  3. My Slim 2AA Battery Node
498 Posts 71 Posters 585.3k Views 69 Watching
  • m26872M m26872
    @dakky Plz correct me... but I guess you're talking about the Avr sleep cycles? I don't know what that's got to do with the bootloader or this thread. I think it's related to interrupt, timers, mysensors and arduino lowpower library. The sleep cycles shouldn't be something to worry about if you're using the "sleep" function as in MySensors API.
    dakkyD
    dakkyD
    dakky
    wrote on last edited by dakky
    #100
    @m26872 hmm you're right. maybe this is a too generic question to be discussed here. pardon me.
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
      martkrui
      wrote on last edited by martkrui
      #101
      I had a bit of an issue getting things going as I've never played with the fuses before. Maybe this can save someone else some time. If I'm doing something silly here please correct me. :sweat_smile:
      [DISCLAIMER] this worked for me. Use at own risk[DISCLAIMER]
      Executed these commands from the subfolder \hardware\tools\avr\bin of my local arduino IDE.
      Connected the board ICSP using an USBASP with the latest firmware. Change the "-c usbasp" part if you connect using something else.
      Flash bootloader
      avrdude -C ../etc/avrdude.conf -c usbasp -B5 -p ATmega328P -U flash:w:..\..\..\arduino\avr\bootloaders\atmega\atmega328_1a.hex
      Set fuses
      I think the B5 was crucial as it slows things down a bit. The bootloader (atmega328_1a.hex) is the one mentioned in the first post. I also added the part in the boards.txt of the arduino IDE.
      Now I can connect the board to the FTDI and upload and run sketches without issues.
      On to the next step :smiley: :+1:
      • dakkyD
        dakkyD
        dakky
        I am not so really skilled in transferring a wiring diagram to "real live". Is this the correct implementation for battery measuring?
        upload-8e188148-e6c0-44ef-9b8c-a01fe9cd1c3a
        m26872M 1 Reply Last reply
        • dakkyD dakky
          m26872M
          m26872M
          m26872
          @dakky First, the "normal" battery monitoring to this node is to use the internal method by, if you like, using the vcc library. Measuring Vcc with external voltage divider makes not a lot of sense. The external voltage divider is useful when measuring e.g. raw battery voltage to some voltage regulator.
          Second, I think you've switched A0 and Gnd in your drawing.
          • dakkyD
            dakkyD
            dakky
            #104
            hurm did i switch them?
            Concerning the method: hmm ok. I just thought, that the one recommenced in the build section of mysensors should be the "correct" one.
            EDIT: Hrhr @Yveaux vcc lib is cute :D workd out of the box ;) thx
            • A
              arnoldg
              Is there some one who have lying around several boards, who can share them with me.
              i'm from the netherlands, and for now i only need 5 to 6 boards, not 30 :)
              so i hope i could take over a couple from someone.
              AWIA A 2 Replies Last reply
              • A arnoldg
                AWIA
                AWIA
                AWI
                @arnoldg send me a pm...
                • A arnoldg
                  ar91
                  Same here, anybody in US has 4 or 5 boards that i could buy?
                  • dakkyD
                    dakkyD
                    dakky
                    Anyone want to share some photos with sensors assembled?
                    Any experiences how long this node will last? I have one DHT11 and one BH1750 onboard and will wake up the node every 5-15 Minutes.
                    Greetings
                    Dakky
                    rsachocR 1 Reply Last reply
                    • N
                      N
                      nikos1671
                      If I order the 10 pieces for 14$ how many sensor I can build? They mean 10 panels with 3 boards each one?
                      • K
                        K
                        kr0815
                        wrote on last edited by kr0815
                        #110
                        yes, that´s 30 sensors you could build then
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          @nikos1671 If you buy the proto pack you could get 9,10 or 11 boards. It could be different that exactly 10 boards. In my case I received 12 boards for my design, in another order I received 11 boards. My last order was 10 boards. But in any case you will be able to make more then 25 sensors. Plenty for a normal house.
                          • dakkyD dakky
                            Greetings
                            Dakky
                            rsachocR
                            rsachocR
                            rsachoc
                            wrote on last edited by rsachoc
                            #112
                            Greetings
                            Dakky
                            I would like this too please! I'm trying to decide on which node to use as a motion sensor and temp/humidity sensor and would like to understand how I add a temp/humidty sensor to these and also the battery drain. And also, what temp/humidity sensors are we able to use with this node? I guess it ouputs max 3v, so does that mean the DHT11 and DHT22 are not able to be used here? Sorry for the newbie questions, I'm beginning to explore my options in relation to building my initial temp/humidity sensor and then a motion sensor.
                            edit OK, so based on what m26872 said here (http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor/5) I think that I can only use Si7021 or HTU21 sensors as this outputs around 3v? From reading the spec sheet of the DHT11 and 22 I see they need 3.7v, so I guess if I want to use those sensors I need this node (http://forum.mysensors.org/topic/486/my-2aa-battery-sensor)?
                            • rsachocR rsachoc
                              Greetings
                              Dakky
                              m26872M
                              m26872M
                              m26872
                              @rsachoc Yep, you got it right.
                              • dakkyD
                                dakkyD
                                dakky
                                #114
                                Arghls no DHT11 with this node? Dammit. But a step up converter should do it?
                                • m26872M
                                  m26872M
                                  m26872
                                  wrote on last edited by m26872
                                  #115
                                  Humidity Sensor example
                                  http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example
                                  (This post used to contain a not yet finished design by mistake. The link above now shows the correct finished project.)
                                  AWIA 1 Reply Last reply
                                  • m26872M
                                    m26872M
                                    m26872
                                    #116
                                    Reed Switch example
                                    With external 10M pull-up to save battery. The plastic foam is used instead of a fixed mount, for easy disassemble, reflash, battery renewal etc.
                                    The Sketch
                                    // EgSlimReed2
                                    // By m26872, 2015-12-22
                                    // Interrupt driven binary switch for Slim Node with Reed switch and external pull-up (10Mohm)
                                    // Inspired by mysensors example:
                                    // https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino
                                    #include <Vcc.h>
                                    #define NODE_ID 5 //12 var senaste "reed-node"-id // 110    // Use static Node_ID  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                                    #define SKETCH_NAME "EgSlimReed"
                                    #define SKETCH_VERSION "2.0 2015-12-22"
                                    #define SW_CHILD_ID 5
                                    #define SW_PIN 3
                                    #define BATTERY_REPORT_DAY 2   // Desired heartbeat interval when inactive. Maximum heartbeat/report interval is equal to this due to the dayCounter.
                                    #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Adjust this according to usage frequency.
                                    #define ONE_DAY_SLEEP_TIME 86400000
                                    #define VCC_MIN 1.9
                                    #define VCC_MAX 3.3
                                    int dayCounter = 0;
                                    int irtCounter = 0;
                                    uint8_t value;
                                    uint8_t sentValue=2;
                                    bool interruptReturn=false;
                                    Vcc vcc;
                                    MyMessage msg(SW_CHILD_ID, V_TRIPPED);
                                      delay(100); // to settle power for radio
                                      gw.begin(NULL,NODE_ID);
                                      pinMode(SW_PIN, INPUT);
                                      digitalWrite(SW_PIN, LOW);    // Disable internal pull-ups
                                      gw.present(SW_CHILD_ID, S_DOOR);
                                      if (!interruptReturn) { // Woke up by timer (or first run)
                                    	dayCounter++;
                                    	if (dayCounter >= BATTERY_REPORT_DAY) {
                                    		  dayCounter = 0;
                                    		  sendBatteryReport();
                                      else {	// Woke up by pin change
                                    	  irtCounter++;
                                    	  gw.sleep(50);  	  // Short delay to allow switch to properly settle
                                    	  value = digitalRead(SW_PIN);
                                    	  if (value != sentValue) {
                                    		 sentValue = value;
                                    	  if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
                                    		irtCounter=0;
                                      // Sleep until something happens with the sensor,   or one sleep_time has passed since last awake.
                                      interruptReturn = gw.sleep(SW_PIN-2, CHANGE, ONE_DAY_SLEEP_TIME);
                                    void sendBatteryReport() {
                                    		  float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
                                    		  int batteryPcnt = static_cast<int>(p);
                                    • m26872M
                                      m26872M
                                      m26872
                                      Motion sensor example
                                      As already mentioned; more details to be found here.http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                                      • dakkyD
                                        dakkyD
                                        dakky
                                        do u add these photos and comments to openhardware.io ? they are quite helpful
                                        • m26872M m26872
                                          AWIA
                                          AWIA
                                          AWI
                                          @m26872 I don't use any I2C pull-ups. All my Si7021/ SHT21 (GY-21) boards include the SDA/SCL pull-ups (and LDO voltage regulator/ level conversion).
                                          m26872M rsachocR 2 Replies Last reply
