SERIAL
                                // Flash leds on rx/tx/err
                                //#define MY_LEDS_BLINKING_FEATURE
                                // Set blinking period
                                // Enable inclusion mode
                                And Ethernet Sketch
                                 * LEDs (OPTIONAL):
                                #define MY_GATEWAY_W5100
                                #define MY_SOFTSPI
                                #define MY_IP_ADDRESS 192,168,2,200   // If this is disabled, DHCP is used to retrieve address
                                #define MY_PORT 5003
                                //#define MY_GATEWAY_SERIAL
                                #include <Ethernet.h>
                                • F
                                  F
                                  Fabien
                                  After 2 days of test. I lost few packets (5 or 6 in 24 hours and usually humidity ...). I will perform another test after changing all my ethernet câbles.
                                  12.5k
